Restore snapshot on non-booting system without grub
Hi.
After two years of Garuda Linux I am compelled to ask for help.
Situation:
in order to use luks2 with fido2 key I took the system to dracut and systemd-boot because I couldn’t get grub to work.
This situation precludes me from using grub to restore snapshots. When I have problems that don’t block my boot I use the snapper but when the system no longer boots I am forced to start with an Arch installation system and restore the snapshot with commands.
With yesterday’s update, for the third time in two years, the system did not restart and no matter how hard I tried I could not find the right sequence of commands to give to do this cleanly without breaking the snapper system.
Is there any documentation specific to Garuda Linux that describes it?
Open the filesystem with cryptsetup should I mount without parameters or with subvol=@?
Once the filesystem is mounted what is the right sequence of commands to restore the snapshot, of which I know the id-nr, respecting the Garuda Linux structure?
Sorry for bad translated english.
Thanking anyone who wants to help me follow all the information about my system.
  Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
    avail: acpi_pm parameters: quiet splash rd.luks.uuid=11f74b06-8541-4ae9-93d5-ac3725dc9f4f
    rd.luks.options=fido2-device=auto root=UUID=951d92e7-bef1-4c4f-b10e-119308ef135a
    rootflags=subvol=@ rootfstype=btrfs nvidia_drm.modeset=1
  Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0 wm: kwin_wayland
    with: krunner vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Laptop System: Dell product: XPS 17 9700 v: N/A serial: <superuser required> Chassis:
    type: 10 serial: <superuser required>
  Mobo: Dell model: 05JJ5P v: A03 serial: <superuser required> part-nu: 098F
    uuid: <superuser required> UEFI: Dell v: 1.28.0 date: 12/18/2023
  ID-1: BAT0 charge: 48.5 Wh (83.8%) condition: 57.9/95.1 Wh (60.9%) volts: 11.9 min: 11.4
    model: SMP DELL 01RR3YM type: Li-poly serial: <filter> status: not charging
  Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake gen: core 10 level: v3
    note: check built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
    microcode: 0xFA
    desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 high: 802 min/max: 800/5000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 801 3: 800 4: 800 5: 800 6: 800 7: 800 8: 802 9: 800 10: 800
    11: 800 12: 800 bogomips: 62399
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915 v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0
    chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Dell driver: N/A
    alternate: nouveau, nvidia_drm, nvidia non-free: 545.xx+ status: current (as of 2024-02;
    EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0302
  Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 0bda:5510 class-ID: fe01 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4 compositor: kwin_wayland
    driver: X: loaded: intel unloaded: modesetting alternate: fbdev,vesa dri: i965 gpu: i915
    display-ID: 0
  Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
    drv: iris surfaceless: drv: iris wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.3-arch1.2 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2) device-ID: 8086:9bc4
    memory: 60.96 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel UHD Graphics (CML
    GT2) driver: mesa intel v: 24.0.3-arch1.2 device-ID: 8086:9bc4 surfaces: xcb,xlib,wayland
    device: 1 type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
    v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
  Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: sof-audio-pci-intel-cnl
    alternate: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8
    class-ID: 0401
  API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band Wi-Fi 6 Killer AX1650s
    160MHz 2x2 driver: iwlwifi v: kernel bu
s-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
    mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0026 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status:
    discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 5.46 TiB used: 1020.74 GiB (18.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P3PSSD8 size: 1.82 TiB
    fw-rev: P9CR40A temp: 30.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:12 vendor: Crucial model: CT4000P3PSSD8 size: 3.64 TiB
    fw-rev: P9CR40A temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 127.98 GiB size: 127.98 GiB (100.00%) used: 52.06 GiB (40.7%) fs: btrfs
    dev: /dev/dm-0 maj-min: 254:0 mapped: luks-11f74b06-8541-4ae9-93d5-ac3725dc9f4f
  ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 1000.5 MiB (48.9%) fs: vfat
  ID-3: /home raw-size: 127.98 GiB size: 127.98 GiB (100.00%) used: 52.06 GiB (40.7%) fs: btrfs
  ID-4: /var/log raw-size: 127.98 GiB size: 127.98 GiB (100.00%) used: 52.06 GiB (40.7%)
    fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-11f74b06-8541-4ae9-93d5-ac3725dc9f4f
  ID-5: /var/tmp raw-size: 127.98 GiB size: 127.98 GiB (100.00%) used: 52.06 GiB (40.7%)
  ID-1: swap-1 type: zram size: 62.42 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
  System Temperatures: cpu: 49.0 C pch: 65.0 C mobo: 44.0 C sodimm: SODIMM C
  Fan Speeds (rpm): cpu: 2501 fan-2: 2498
  Memory: total: 64 GiB note: est. available: 62.43 GiB used: 8.28 GiB (13.3%)
  Processes: 366 Power: uptime: 1h 37m states: freeze,mem,disk suspend: s2idle avail: deep
    wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 24.89 GiB
    services: org_kde_powerdevil,upowerd Init: systemd v: 255 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 2209 libs: 493 tools: octopi,pamac,paru Compilers: clang: 17.0.6
    gcc: 13.2.1 Client: shell wrapper v: 5.2.26-release inxi: 3.3.33
Garuda (2.6.23-1):
  System install date:     2023-04-04
  Last full system update: 2024-03-22
  Is partially upgraded:   Yes
  Relevant software:       snapper tlp NetworkManager dracut nvidia-dkms
mar 24 14:56:21 xps-toni systemd[1]: dbus.socket: Socket service dbus.service not loaded, refusing.
