Hello.
Kernel: 5.16.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=dc8a04cb-d495-4e40-a32a-a245a37d9d9a rw [email protected]
Type: Laptop System: ASUSTeK product: ROG Strix G513QY_G513QY v: 1.0
Mobo: ASUSTeK model: G513QY v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G513QY.316 date: 11/29/2021
ID-1: BAT0 charge: 85.9 Wh (100.0%) condition: 85.9/90.0 Wh (95.4%)
volts: 17.1 min: 15.9 model: AS3GWYF3KC GA50358 type: Li-ion
serial: <filter> status: Full
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2269 high: 3723 min/max: 1200/4889 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2153 2: 2071
3: 1941 4: 1662 5: 2360 6: 2537 7: 1715 8: 3723 9: 1984 10: 2079 11: 2286
12: 1827 13: 2017 14: 3146 15: 2056 16: 2753 bogomips: 105400
IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] vendor: ASUSTeK
driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none empty: DP-1 bus-ID: 03:00.0 chip-ID: 1002:73df
class-ID: 0380
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:1638
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 300 dpi: 142
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.13-zen1-1-zen LLVM 13.0.1)
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.16.13-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 13.78 GiB (1.4%)
model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB block-size: physical: 512 B
rev: FXM7201Q temp: 32.9 C scheme: GPT
used: 13.78 GiB (1.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.1 GiB used: 4.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2100
GPU: device: amdgpu temp: 47.0 C mem: 46.0 C fan: 0 watts: 7.00
device: amdgpu temp: 57.0 C
Processes: 400 Uptime: 39m wakeups: 19 Memory: 15.1 GiB
used: 4.03 GiB (26.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1685 lib: 500 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-08
Last full system update: 2022-03-08
Failed units: nmb.service
How do you add google as an option to the FireDragon search engines? Ive looked on the Garuda linux forum, the wiki, and the github/gitlab pages for FireDragon but I haven't seen anyone talking about this yet.
