Installed RPCS3 from garuda assistant but the program fails to start. It gives this output
rpcs3: error while loading shared libraries: libwolfssl.so.30: cannot open shared object file: No such file or directory
Tried following some guides on solving shared libraries errors.
sudo ldconfig didn't help and trying to find library path with sudo find libwolfssl.so did not work. Thanks for any help!
Kernel: 5.16.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=74168034-3331-4447-b79f-cfe584359abd rw [email protected]
cryptdevice=UUID=5b832090-a2c7-482f-bd8d-c98baf90653c:luks-5b832090-a2c7-482f-bd8d-c98baf90653c
root=/dev/mapper/luks-5b832090-a2c7-482f-bd8d-c98baf90653c quiet splash
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.33 wm: muffin vt: 7
dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 7559 v: 1.2.0
Mobo: Dell model: 0H0CC0 v: A00 serial: <superuser required> UEFI: Dell
v: 1.2.0 date: 09/22/2016
ID-1: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
model: Logitech Gaming Mouse G900 type: N/A serial: <filter> status: Full
Device-1: sony_controller_battery_ac:fd:93:05:8b:7b model: N/A
serial: N/A charge: N/A status: Full
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 860 high: 900 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 841 4: 900
5: 898 6: 844 7: 900 8: 900 bogomips: 41599
Type: l1tf
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Dell driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.0
chip-ID: 10de:139b class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-4:6 chip-ID: 1bcf:28b0 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 driver: X:
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2816x864 s-dpi: 85 s-size: 838x257mm (33.0x10.1")
s-diag: 877mm (34.5")
Monitor-1: HDMI-1 mapped: HDMI-A-1 pos: primary,right
model: HDMI1-2714UDH serial: <filter> built: 2016 res: 1536x864 hz: 60
dpi: 65 gamma: 1.2 size: 596x335mm (23.5x13.2") diag: 685mm (27")
ratio: 16:9 modes: max: 4096x2160 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: Chi Mei Innolux built: 2013
res: 1280x720 hz: 60 dpi: 95 gamma: 1.2 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-2: BEHRINGER GmbH UMC204HD 192k type: USB driver: snd-usb-audio
bus-ID: 1-1:2 chip-ID: 1397:0508 class-ID: fe01
Sound Server-1: ALSA v: k5.16.14-zen1-1-zen running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:3165 class-ID: 0280
IF-ID-1: wgivpn state: unknown speed: N/A duplex: N/A mac: N/A
bus-ID: 1-5:9 chip-ID: 8087:0a2a class-ID: e001
address: <filter>
Local Storage: total: 698.65 GiB used: 118.63 GiB (17.0%)
model: WDS250G1B0B-00AS40 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST9500420AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SDM1 scheme: MBR
used: 118.63 GiB (51.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5b832090-a2c7-482f-bd8d-c98baf90653c
used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 15.5 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 62.0 C pch: 54.5 C mobo: 27.8 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 304 Uptime: 38m wakeups: 4 Memory: 15.5 GiB
used: 3.84 GiB (24.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1583 lib: 479 Shell: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-14
Last full system update: 2022-03-15