mar 24 14:56:21 xps-toni systemd[1]: Failed to listen on D-Bus System Message Bus Socket.
mar 24 14:56:23 xps-toni systemd[1]: dbus.socket: Socket service dbus.service not loaded, refusing.
mar 24 14:56:23 xps-toni systemd[1]: Failed to listen on D-Bus System Message Bus Socket.
mar 24 14:56:23 xps-toni kernel: Bluetooth: hci0: FW download error recovery failed (-19)
mar 24 14:56:23 xps-toni kernel: Bluetooth: hci0: sending frame failed (-19)
mar 24 14:56:23 xps-toni kernel: Bluetooth: hci0: Reading supported features failed (-19)
mar 24 14:56:23 xps-toni kernel: Bluetooth: hci0: Failed to read MSFT supported features (-19)
mar 24 14:56:25 xps-toni kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
mar 24 14:56:26 xps-toni kernel: Failed to get private value: 752001 => 0000 ret=-5
mar 24 14:56:28 xps-toni kernel: ucsi_acpi USBC000:00: unknown error 0
mar 24 14:56:28 xps-toni kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
mar 24 14:56:29 xps-toni bluetoothd[1501]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
mar 24 14:56:29 xps-toni bluetoothd[1501]: Failed to clear UUIDs: Failed (0x03)
mar 24 14:56:29 xps-toni bluetoothd[1501]: Failed to add UUID: Failed (0x03)
mar 24 14:56:32 xps-toni systemd[1859]: Failed to start Portal service (GTK/GNOME implementation).
mar 24 14:56:39 xps-toni systemd[2466]: Failed to start BTRFS Assistant Snapper check.
mar 24 14:56:39 xps-toni optimus-manager-qt[3235]: Unable to read current mode from Optimus Manager state file
mar 24 14:56:40 xps-toni systemd-coredump[3299]: Process 3235 (optimus-manager) of user 1000 dumped core.
                                                 Stack trace of thread 3235:
                                                 #0  0x0000797b170ab32c n/a (libc.so.6 + 0x8d32c)
                                                 #1  0x0000797b1705a6c8 raise (libc.so.6 + 0x3c6c8)
                                                 #2  0x0000797b170424b8 abort (libc.so.6 + 0x244b8)
                                                 #3  0x0000797b176980c2 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x980c2)
                                                 #4  0x00005ba56b9728b9 n/a (optimus-manager-qt + 0xc8b9)
                                                 #5  0x00005ba56b97a1ff n/a (optimus-manager-qt + 0x141ff)
                                                 #6  0x00005ba56b975f9e n/a (optimus-manager-qt + 0xff9e)
                                                 #7  0x0000797b170
43cd0 n/a (libc.so.6 + 0x25cd0)
                                                 #8  0x0000797b17043d8a __libc_start_main (libc.so.6 + 0x25d8a)
                                                 #9  0x00005ba56b976de5 n/a (optimus-manager-qt + 0x10de5)
                                                 Stack trace of thread 3288:
                                                 #0  0x0000797b171190bf __poll (libc.so.6 + 0xfb0bf)
                                                 #1  0x0000797b1292305d n/a (libQt5WaylandClient.so.5 + 0x6905d)
                                                 #2  0x0000797b176eb86a n/a (libQt5Core.so.5 + 0xeb86a)
                                                 #3  0x0000797b170a955a n/a (libc.so.6 + 0x8b55a)
                                                 #4  0x0000797b17126a3c n/a (libc.so.6 + 0x108a3c)
                                                 Stack trace of thread 3271:
                                                 #1  0x0000797b1617f2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                 #2  0x0000797b1611f162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                 #3  0x0000797b178e329c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2e329c)
                                                 #4  0x0000797b17893194 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x293194)
                                                 #5  0x0000797b176ef646 _ZN7QThread4execEv (libQt5Core.so.5 + 0xef646)
                                                 #6  0x0000797b18cdfa9a n/a (libQt5DBus.so.5 + 0x17a9a)
                                                 #7  0x0000797b176eb86a n/a (libQt5Core.so.5 + 0xeb86a)
