Removing blur from kitty
kitty has a blur that is normally set in the conf file with background_blur 1 but thats not there and its a custom file by garuda so i checked the config they tossed in at the bottom line but didnt see it there either and adding background_blur 0 to the conf gets overridden…
i just dont know where the custom configs are that garuda is trying to use
Please, post garuda-inxi.
Where did you edit and which file, please write full names.
There will never be changed files by system in /home until you change it or use an app like garuda-assistant.
Did you save your changes?
And what you want to do?
Did you look also in .config/kitty/current-theme.conf
Edit.
IDK, new upstream bug?
I use kitty 0.36.2
BTW, in window manager I always use “full” windows, apart from this screenshot :smiley:
i checked out ~/.config/kitty/current-theme.conf and ~/.config/kitty/kitty.conf
in ~/.config/kitty/kitty.conf line 985 was set to 1 i changed it to 0.75 and noticed its blured and adding background_blur 0 did not help i also tried swapping to lts just in case it was a zen thing but no luck
and i mean you can drop line 985 to 0 its still blurry i feel so confused
edit: line 985 is background_transparancy
Shouldn’t you be looking at a compositor, say picom?
blur-background-exclude = [
  #"window_type = 'dock'",
  #"window_type = 'desktop'",
  #"class_g = 'URxvt'",
  "class_g = 'slop'",
  "class_g = 'i3status'",
  "_GTK_FRAME_EXTENTS@:c",
  "window_type = 'menu'",
  "window_type = 'tooltip'",
  "window_type = 'popup_menu'",
  "window_type = 'dropdown_menu'",
and probably add something here - to exclude kitty. Not 100 percent sure about Kitty
Maybe I don’t understand, do you want blur or not? :smiley:
Maybe look also in i3 config, I have no blur in my i3wm.
I can’t check it right now.
twas a picom thing! i just added
"class_g = 'kitty'",
to /home/$USER/.config/picom.conf
