Reset kde plasma to default
  Kernel: 5.18.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e46fe81f-7dfd-4f6a-a9fb-9cf9d645f98a
    rw [email protected] quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
    resume=UUID=e912bbf4-d5e0-42e1-9d5e-5f0b144b76b4 loglevel=3
  Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 3 dm: SDDM
  Type: Laptop System: HP product: OMEN by HP Laptop 16-c0xxx v: N/A serial: <superuser required>
    Chassis: type: 10 serial: <superuser required>
  Mobo: HP model: 8902 v: 89.55 serial: <superuser required> UEFI: AMI v: F.14 date: 02/11/2022
  ID-1: BAT0 charge: 70.0 Wh (99.9%) condition: 70.1/70.1 Wh (100.0%) volts: 17.2 min: 15.4
    model: HP Primary type: Li-ion serial: <filter> status: N/A cycles: 4
  Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 4
    built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
    microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3629 high: 4400 min/max: 1200/4462 boost: enabled scaling:
    driver: acpi-cpufreq governor: performance cores: 1: 3706 2: 3525 3: 3529 4: 3533 5: 3527
    6: 3540 7: 3526 8: 3644 9: 3243 10: 4400 11: 3608 12: 3530 13: 3524 14: 3502 15: 4144 16: 3587
    bogomips: 102208
    mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Hewlett-Packard driver: amdgpu
    v: kernel arch: RDNA 2 process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none off: DP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73ff
    class-ID: 0380
  Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN 5.1
    process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: eDP-1 empty: DP-2 bus-ID: 09:00.0 chip-ID: 1002:1638
  Device-3: Luxvisions Innotech HP Wide Vision HD Camera type: USB driver: uvcvideo
    bus-ID: 1-3:3 chip-ID: 30c9:000e class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2 compositor: kwin_wayland
    driver: X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu,amdgpu
    display-ID: 0
  Monitor-1: eDP-1 res: 2560x1440 size: N/A modes: N/A
  OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.46 5.18.10-zen1-1-zen) v: 4.6 Mesa 22.1.3
    direct render: Yes
  Device-1: AMD Navi 21/23 HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel
    bus-ID: 3-1.3:5 v: kernel pcie: chip-ID: 0763:410b gen: 4 class-ID: fe01 speed: 16 GT/s
    lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-2: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
    alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID
: 09:00.5
  Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6
  Device-5: M-Audio AIR 192 4 type: USB driver: snd-usb-audio
  Sound Server-1: ALSA v: k5.18.10-zen1-1-zen running: yes
  Sound Server-4: PipeWire v: 0.3.54 running: yes
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
  Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter vendor: Hewlett-Packard
    driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
    chip-ID: 10ec:8852 class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
    chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
  Local Storage: total: 1.84 TiB used: 179.09 GiB (9.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB
    rev: 2B2QEXM7 temp: 37.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: MZVLB1T0HBLR-000H1 size: 953.87 GiB
    rev: HPS0NEXF temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 179.09 GiB (19.6%) fs: btrfs
    dev: /dev/nvme0n1p2 maj-min: 259:3
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 580 KiB (0.2%) fs: vfat
    dev: /dev/nvme0n1p1 maj-min: 259:2
  ID-3: /home raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 179.09 GiB (19.6%) fs: btrfs
  ID-4: /var/log raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 179.09 GiB (19.6%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
  ID-5: /var/tmp raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 179.09 GiB (19.6%)
  ID-1: swap-1 type: zram size: 14.98 GiB used: 103.8 MiB (0.7%) priority: 100 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 16.55 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3 maj-min: 259:4
  System Temperatures: cpu: N/A mobo: N/A
  Fan Speeds (RPM): cpu: 2401 fan-2: 2211
  GPU: device: amdgpu temp: 38.0 C device: amdgpu temp: 39.0 C mem: 40.0 C fan: 0 watts: 4.00
  Processes: 390 Uptime: 35m wakeups: 2 Memory: 14.98 GiB used: 5.24 GiB (35.0%) Init: systemd
  v: 251 default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages:
  pacman: 2387 lib: 577 Client: shell wrapper v: 5.1.16-release inxi: 3.3.19
Garuda (2.6.4.r1.g3842242-1):
  System install date:     2022-04-07
  Last full system update: 2022-07-10
  Is partially upgraded:   Yes
Hello,
after all this updates , kde-plasma seems to be clunky. Some Windows have not titel bar with buttons, Windows placement is not correct etc.
In the past, I had reset kde-plasma to default, where I delete all files in .kde/share/config/plasma*. But this files not exist in this distrubution.
Which files I need to delete, to reset kde-plasma to default?
I remove latte, because i don't like it.
THX
The plasma config files are placed in ~/.config/*, some are also present in ~/.local/share/*.
