Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=fda8a0a5-722d-46f7-8ec5-94eda5810359 rw rootflags=subvol=@
resume=UUID=e4e510cb-8fe0-461a-b564-d6596ced6432 loglevel=3
Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.37 wm: muffin dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: GA-78LMT-USB3 6.0 serial: N/A
BIOS: Award v: F2 date: 11/25/2014
Info: model: AMD FX-6300 socket: 754 (M2) note: check bits: 64 type: MT MCP
arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
model-id: 2 stepping: 0 microcode: 0x6000852
Topology: cpus: 1x cores: 6 smt: enabled cache: L1: 288 KiB
desc: d-6x16 KiB; i-3x64 KiB L2: 6 MiB desc: 3x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2816 high: 3500 min/max: 1400/3500 boost: enabled
base/boost: 3500/3000 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.5 V ext-clock: 200 MHz cores: 1: 3500 2: 2500 3: 3500 4: 3500
5: 1400 6: 2500 bogomips: 42186
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1,DVI-D-1
bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 44.0 C
Display: x11 server: X.Org v: 21.1.7 driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
s-diag: 414mm (16.31")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC 1970W serial: <filter>
built: 2015 res: 1366x768 hz: 60 dpi: 85 gamma: 1.2
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
max: 1366x768 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.0 renderer: AMD Radeon RX 550 / 550 Series
(polaris12 LLVM 15.0.7 DRM 3.49 6.2.7-zen1-1-zen) direct-render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aae0
Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
lanes: 1 port: ce00 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp0s19f2u4 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Xiaomi Mi/Redmi series (RNDIS) type: USB driver: rndis_host
v: kernel bus-ID: 3-4:9 chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 2.73 TiB used: 1.75 TiB (64.3%)
model: WD10EZRX-00L4HB0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: MBR
model: WD20EZBX-00AYRA0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-1: / raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
used: 327.54 GiB (35.7%) fs: btrfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
maj-min: 8:1
ID-3: /var/log raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
maj-min: 8:1
ID-4: /var/tmp raw-size: 918.68 GiB size: 918.68 GiB (100.00%)
maj-min: 8:1
ID-1: swap-1 type: zram size: 11.67 GiB used: 3.43 GiB (29.4%)
ID-2: swap-2 type: partition size: 12.83 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 52.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1600
Processes: 332 Uptime: 21h 48m wakeups: 0 Memory: 11.67 GiB
used: 6.31 GiB (54.1%) Init: systemd v: 253 default: graphical
pkgs: 1801 libs: 535 tools: octopi,pamac,paru pm: flatpak pkgs: 0
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-14
Last full system update: 2023-03-23 ↻
Need little Information on rkhunter log file.
https://www72.zippyshare.com/v/oUlE6nIm/file.html