                                                 #8  0x0000797b170a955a n/a (libc.so.6 + 0x8b55a)
                                                 #9  0x0000797b17126a3c n/a (libc.so.6 + 0x108a3c)
                                                 Stack trace of thread 3287:
                                                 #0  0x0000797b170a5ebe n/a (libc.so.6 + 0x87ebe)
                                                 #1  0x0000797b170a8750 pthread_cond_wait (libc.so.6 + 0x8a750)
                                                 #2  0x0000797b176f35f4 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xf35f4)
                                                 #3  0x0000797b12923004 n/a (libQt5WaylandClient.so.5 + 0x69004)
                                                 #4  0x0000797b176eb86a n/a (libQt5Core.so.5 + 0xeb86a)
                                                 #5  0x0000797b170a955a n/a (libc.so.6 + 0x8b55a)
                                                 #6  0x0000797b17126a3c n/a (libc.so.6 + 0x108a3c)
                                                 ELF object binary architecture: AMD x86-64
mar 24 14:56:40 xps-toni backintime[3253]: Profilo principale(1) :: ERROR: Back In Time is not configured!
mar 24 14:56:40 xps-toni plasmashell[3058]: aurorae: Couldn't find QML Decoration  ""
mar 24 14:56:46 xps-toni sudo[3847]:     toni : a password is required ; TTY=pts/0 ; PWD=/home/toni ; USER=root ; COMMAND=/usr/bin/true
mar 24 15:10:50 xps-toni sudo[6985]:     toni : a password is required ; TTY=pts/0 ; PWD=/home/toni ; USER=root ; COMMAND=/usr/bin/true
mar 24 15:19:10 xps-toni sudo[8419]:     toni : a password is required ; TTY=pts/0 ; PWD=/home/toni ; USER=root ; COMMAND=/usr/bin/true
mar 24 15:28:04 xps-toni sudo[8955]:     toni : a password is required ; TTY=pts/1 ; PWD=/home/toni ; USER=root ; COMMAND=/usr/bin/true
mar 24 15:37:05 xps-toni kernel: ACPI Error: Thread 886833152 cannot release Mutex [ECMX] acquired by thread 2169976512 (20230628/exmutex-378)
mar 24 15:37:05 xps-toni kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20230628/psparse-529)
If you know the subvolume name of snapshot you wanna roll back to and you can edit the kernel command line params at boot up time. Like in grub when you press ‘e’ it gives you a minimal emacs editor to change kernel command line params temporarily then yes you can restore your system without needing grub.
Example, a
sudo btrfs subvolume list /
Shows that I have
.snapshots/94/snapshot
Subvolume this is basically snapshot number 94. Say I wanna restore this. While booting up I will edit the kernel command line params. And,
change the vmlinuz path, root subvol, microcode and initrd path
From,
linux "/@/boot/vmlinuz-linux-... root=UUID=... <some command line params for kernel> rootflags=...,subvol="@"
initrd "/@/boot/intel-ucode.img" "/@/boot/initramfs-linux....img"
To,
linux "/@/.snapshots/94/snapshot/boot/vmlinuz-linux-... root=UUID=... <some command line params for kernel> rootflags=...,subvol="@/.snapshots/94/snapshot"
initrd "/@/.snapshots/94/snapshot/boot/intel-ucode.img" "/@/.snapshots/94/snapshot/boot/initramfs-linux....img"
This is what a grub menuentry looks like not sure what systemd equivalent of this might look like but I am sure you get the general idea. I have changed root subvol to snapshot subvol. This will boot my system into the snapshot.
Then I will launch snapper and it automatically detects I have booted into a snapshot and offers to restore it for me. I click yes and then reboot normally into my actual system this time.
The only blocker here is knowing the snapshot subvol name before hand. Otherwise you would have to chroot into your system to know it.
Or you can chainload grub using systemd-boot as well. So normally you use systemd-boot to boot into your system and for instances like this you boot into grub from systemd-boot and use grub-btrfs created entries to boot into snapshots.
hi
Thank you for the very quick response.
I will try the solutions you provided and if I solve I will point to your answer as the solution.
I took a look at the grub concatenation to systemd-boot but I don’t think it can work because the grub is not able to open the encrypted volume.
Thanks again
etazeta
