inserting the usb key dwa-171eu series c1 is not detected, tried to install some drivers from aur
rtl8812au-20210629-dkms-git
And
rtl8812au-dkms-git
but I can't see it
Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a8648e1b-5150-45d3-94da-1ae02ea414d9 rw rootflags=subvol=@
Type: Desktop System: Hewlett-Packard product: HP Compaq Elite 8300 SFF
v: N/A serial: <superuser required> Chassis: type: 4
Mobo: Hewlett-Packard model: 3397 serial: <superuser required>
UEFI: Hewlett-Packard v: K01 v02.98 date: 03/18/2015
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3310 high: 3848 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3726 2: 3807 3: 3796
4: 3397 5: 1766 6: 2349 7: 3797 8: 3848 bogomips: 54273
Type: l1tf
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: Micro-Star MSI
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c81 class-ID: 0300
Device-2: Sunplus Innovation HD 720P webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.6.1:6 chip-ID: 1bcf:2701
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9")
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
Device-3: Sunplus Innovation HD 720P webcam type: USB
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: f020 bus-ID: 00:19.0 chip-ID: 8086:1502
driver: btusb v: 0.8 bus-ID: 1-1.2:3 chip-ID: 0a12:0001 class-ID: fe01
Local Storage: total: 588.73 GiB used: 11.14 GiB (1.9%)
ID-1: /dev/sdb maj-min: 8:16 vendor: Intenso model: SSD SATAIII
type: SSD serial: <filter> rev: 4A0 scheme: GPT
ID-2: /dev/sdd maj-min: 8:48 vendor: Silicon Power
model: SPCC Solid State Disk size: 111.79 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: V3.3
used: 11.14 GiB (2.3%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.57 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 41 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 43%
Processes: 313 Uptime: 36m wakeups: 0 Memory: 15.57 GiB
used: 3.6 GiB (23.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1417 lib: 338 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
Garuda (2.5.3-1):
System install date: 2022-01-31
Last full system update: 2022-01-31
