New User Here
The Option To Change Resolution Is Capped At 800x600
And I Think Its Not A Driver Problem Because Its Showing Name Of GPU In Neofetch
here are the images
and it would be better if i can unlock 100 hz too
Monitor - MSI PRO MP 251
CPU - i7 4790s
GPU - Nvidia GT 730
RAM - 16GB
Welcome to the Forum
Please can you provide your
As per the forum template
Kernel: 6.10.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b73f2d8d-22b7-402b-be8b-da86adf5baf0 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop Mobo: INTEL model: H81 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 4.6.5
date: 09/19/2022
Info: model: Intel Core i7-4790S bits: 64 type: MT MCP arch: Haswell
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2909 high: 4000 min/max: 800/4000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3193 2: 4000 3: 3193
4: 4000 5: 3193 6: 900 7: 1600 8: 3193 bogomips: 51085
Device-1: NVIDIA GF108 [GeForce GT 730] driver: N/A alternate: nouveau,
nvidia_drm, nvidia non-free: series: 390.xx+
status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:0f02 class-ID: 0300
alternate: fbdev,nv,vesa gpu: N/A display-ID: 0
Monitor-1: Unknown-1 res: 800x600 size: N/A modes: N/A
API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless:
drv: swrast wayland: drv: swrast x11: drv: swrast inactive: gbm
API: OpenGL v: 4.5 vendor: mesa v: 24.2.1-arch1.1 note: incomplete
(EGL sourced) renderer: llvmpipe (LLVM 18.1.8 256 bits)
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.1-arch1.1 (LLVM
18.1.8) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
API: ALSA v: k6.10.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: TP-Link UB5A Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:2 chip-ID: 2357:0604
Local Storage: total: 593 GiB used: 14.01 GiB (2.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: EVM model: NV 512GB
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: V1013A0
temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: General USB Flash Disk
size: 116.06 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD
serial: <filter> fw-rev: 3.00 scheme: MBR
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 13.99 GiB (23.3%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 27 MiB (28.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 60 GiB size: 60 GiB (100.00%)
used: 13.99 GiB (23.3%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
zswap: no
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 47.0 C mobo: N/A
Memory: total: 16 GiB available: 15.57 GiB used: 3.67 GiB (23.6%)
Processes: 241 Power: uptime: 44m states: freeze,mem,disk
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1319 libs: 376 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date: 2024-09-02
Last full system update: 2024-09-02 ↻
Failed units
filo
2 September 2024 17:38
4
Just in case, this means that a reboot is pending after the latest update. Especially considering that
No driver is currently loaded for your GPU.
Try also selecting an x11 session instead of wayland in the login screen.
Still Capped in x11
Tried Both The Option Still Resolution Capped At 800x600
I dont know how to load gpu driver but i tried switching to both x11 and wayland.
filo
2 September 2024 17:57
9
Try with Garuda settings manager → HW configuration
There should be a button to autoinstall proprietary drivers. I’m not sure it will work because your GPU is not supported anymore.
Did what you said and it installed but still resolution is capped and i restared after installing drivers too
filo
2 September 2024 18:07
12
Could you please provide again your garuda-inxi?
sure
date: 09/19/2022
Speed (MHz): avg: 799 high: 800 min/max: 800/4000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 798 bogomips: 51082
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 800x600 s-dpi: 96 s-size: 211x158mm (8.31x6.22")
s-diag: 264mm (10.38")
Monitor-1: Unknown-1 mapped: None-1 res: 800x600 hz: 60 size: N/A
modes: 800x600
drv: swrast x11: drv: swrast inactive: gbm,wayland
API: OpenGL v: 4.5 vendor: mesa v: 24.2.1-arch1.1 note: incomplete (EGL
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
Local Storage: total: 593 GiB used: 14.08 GiB (2.4%)
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 14.05 GiB (23.4%)
used: 14.05 GiB (23.4%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
zswap: no
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A
Memory: total: 16 GiB available: 15.57 GiB used: 3.14 GiB (20.2%)
Processes: 246 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
inxi: 3.3.35
filo
2 September 2024 18:16
14
Still N/A I see. Was an error reported?
Anyway, try
sudo pacman -S nvidia-390xx-dkms nvidia-390xx-utils
from terminal.
[sudo] password for phantom:
resolving dependencies...
:: nvidia-390xx-utils-390.157-12 and nvidia-utils-560.35.03-2 are in conflict (nvidia-libgl). Remove nvidia-utils? [y/N]
filo
2 September 2024 18:20
18
Try Yes, but I’m afraid we’ll get into a nightmare of conflicts. We’ll need an Nvidia user, which I’ve never been
dalto
2 September 2024 18:44
21
Is there a reason you created a second account?
gt 730 sounds kind of dubious.
It seems to me like the display is not being properly detected, have you tried another cable or another port?
2 things stand out, not using Nouveau , and connecting at gen1 speed instead of gen2. Did you install with proprietary drivers and they failed? Make sure the GPU is properly seated in the slot closest to the CPU. Do you have any difference when booting LTS kernel?
system
Closed
24 September 2024 20:33
32
