Removing 3 finger gesture
Hello,
I am trying to configure gestures on KDE dragonized. I am using libinput-gestures-qt to edit the conf file. I set a four finger swipe up to refresh the webpage, but something else is also responding to this gesture by showing me all my active windows. I wish to disable or delete whatever is causing this. KDE uses libinput, but the four finger response isn’t listed in the libinput-gestures.conf file. What is causing this?
Kernel: 6.7.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-linux-zen
root=UUID=ba36aca1-7437-429c-8dfc-db04d64233f7 rw rootflags=subvol=@
quiet rd.luks.uuid=09eab190-cdfe-41c7-9c52-13c4350ae0a7 loglevel=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Convertible System: LENOVO product: 82R7 v: IdeaPad Flex 5 14IAU7
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14IAU7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: J7CN44WW date: 05/24/2023
ID-1: BAT0 charge: 28.9 Wh (56.4%) condition: 51.2/52.5 Wh (97.5%)
power: 12.0 W volts: 11.5 min: 11.5 model: SMP L21M3PE0 type: Li-poly
serial: <filter> status: discharging cycles: 79
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x430
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 564 high: 2370 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: performance cores: 1: 2370 2: 400 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 59904
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a8 class-ID: 0300
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 5986:214d
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a8 memory: 14.83 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 16 device: 0 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: mesa intel v: 23.3.4-arch1.2
device-ID: 8086:46a8 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.4-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.7.2-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
IF-ID-1: surfshark_ipv6 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: surfshark_wg state: unknown speed: N/A duplex: N/A mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
Local Storage: total: 931.51 GiB used: 746.41 GiB (80.1%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 41.9 C
ID-1: / raw-size: 462.09 GiB size: 462.09 GiB (100.00%)
used: 76.9 GiB (16.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-09eab190-cdfe-41c7-9c52-13c4350ae0a7
ID-2: /boot raw-size: 1 GiB size: 1 GiB (100.00%) used: 198.2 MiB (19.4%)
ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 34.7 MiB (6.8%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /home raw-size: 462.09 GiB size: 462.09 GiB (100.00%)
ID-5: /var/log raw-size: 462.09 GiB size: 462.09 GiB (100.00%)
ID-6: /var/tmp raw-size: 462.09 GiB size: 462.09 GiB (100.00%)
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-2: swap-2 type: zram size: 15.19 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 366 Uptime: 1h 13m wakeups: 1 Memory: total: 16 GiB note: est.
available: 15.19 GiB used: 8.1 GiB (53.4%) Init: systemd v: 255
pm: pacman pkgs: 2013 libs: 578 tools: octopi,paru pm: appimage pkgs: 0
pm: flatpak pkgs: 0 Shell: fish v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2023-11-22
Last full system update: 2024-01-31
Failed units:            clamav-freshclam.service
If this desktop effect is what I think it is, I think I may have found some information to help (bit old information but could be still relevant)
If this is still true today, they might be some hard-coded defaults that kwin has.
This part of the post got me thinking that it might have a chance solving your issue:
“However, the up/down swipe gestures can be disabled by going into KDE Settings > Workspace Behavior > Desktop Effects and disabling Desktop Grid and Present Windows. The left/right gestures cannot be removed without disabling all virtual desktops.”
More of a work-around than a true fix, but hopefully that information is helpful still.
