This may not be directly related to Garuda, and I have read the Arch wiki about removing LUKS, but I'm wondering if theres a quick and easy way to remove the disk encryption I chose when I setup Garuda? Or is the description on the wiki the best way?
Thanks in advance!
Edit....to be more specific, the Arch wiki says to use this command:
cryptsetup-reencrypt --decrypt <device_path>
Since this is an Arch based system i will this work on Garuda?
