Resume from sleep issues
Hi everyone!
New Garuda Mokka user here. I am having trouble resuming my laptop from sleep. I tried many different potential fixes including:
  • s2idle kernel parameter
  • Disabling the dGPU
  • Changing kernels
  • NVPerserveVideo memory
The sleep issues are different on some occasions. Sometimes my computer freezes immediately as password prompt (however I can still hear the volume up/down sounds). Sometimes I can enter the password in and get to desktop, but the desktop freezes within a minute. Sometimes I can get to desktop, but the wallpaper turns black only windows that are open I can use.
I would appreciate any help! This is my first post so please let me know how I can properly seek help if I missed any best practices. Thank you all!
Kernel: 6.14.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=fdc52a03-f6c8-44ce-a91f-6a910eefa2b0 rw rootflags=subvol=@
quiet loglevel=3 mt7921e.disable_aspm=y splash ibt=off
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: ASUSTeK product: ProArt P16 H7606WV_H7606WV v: 1.0
Mobo: ASUSTeK model: H7606WV v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: H7606WV.316
date: 02/11/2025
ID-1: BAT1 charge: 81.2 Wh (100.0%) condition: 81.2/89.8 Wh (90.4%)
volts: 17.3 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
ID-2: hidpp_battery_0 charge: 87% condition: N/A volts: 4.0 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
Info: model: AMD Ryzen AI 9 HX 370 w/ Radeon 890M bits: 64 type: MT MCP
arch: N/A level: v4 note: check family: 0x1A (26) model-id: 0x24 (36)
stepping: 0 microcode: 0xB20401B
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 960 KiB desc: d-12x48 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 24 MiB desc: 1x16 MiB, 1x8 MiB
Speed (MHz): avg: 605 min/max: 599/5157:3289 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 605 2: 605 3: 605
4: 605 5: 605 6: 605 7: 605 8: 605 9: 605 10: 605 11: 605 12: 605 13: 605
14: 605 15: 605 16: 605 17: 605 18: 605 19: 605 20: 605 21: 605 22: 605
23: 605 24: 605 bogomips: 95811
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s ports:
active: none empty: DP-9,HDMI-A-1 bus-ID: 65:00.0 chip-ID: 10de:28a0
Device-2: Advanced Micro Devices [AMD/ATI] Strix [Radeon 880M / 890M]
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-6,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5,
DP-7, DP-8, Writeback-1 bus-ID: 66:00.0 chip-ID: 1002:150e class-ID: 0380
temp: 41.0 C
Device-3: Shinetech ASUS FHD webcam driver: hid-sensor-hub,usbhid,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
chip-ID: 3277:0059 class-ID: fe01 serial: <filter>
gpu: amdgpu d-rect: 8960x3840 display-ID: 0
Monitor-1: DP-6 pos: primary,top-left model: Samsung C49RG9x
serial: <filter> built: 2018 res: mode: 5120x1440 hz: 120 scale: 114% (1.15)
to: 4452x1252 dpi: 82 gamma: 1.2 size: 1193x336mm (46.97x13.23")
diag: 1239mm (48.8") modes: max: 5120x1440 min: 720x400
Monitor-2: eDP-1 pos: bottom-r model: Samsung 0x415d built: 2021 res:
mode: 3840x2400 hz: 60 scale: 175% (1.75) to: 2194x1371 dpi: 284 gamma: 1.2
size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10 modes:
max: 3840x2400 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2
drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia surfaceless:
drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
gfx1150 LLVM 19.1.7 DRM 3.61 6.14.1-zen1-1-zen) device-ID: 1002:150e
API: Vulkan v: 1.4.309 layers: 6 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV GFX1150) driver: N/A device-ID: 1002:150e
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: N/A device-ID: 10de:28a0
Device-1: NVIDIA AD107 High Definition Audio vendor: ASUSTeK
bus-ID: 65:00.1 chip-ID: 10de:22be class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 66:00.1 chip-ID: 1002:1640 class-ID: 0403
driver: snd_acp_pci v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_rpl_pci_acp6x, snd_pci_ps,
bus-ID: 66:00.5 chip-ID: 1022:15e2 class-ID: 0480
lanes: 16 bus-ID: 66:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Schiit Audio Modi 3+ driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.4.2.1:27 chip-ID: 30be:1014
class-ID: 0102
Device-6: Antlion Audio Wireless Microphone
lanes: 1 mode: 1.1 bus-ID: 5-1.4.3:26 chip-ID: 2f96:0100 class-ID: 0300
