Removing / updating saved entries in ksshaskpass
Hello Garuda users,
I am having trouble using ksshaskpass. I tried to clone a private repo from Github which requires authentication. I mistakenly entered my password in the prompt that opened which was actually asking for my username. Now it seems that my password is forever set as my Github username and I was not able to find a way to delete / reset the entry.
The only relevant information I found was this SO post which describes my exact problem: github - Git asks a password for a wrong URL - Stack Overflow
which however provides no solution either.
I also found this: Reddit - Dive into anything however I would like to keep using ksshaskpass or a utility like it.
I found one more post: Ksshaskpass - delete remembered credentials - Help - NixOS Discourse. This seems to be a common problem with apparently no documented solution. I do not have kwalletmanager as described there.
  1. How can I edit / remove saved usernames in ksshaskpass? Running the program only opens a prompt where I can enter a password, which then simply prints this password on the terminal.
  2. Given all the linked posts, is there a better (more usable) alternative to ksshaskpass? I'm only using it because it was already installed.
Thank you for your time.
System information:
Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=72e0724c-168d-4e42-9fe9-92c648a94321 rw [email protected]
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1407
date: 04/02/2020
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4200 high: 4201 min/max: 2200/4910 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4200 2: 4200
3: 4200 4: 4200 5: 4200 6: 4200 7: 4200 8: 4201 9: 4200 10: 4200 11: 4200
12: 4200 13: 4200 14: 4200 15: 4200 16: 4200 bogomips: 134400
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 525.89.02
alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Ampere code: GAxxx
lanes: 16 bus-ID: 09:00.0 chip-ID: 10de:2488 class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 23.1.1
Screen-1: 0 s-res: 4480x1440 s-dpi: 108 s-size: 1054x342mm (41.50x13.46")
s-diag: 1108mm (43.63")
Monitor-1: DP-0 pos: primary,top-right res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: HDMI-0 pos: bottom-l res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.74x10.55") diag: 546mm (21.51") modes: N/A
API: OpenGL v: N/A renderer: N/A direct-render: N/A
Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2-2:2 pcie: chip-ID: 0d8c:0014
class-ID: 0300 gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid
API: ALSA v: k6.2.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
Local Storage: total: 3.67 TiB used: 10.86 GiB (0.3%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 211070WD temp: 41.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Patriot model: N/A
size: 28.9 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 505.58 GiB size: 505.58 GiB (100.00%)
used: 10.83 GiB (2.1%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
used: 25.6 MiB (26.7%) fs: vfat dev: /dev/nvme1n1p2 maj-min: 259:5
ID-3: /home raw-size: 505.58 GiB size: 505.58 GiB (100.00%)
ID-4: /var/log raw-size: 505.58 GiB size: 505.58 GiB (100.00%)
ID-5: /var/tmp raw-size: 505.58 GiB size: 505.58 GiB (100.00%)
System Temperatures: cpu: 47.5 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 374 Uptime: 47m wakeups: 0 Memory: 31.26 GiB
used: 4.33 GiB (13.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1200
libs: 308 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date:     2023-04-21
Last full system update: 2023-04-21 ↻
first i would reboot
secondly i would not worry to much as this is a fresh install, just reinstall :slight_smile:
Surely there must be a better way? :sweat_smile:
I'm dual booting with Windows which I am very surprised worked immediately given all the warnings I read.
I would also like to know in case this happens again, since the prompt was somewhat misleading and I could see myself doing the same mistake again (or simply wrongly entering my username?).
I finally found a solution.
kwalletmanager is required to edit passwords, but is not installed by default.
Installing this and then running it allowed me to delete the incorrect entry for Github.
