Removing nerd-fonts-fantasque-sans-mono breaks dependency 'nerd-fonts-fantasque-sans-mono' required by garuda-wayfire-settings
Hi.
Unable to run garuda-update successfully because of the above conflict, if I remove garuda-wayfire-settings with garuda-fish-config, then I can update, but after that I'm unable to reinstall these because of the same font conflict.
garuda-inxi:
  Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=7559cfe1-af71-4c09-b4d5-c1cc0b357e71 rw [email protected]
    splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
  Desktop: wayfire v: 0.7.4 info: waybar vt: 1 dm: greetd
  Type: Laptop System: LENOVO product: 20C0S0YE0A v: ThinkPad S1 Yoga
  Mobo: LENOVO model: 20C0S0YE0A v: SDK0E50510 Pro
    serial: <superuser required> UEFI: LENOVO v: B0ET47WW (1.34 )
    date: 03/24/2020
  ID-1: BAT0 charge: 32.7 Wh (78.0%) condition: 41.9/47.1 Wh (89.0%)
    volts: 15.6 min: 14.8 model: SONY 45N1705 type: Li-poly serial: <filter>
    status: not charging
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
  Info: model: Intel Core i5-4300U bits: 64 type: MT MCP arch: Haswell
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1241 high: 2571 min/max: 800/2900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 2571 3: 798
    4: 798 bogomips: 19954
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
    v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
    active: HDMI-A-2 off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:0a16 class-ID: 0300
  Device-2: Realtek Integrated Camera type: USB driver: uvcvideo
    bus-ID: 2-6:8 chip-ID: 0bda:5720 class-ID: 0e02 serial: <filter>
  Display: wayland server: Xwayland v: 22.1.7 compositor: wayfire v: 0.7.4
    driver: gpu: i915 display-ID: 1
  Monitor-1: HDMI-A-2 model: LG (GoldStar) 32LG3000 serial: <filter>
    built: 2008 res: 1360x768 hz: 60 dpi: 49 gamma: 1.2 scale: 1
    size: 700x390mm (27.56x15.35") diag: 802mm (31.6") ratio: 16:9 modes:
    max: 1360x768 min: 720x400
  Monitor-2: eDP-1 model: LG Display 0x0414 built: 2013 res: 1360x768
    dpi: 177 gamma: 1.2 size: 276x156mm (10.87x6.14") diag: 317mm (12.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel HD Graphics 4400 (HSW
    GT2) direct render: Yes
  Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
    bus-ID: 2-1:2 v: kernel chip-ID: 0d8c:0102 bus-ID: 00:03.0
    chip-ID: 8086:0a0c class-ID: 0300 class-ID: 0403
  Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
  Device-3: C-Media CM106 Like Sound Device type: USB
  Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
    speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:08b2 class-ID: 0280
    bus-ID: 2-4:9 chip-ID: 8087:07dc class-ID: e001
  Local Storage: total: 953.87 GiB used: 341.27 GiB (35.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Verbatim model: Vi550 S3
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 0A0 scheme: GPT
  ID-1: / raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
    used: 341.24 GiB (58.2%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
    used: 25.6 MiB (26.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
  ID-4: /var/log raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
  ID-5: /var/tmp raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.65 GiB used: 545 MiB (7.0%) priority: 100
  System Temperatures: cpu: 62.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Processes: 272 Uptime: 1h 31m wakeups: 20 Memory: 7.65 GiB
  used: 4.35 GiB (56.8%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1952
  pm: pacman pkgs: 1924 libs: 513 tools: gnome-software,octopi,pamac,paru
  pm: flatpak pkgs: 28 Shell: fish v: 3.5.1 default: Bash v: 5.1.16
  running-in: alacritty inxi: 3.3.24
Garuda (2.6.12-1):
  System install date:     2022-05-10
  Last full system update: 2022-12-29
  Is partially upgraded:   Yes
  Failed units:            shadow.service systemd-networkd-wait-online.service
sudo pacman -Rdd nerd-fonts-fantasque-sans-mono && sudo pacman -S ttf-fantasque-nerd
solved the problem, but I didn't find what double d means in pacman info, one d is to bypass dependencies, but double?
From the Pacman man page (I have emboldened the last sentence):
-d, --nodeps
Skips dependency version checks. Package names are still checked. Normally, pacman will always check a package’s dependency fields to ensure that all dependencies are installed and there are no package conflicts in the system. Specify this option twice to skip all dependency checks.
From the ArchWiki
To remove a package, which is required by another package, without removing the dependent package:
Warning: The following operation can break a system and should be avoided. See System maintenance#Avoid certain pacman commands.
# pacman -Rdd *package_name*
Thank you. Do you know about some intent to solve this dependency race on fonts with Wayfire? We should avoid to break the system with such operations....
Yes, I believe SGS just submitted a commit to fix this issue: Update file PKGBUILD (8d9b6bf6) · Commits · Garuda Linux / Themes and Settings / Settings / garuda-wayfire-settings · GitLab
Thank you for bringing the issue forward. :+1:
Another issue we noticed is with the stock install of Wayfire the font in Alacritty is kind of broken looking. You can fix this by changing the font in .config/alacritty/alacritty.yml from FiraCode Nerd Font Mono to something else--or just comment out or delete the whole font section and it will default to the Alacritty font which is not broken.
Ok, I removed it. :slight_smile:
Thank you guys, keep up the good work, you're the top of distrohoppers :slight_smile:
