Good morning, after a re-install of Garuda I am unable to use my wi-fi adapter.
I have spent days scrolling and tried many of the listed drivers and while my system recognizes the usb and has a driver I am still unable to use this device.
I will post relevant info, please let me know if I can provide anything further.
Has anyone had experience getting this working?
Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=fbd21df3-1201-42be-8443-69125f954c6f rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: F2A88XN-WIFI v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F2 date: 12/16/2013
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
Info: model: AMD A10-7850K APU with Radeon R7 Graphics bits: 64 type: MT MCP
arch: Steamroller level: v2 built: 2014 process: GF 28nm family: 0x15 (21)
model-id: 0x30 (48) stepping: 1 microcode: 0x6003103
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3451 high: 3700 min/max: 1700/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 2706
3: 3700 4: 3700 bogomips: 29548
Device-1: AMD Kaveri [Radeon R7 Graphics] driver: radeon v: kernel
alternate: amdgpu arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm
built: 2013-17 ports: active: none empty: DVI-D-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:01.0 chip-ID: 1002:130f class-ID: 0300
Device-2: NVIDIA GM107GL [Quadro K1200] driver: nouveau v: kernel
non-free: 545.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-2019 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1 empty: DP-2,DP-3,DP-4 bus-ID: 01:00.0 chip-ID: 10de:13bc
class-ID: 0300 temp: 49.0 C
compositor: kwin_wayland driver: X: loaded: nouveau,radeon
unloaded: modesetting alternate: fbdev,nv,vesa dri: nouveau,radeonsi
gpu: radeon,nouveau display-ID: 0
Monitor-1: DP-1 res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: amd radeonsi platforms:
device: 0 drv: radeonsi device: 1 drv: nouveau device: 2 drv: swrast gbm:
drv: nouveau surfaceless: drv: radeonsi wayland: drv: nouveau x11:
drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.7-arch1.3 glx-v: 1.4
direct-render: yes renderer: NV117 device-ID: 10de:13bc memory: 3.9 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: AMD Kaveri HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:1308 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fbc
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:08b1 class-ID: 0280
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
chip-ID: 045e:02e6 class-ID: 0000 serial: <filter>
Device-4: TP-Link Archer T2U PLUS [RTL8821AU] driver: rtl88XXau type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-2:2 chip-ID: 2357:0120
IF: wlp0s16f0u2 state: dormant mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-3:2 chip-ID: 8087:07dc
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: yes address: see --recommends
Local Storage: total: 1.36 TiB used: 62.81 GiB (4.5%)
model: WD10EZEX-60WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
used: 62.81 GiB (13.5%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 14.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 21.9 C mobo: N/A
GPU: device: nouveau temp: 49.0 C fan: 4380 mV: 912.00 device: radeon
temp: 21.0 C
Memory: total: 16 GiB note: est. available: 14.57 GiB used: 2.24 GiB (15.3%)
Processes: 224 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.79 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1967 libs: 574 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26
System install date:     2024-05-04
Last full system update: 2024-05-15
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 045e:02e6 Microsoft Corp. Xbox Wireless Adapter for Windows
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 046d:c534 Logitech, Inc. Nano Receiver
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 8087:07dc Intel Corp. Bluetooth wireless interface
Bus 004 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 002: ID 2357:0120 TP-Link Archer T2U PLUS [RTL8821AU]
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
lsusb -t
/:  Bus 001.Port 001: Dev 001, Class=root_hub, Driver=ehci-pci/5p, 480M
|__ Port 001: Dev 002, If 0, Class=Vendor Specific Class, Driver=xone-dongle, 480M
/:  Bus 002.Port 001: Dev 001, Class=root_hub, Driver=ohci-pci/5p, 12M
|__ Port 003: Dev 002, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 002, If 1, Class=Human Interface Device, Driver=usbhid, 12M
/:  Bus 003.Port 001: Dev 001, Class=root_hub, Driver=ehci-pci/5p, 480M
/:  Bus 004.Port 001: Dev 001, Class=root_hub, Driver=ohci-pci/5p, 12M
|__ Port 003: Dev 002, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 003: Dev 002, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 005: Dev 003, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 005: Dev 003, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 005: Dev 003, If 2, Class=Human Interface Device, Driver=usbhid, 12M
/:  Bus 005.Port 001: Dev 001, Class=root_hub, Driver=ohci-pci/2p, 12M
/:  Bus 006.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
|__ Port 002: Dev 002, If 0, Class=Vendor Specific Class, Driver=rtl88XXau, 480M
/:  Bus 007.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/:  Bus 008.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
/:  Bus 009.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 5000M
DKMS Status
rtl88xxau/r1298.b44d288, 6.8.9-zen1-2-zen, x86_64: installed
xone-v0.3-57/g29ec357, 6.8.9-zen1-2-zen, x86_64: installed
