hello,I recently switched from kde to cinnamon,I started to theme it,it all goes well until I started changing the Icons , when I set the icons to papirus, all the icons change except in garuda applications (garuda wellcome,garuda gamer,etc...) they stick with beautyline icons,is there any way that I can change the icons in garuda applications
Some of those applications are using embedded icons, not system icons.
kvantum shouldn't be doing that though. I am not that familiar with cinnamon. Perhaps there is a different way to set the icons that Qt applications use.
qt5ct and qt6ct have options for changing the icon themes. Make sure to set
QT_QPA_PLATFORMTHEME=1 in /etc/environment, then log out and back in.
