Edit: Forgot greeting you people
Hello this place looks nice!
System: Kernel: 5.14.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=80343442-7c16-4057-a189-0f561ed24e1c rw
systemd.unified_cgroup_hierarchy=1 resume=UUID=9ce08bf3-2e28-49af-8a3e-82c102e47087 loglevel=3
Desktop: KDE Plasma 5.23.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: MSI model: Z170A PC MATE (MS-7971) v: 2.0 serial: <filter> UEFI: American Megatrends v: A.G0
date: 06/23/2018
CPU: Info: Quad Core model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S family: 6 model-id: 5E (94)
stepping: 3 microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27999
Speed: 3642 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 3642 2: 3691 3: 3648 4: 3746
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel HD Graphics 530 vendor: Micro-Star MSI driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1912
class-ID: 0380
Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: ZOTAC driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:13c2
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2") s-diag: 1055mm (41.5")
Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x269mm (18.8x10.6") diag: 548mm (21.6")
OpenGL: renderer: NV124 v: 4.3 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fbb class-ID: 0403
Device-3: Samson C01U Pro condenser microphone type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:4
chip-ID: 17a0:0303 class-ID: 0300
Sound Server-1: ALSA v: k5.14.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: TP-Link TL-WN822N Version 4 RTL8192EU type: USB driver: rtl8xxxu bus-ID: 1-6:5 chip-ID: 2357:0108
IF: wlp0s20f0u6 state: down mac: <filter>
IF-ID-1: enp0s20f0u3 state: unknown speed: -1 duplex: half mac: <filter>
Bluetooth: Device-1: Samsung Galaxy series misc. (tethering mode) type: USB driver: rndis_host v: kernel bus-ID: 1-3:3
chip-ID: 04e8:6863 class-ID: 0a00 serial: <filter>
Report: bt-service: enabled,stopped note: tool can't run
Drives: Local Storage: total: 1.24 TiB used: 20.44 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: OCZ model: TRION100 size: 111.79 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 11.2 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Transcend model: TS240GSSD220S size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 5F8 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZEX-22BN5A0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: 1A01 scheme: GPT
Partition: ID-1: / raw-size: 95.48 GiB size: 95.48 GiB (100.00%) used: 20.43 GiB (21.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 95.48 GiB size: 95.48 GiB (100.00%) used: 20.43 GiB (21.4%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 95.48 GiB size: 95.48 GiB (100.00%) used: 20.43 GiB (21.4%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw-size: 95.48 GiB size: 95.48 GiB (100.00%) used: 20.43 GiB (21.4%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: partition size: 16.05 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
ID-2: swap-2 type: zram size: 14.59 GiB used: 2.5 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 41.5 C mobo: 29.8 C gpu: nouveau temp: 42.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 814
Info: Processes: 218 Uptime: 10m wakeups: 0 Memory: 14.59 GiB used: 3.03 GiB (20.8%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1738 lib: 514 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.07
When I try to connect any network: after entering password, it stays in "configuring interface" for a while then "wireless interface (wlp0s20f0u6)" error pops up "The WiFi network could not be found". I tried both home wi-fi and mobile hotspot. Wired hotspot is working. I use a tp-link external wifi adapter.
Any idea why?
Also: Update function not working in Garuda Assistant. Terminal returns: "/bin/bash: line 1: update: command not found"
Edit 2: I tried restarting wi-fi module and selecting 2.4 / 5 GHz methods found in some other posts.
Edit 3: Thank you for updating the title.