API: ALSA v: k6.14.1-zen1-1-zen status: kernel-api tools: N/A
Device-1: MEDIATEK vendor: Foxconn driver: mt7925e v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 63:00.0 chip-ID: 14c3:7925
IF: wlp99s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1.4.5:10
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 0489:e11e
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 4.57 TiB used: 1.31 TiB (28.7%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung
model: SSD 990 EVO Plus 4TB size: 3.64 TiB block-size: physical: 512 B
fw-rev: 1B2QKXG7 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Micron
model: MTFDKBA1T0QFM-1BD1AABGB size: 953.87 GiB block-size: physical: 512 B
fw-rev: V3MA101 temp: 30.9 C scheme: GPT
used: 55.06 GiB (5.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 30.41 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Memory: total: 32 GiB note: est. available: 30.41 GiB used: 9.37 GiB (30.8%)
Processes: 622 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
image: 12.09 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 1869 libs: 435 tools: octopi,paru,yay
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date:     2025-04-06
Last full system update: 2025-04-08
Last boot journalctl
Apr 08 21:19:36 kded6[6726]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_66_00.6.HiFi__Mic3__source"
Apr 08 21:19:36 kded6[6726]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_66_00.6.HiFi__Speaker__sink"
Apr 08 21:19:36 kded6[6726]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Apr 08 21:19:36 kded6[6726]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Apr 08 21:19:36 plasmashell[6791]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_66_00.6.HiFi__Speaker__sink"
Apr 08 21:19:36 plasmashell[6791]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_66_00.6.HiFi__Mic3__source"
Apr 08 21:19:36 kded6[6726]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Apr 08 21:19:36 wpa_supplicant[1387]: wlp99s0: CTRL-EVENT-DSCP-POLICY clear_all
Apr 08 21:19:36 wpa_supplicant[1387]: nl80211: deinit ifname=wlp99s0 disabled_11b_rates=0
Apr 08 21:19:36 plasmashell[6791]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Apr 08 21:19:36 plasmashell[6791]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Apr 08 21:19:36 plasmashell[6791]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Apr 08 21:19:37 systemd[1]: nvidia-suspend.service: Deactivated successfully.
Apr 08 21:19:37 systemd[1]: Finished NVIDIA system suspend actions.
Apr 08 21:19:37 systemd[1]: Starting System Suspend...
Apr 08 21:19:37 systemd-sleep[9397]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0>
Apr 08 21:19:37 systemd-sleep[9397]: This is not recommended, and might result in unexpected behavior, particularly
Apr 08 21:19:37 systemd-sleep[9397]: in suspend-then-hibernate operations or setups with encrypted home directories.
Apr 08 21:19:37 systemd-sleep[9397]: Performing sleep operation 'suspend'...
Apr 08 21:19:37 kernel: PM: suspend entry (s2idle)
About sometimes, sometimes it works?
Try X11 from login page, check BIOS updates.
There are missing chars after SESSIONS=0>
Did you use encryption?
Did you reboot from Win?
Always shutdown Win. Cold boot to Linux.
I tried the following with little to no change:
  • Changed to X11 from login page
  • Updated to latest BIOS already
  • Not using encryption
  • Went into Windows and shut it down fully
  • Set SYSTEMD_SLEEP_FREEZE_USER_SESSIONS= to true and false
I think something weird is going on with the nvme storage where Garuda is installed. This last boot I got it to to wake from sleep with a terminal open and I ran journalctl and there was a bunch of BTRFS and nvme errors on the boot drive. However, when I restarted after it froze, none of the messages were there anymore with the last few messages saying:
Apr 08 23:46:10 systemd[1]: nvidia-suspend.service: Deactivated successfully.
Apr 08 23:46:10 systemd[1]: Finished NVIDIA system suspend actions.
Apr 08 23:46:10 systemd[1]: nvidia-suspend.service: Consumed 1.049s CPU time, 19.9M memory peak.
Apr 08 23:46:10 systemd[1]: Starting System Suspend...
Apr 08 23:46:10 systemd[1]: session-1.scope: Unit now frozen-by-parent.
