Hi there,
I just joined as i am having problems with screen going black (while i am working ,evan while watching a video)
I want to remove all aspects of auto generated screen behaviour like that found in i3wm (blurlock autolock ? )
As i am now just checking out Garuda Sway edition i am a bit lost on how to configure it , Sway seems similar to i3wm , but if i could get some help on locating this function i.e. i dont want the screen to sleep , hibernate or do anything other than what its told by me.
Tanx heaps Cameron
Welcome
Try this
https://wiki.archlinux.org/title/Sway
Or search in ~/.config or web.
In ~/.config/sway/config.d/default line 20
### Idle configuration
exec swayidle -w\
timeout 1070 'swaylock -f -C ~/.config/swaylock/config'\
timeout 770 'swaymsg "output * dpms off"' \
resume 'swaymsg "output * dpms on"' \
before-sleep 'swaylock -C ~/.config/swaylock/config'
# This will lock your screen after 300 seconds of inactivity, then turn off
# your displays after another 300 seconds, and turn your screens back on when
# resumed. It will also lock your screen before your computer goes to sleep.
Either remove it or configure it
Tanx so much for ur reply .
Wiki didn't show the program i was looking for ( which i am thinking is lockman ?) i was able to find the config using a gui thunar ( i am not capable in terminal ) and extended the time out values in exec swayidle which has worked as i left the os on over night and its still not shut down so , this is a fluky quick fix for now .
I will find this program and kill it eventually.
SGS i really appreciate ur reply here .
namiste cams
Hi there ,
I could not remove it ( i not competent ) i tried commentating out the lines which produced error messages , so i extended the time out values which has worked , but i actually want to remove it i just dont know how at this stage , if i could find the program and delete it nice .
Tanx for ur reply u rock .
The package is called swayidle
I wouldn't recommend removing it but if you know you will be watching videos and etc; you use the command
killall swayidle
This is will kill swayidle for this session
Happy to Help!
Awesome reply tanx , this is a great pre configured wm coming from i3wm will continue with it , theirs still problems which i will work out .
Regards cams
