Hey there!
I've heard about some changes in new garuda editions, specifically new default fonts in Konsole (kde Dragonized edition).
There are many buttons to reset different configs in garuda-assistant, including, for example, alacritty terminal, but I haven't found Konsole reset setting there.
So, my question is, how to reset konsole setting to garuda defaults? The follow-up question is: can it even be added to garuda-assistant?
Thx!
Kernel: 5.18.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=d4f24890-497a-4b6f-bb80-b3374410998b rw rootflags=subvol=@
resume=UUID=97fa3e3b-b2f7-493c-94c8-2f34455cf554 loglevel=3
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: Gigabyte model: B550 AORUS PRO AX
serial: <superuser required> UEFI: American Megatrends LLC. v: F16a
date: 02/16/2022
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3058 high: 3342 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3149 2: 3342
3: 2992 4: 2993 5: 2997 6: 2993 7: 3265 8: 3007 9: 2990 10: 2994 11: 2990
12: 2992 bogomips: 93418
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Gigabyte driver: amdgpu v: kernel
arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
active: HDMI-A-1 empty: none bus-ID: 06:00.0 chip-ID: 1002:1638
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Idek Iiyama PL2492H
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.46 5.18.9-zen1-1-zen)
v: 4.6 Mesa 22.1.3 direct render: Yes
speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
Sound Server-1: ALSA v: k5.18.9-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.53 running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-5:8 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 931.51 GiB used: 615.97 GiB (66.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
temp: 28.9 C scheme: GPT
ID-1: / raw-size: 914.67 GiB size: 914.67 GiB (100.00%)
used: 615.97 GiB (67.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 914.67 GiB size: 914.67 GiB (100.00%)
ID-4: /var/log raw-size: 914.67 GiB size: 914.67 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.67 GiB size: 914.67 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.98 GiB used: 807.5 MiB (5.3%)
ID-2: swap-2 type: partition size: 16.54 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 26.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0 fan-3: 584
Power: 12v: N/A 5v: N/A 3.3v: 1.69 vbat: 1.59
Processes: 347 Uptime: 14h 10m wakeups: 0 Memory: 14.98 GiB
used: 4.69 GiB (31.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 2319
lib: 582 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
e[1;34mGaruda (2.6.4-2):e[0m
e[1;34m System install date:e[0m 2021-11-16
e[1;34m Last full system update:e[0m 2022-07-07
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m nmb.service