Apr 08 23:46:10 systemd[1]: user@1000.service: Unit now frozen-by-parent.
Apr 08 23:46:10 systemd[1]: user.slice: Unit now frozen.
Apr 08 23:46:10 systemd[1]: user-1000.slice: Unit now frozen-by-parent.
Apr 08 23:46:10 systemd-sleep[8714]: Successfully froze unit 'user.slice'.
Apr 08 23:46:10 systemd-sleep[8714]: Performing sleep operation 'suspend'...
Apr 08 23:46:10 kernel: PM: suspend entry (s2idle)
Thank you so much for helping me with this! I really want to daily drive this distro and I just need to get this sleep issue fixed.
Are there any setting options for S2idle etc. in the BIOS?
What are the settings in the system settings?
Did you try and check about
sudo nvidia-settings
Is WOL, wake on (W)LAN in use?
What are the default settings there?
Maybe this will help you
I can’t really help, my computer never sleeps :wink:
The never-ending story of nvidia and sleep/suspend/hibernate. :slightly_smiling_face:
There are several topics about it in the Arch forum and here in the forum, have you ever searched for it?
You should also take a look here: System does not return from suspend - ArchWiki
Check if the required services are running: Necessary services PVM after suspend - ArchWiki
When you reboot, a new journal is created. In this case you have to call the journal from the previous boot, for example:
journalctl -b -0               #current boot
journalctl -b -1               #previous boot
journalctl -b -2               #second previous boot
journalctl --list-boots        #list of boots with their numbers/date
And if there are really relevant nvme/btrfs errors, we can only find out if corresponding error messages are posted.
Its actually a bigger issue now then ever as its affecting windows as well people with non 50 cards are told to use the December driver an 50 users are kinda sol. At least currently nvidia drivers are broken on both windows an linux.
It brings to question though if the wayland issues are really wayland. Since multi monitor is also broken in new nvidia drivers.
Nvidia drivers are always broken, regardless of the platform. :sweat_smile:
Thank you all so much for your help and input :folded_hands:
So, I tried several potential fixes to no avail, including most of what was mentioned previously. Here is a list:
  • Switch nvme slots
  • Changed the wifi card out
  • Tried nvidia-open-dkms instead of nvidia-dkms drivers
  • Tried deep and shallow sleep modes
  • Disabling the lock screen after sleep
  • Trying to hibernate instead of suspend
@nepti, I have went through those links previously, and I have those services running and parameters set for the nvidia configurations. Also, the journalctl logs for previous boots weren’t there when I had those nvme errors.
I am going to try and reinstall the nvidia-dkms drivers with the official linux kernel as mentioned in a previous thread: Issues with nvidia! Like not waking-up after suspending, or other issues with current version of nvidia's drivers? - #5 by TNE
Thanks again everyone. I might have to succumb to shutting down the computer and not having sleep… :unamused_face:
One reason I think it might be some kind of nvme/storage related issue is because sometimes I can get back to desktop and video seems to be working. This last suspend I had a browser open and I could interact with the browser fine. But, there was no wallpaper or bottom task bar icons, and as soon as I opened a terminal with CTRL + ALT + T the computer black screened.
Btw, reverting to nvidia-dkms and linux kernel did not change anything.
Most recent journalctl:
Apr 09 11:57:33 plasmashell[1984]: org.kde.pulseaudio: No object for name "auto_null"
Apr 09 11:57:33 plasmashell[1984]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Apr 09 11:57:34 systemd[1]: nvidia-suspend.service: Deactivated successfully.
Apr 09 11:57:34 systemd[1]: Finished NVIDIA system suspend actions.
Apr 09 11:57:34 systemd[1]: Starting System Suspend...
Apr 09 11:57:34 systemd[1]: user@1000.service: Unit now frozen-by-parent.
Apr 09 11:57:34 systemd[1]: user-1000.slice: Unit now frozen-by-parent.
Apr 09 11:57:34 systemd[1]: session-1.scope: Unit now frozen-by-parent.
Apr 09 11:57:34 systemd[1]: user.slice: Unit now frozen.
Apr 09 11:57:34 systemd-sleep[3889]: Successfully froze unit 'user.slice'.
Apr 09 11:57:34 systemd-sleep[3889]: Performing sleep operation 'suspend'...
Apr 09 11:57:34 kernel: PM: suspend entry (s2idle)
