garuda-inxi:
Kernel: 6.4.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=308b5626-2597-4f46-9f16-a4d882bf2bf0 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: Unity info: xmobar, trayer wm: XMonad v: 0.17.1 vt: 2 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401QM_GA401QM
Mobo: ASUSTeK model: GA401QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GA401QM.412 date: 08/30/2022
ID-1: BAT0 charge: 59.8 Wh (99.0%) condition: 60.4/76.0 Wh (79.4%)
status: charging
Info: model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3100 high: 3300 min/max: 1200/4679 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2394 2: 3300
3: 1916 4: 3300 5: 3300 6: 3300 7: 3300 8: 3300 9: 3300 10: 3300 11: 3300
12: 3300 13: 3300 14: 3300 15: 2395 16: 3300 bogomips: 105396
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: DP-1
empty: none bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 60.0 C
compositor: Picom v: git-b700a driver: X: loaded: modesetting,nvidia
dri: radeonsi gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x2880
Monitor-1: DP-1 mapped: DP-1-0 note: disabled
model: LG (GoldStar) HDR WQHD serial: <filter> built: 2020 res: N/A dpi: 109
gamma: 1.2 size: 800x335mm (31.5x13.19") diag: 867mm (34.1") modes:
max: 3440x1440 min: 640x480
Monitor-2: eDP-1 pos: primary model: TL140BDXP01-0 built: 2020
res: 1664x936 hz: 120 dpi: 136 gamma: 1.2 size: 310x174mm (12.2x6.85")
diag: 355mm (14") ratio: 16:9 modes: 2560x1440
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.1-zen2-1-zen) direct-render: Yes
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.4.1-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
IF-ID-1: br-08e1e3e2cbbe state: down mac: <filter>
IF-ID-2: br-7b04b53e24a5 state: down mac: <filter>
IF-ID-3: br-e5c601d526a8 state: down mac: <filter>
IF-ID-4: br-f1969c90fbd9 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: docker0 state: down mac: <filter>
IF-ID-6: veth38c9da4 state: up speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:4 chip-ID: 8087:0029
Local Storage: total: 953.87 GiB used: 746.5 GiB (78.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 52.9 C
ID-1: / raw-size: 322 GiB size: 322 GiB (100.00%) used: 265 GiB (82.3%)
used: 41.9 MiB (8.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 503.37 GiB size: 503.37 GiB (100.00%)
used: 481.46 GiB (95.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 322 GiB size: 322 GiB (100.00%)
used: 265 GiB (82.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 322 GiB size: 322 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.03 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 71.5 C mobo: N/A gpu: amdgpu temp: 65.0 C
Fan Speeds (RPM): cpu: 3300
Processes: 478 Uptime: 5m wakeups: 2 Memory: available: 15.03 GiB
used: 3.13 GiB (20.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 2646 pm: dpkg
pkgs: 0 pm: pacman pkgs: 2618 libs: 557 tools: octopi,paru pm: flatpak
pkgs: 10 pm: snap pkgs: 18 Shell: fish v: 3.6.1 running-in: tmux:
inxi: 3.3.27
System install date: 2022-01-06
Last full system update: 2023-07-07
I apriciate that you made the effort to configure chromium but its not working out for me since the update. Netflix is not working because of some DRM issues or something else and all my configurations are gone. I reverted in my snapshots and the config that causes the issues seems to be somewhere in my home directory but I have no idea where. Because I have snapshots of both my home and root partition, everything works fine with the newest root and old home snapshot.
How can I roll back, or what files did you actually add?
