how do i connect to my wifi ?
it is enabled when i go to network assistant.
System: Kernel: 5.11.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=24d1d2c7-7a09-4ce9-a210-e033a3439cf1
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 80XH v: Lenovo ideapad 320-15ISK serial: <filter> Chassis:
type: 10 v: Lenovo ideapad 320-15ISK serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI-[Legacy]: LENOVO v: 4WCN47WW
date: 06/30/2020
Battery: ID-1: BAT0 charge: 21.6 Wh (100.0%) condition: 21.6/30.6 Wh (70.7%) volts: 8.5 min: 7.6
model: CPT-COS L16C2PB2 type: Li-poly serial: <filter> status: Full
CPU: Info: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake family: 6
model-id: 4E (78) stepping: 3 microcode: E2 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15999
Speed: 2000 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 2000 2: 2000 3: 2000 4: 2001
Graphics: Device-1: Intel HD Graphics 520 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:1921 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 920MX] vendor: Lenovo driver: nouveau v: kernel
bus-ID: 01:00.0 chip-ID: 10de:134f class-ID: 0302
Device-3: Syntek EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:3 chip-ID: 174f:241a
class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.0.3 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.11.16-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo driver: N/A
modules: rtl8821ae port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8821 class-ID: 0280
Bluetooth: Device-1: Realtek RTL8821A Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-7:2
chip-ID: 0bda:0821 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 931.51 GiB used: 31.49 GiB (3.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 0001 scheme: MBR
Partition: ID-1: / raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 31.49 GiB (3.4%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 31.49 GiB (3.4%) fs: btrfs
ID-3: /var/log raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 31.49 GiB (3.4%) fs: btrfs
ID-4: /var/tmp raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 31.49 GiB (3.4%) fs: btrfs
ID-1: swap-1 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 40.0 C mobo: N/A
Info: Processes: 211 Uptime: 5m wakeups: 14140 Memory: 5.71 GiB used: 2.36 GiB (41.3%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1936 lib: 389
Shell: fish v: 3.2.1 running-in: konsole inxi: 3.3.04
iwconfig
lo no wireless extensions.
enp2s0 no wireless extensions.
