I am trying to use Remote Desktop Manager which I downloaded from AUR. Installed with no errors. Reason I installed AUR version is because Flatpak version alerted me on a 2024 release. So uninstalled Flatpak and installed AUR 2024 version. RDP Sessions worked with Flatpak However when I try to open an RDP session with the AUR I get an error: Unable to connect to Host.
When I try to run Remote Desktop Manager from terminal, I get the following error:
reggie@garudaK in ~/Downloads took 2ms
╰─λ remotedesktopmanager
(RemoteDesktopManager:324083): Gtk-CRITICAL **: 10:02:06.897: gtk_widget_grab_default: assertion 'gtk_widget_get_can_default (widget)' failed
[10:02:12:314] [324178:0004f25d] [INFO][Devolutions.Rdp.Credentials] - [Parse]: parsing "r*****", "t********" (Mstsc) => "Username: "r*****" Domain: "t********""
[10:02:12:322] [324178:0004f25d] [WARN][com.freerdp.core.client] - [freerdp_channels_client_load_ex]: Skipping, channel already loaded
[10:02:12:322] [324178:0004f25d] [ERROR][com.freerdp.channels.virtual.channel] - [virtchan_virtual_channel_init_event_ex]: Unhandled event type 0
[10:02:13:840] [324178:0004f25d] [WARN][com.freerdp.core.nego] - [nego_enable_aad]: This build does not support AAD security, disabling.
[10:02:13:842] [324178:0004f25d] [ERROR][com.freerdp.core.transport] - [transport_default_write]: BIO_should_retry returned a system error 32: Broken pipe
[10:02:13:842] [324178:0004f25d] [ERROR][com.freerdp.core] - [transport_default_write]: ERRCONNECT_CONNECT_TRANSPORT_FAILED [0x0002000D]
reggie@garudaK in ~/Downloads took 3m52s
╰─λ garuda-inxi
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0ce9b7db-35f3-430a-9870-91855461dff3 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
UEFI: American Megatrends v: 4204 date: 02/24/2022
Device-1: hidpp_battery_0 model: Logitech K350 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech M510 serial: <filter>
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3999 high: 4011 min/max: 2200/4918 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4000 2: 3998
3: 3989 4: 4000 5: 3999 6: 4002 7: 4000 8: 4003 9: 4000 10: 4000 11: 4000
12: 4000 13: 4000 14: 3999 15: 4000 16: 4000 17: 4000 18: 4000 19: 3999
20: 4000 21: 4011 22: 4000 23: 3999 24: 4000 bogomips: 191996
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: ASUSTeK
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DP-1,DVI-D-1,HDMI-A-1 empty: none bus-ID: 04:00.0 chip-ID: 10de:2187
Device-2: Logitech BCC950 ConferenceCam
driver: hid-generic,usbhid,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 5-3.1:5 chip-ID: 046d:0837 class-ID: 0300
Screen-1: 0 s-res: 5760x1080 s-dpi: 81 s-size: 1806x343mm (71.10x13.50")
s-diag: 1838mm (72.37")
Monitor-1: DP-1 note: disabled pos: right model: BenQ GW2760HS
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: DVI-D-1 mapped: DVI-D-0 note: disabled pos: left
model: BenQ GW2760HS serial: <filter> built: 2014 res: 1920x1080 hz: 60
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
Monitor-3: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,center
model: BenQ GW2760HS serial: <filter> built: 2015 res: 1920x1080 hz: 60
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650
SUPER/PCIe/SSE2 memory: 3.91 GiB
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 SUPER driver: nvidia v: 550.67 device-ID: 10de:2187
surfaces: xcb,xlib
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 04:00.1 chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech BCC950 ConferenceCam audio
lanes: 1 mode: 1.1 bus-ID: 5-3.3:8 chip-ID: 046d:0838 class-ID: 0300
Device-4: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-4.4:8
chip-ID: 001f:0b21 class-ID: 0300 serial: <filter>
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168
Device-2: Intel 82571EB/82571GB Gigabit Ethernet D0/D1 driver: e1000e
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 port: f020 bus-ID: 09:00.0
chip-ID: 8086:105e class-ID: 0200
IF: enp9s0f0 state: down mac: <filter>
Device-3: Intel 82571EB/82571GB Gigabit Ethernet D0/D1 driver: e1000e
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 port: f000 bus-ID: 09:00.1
IF: enp9s0f1 state: down mac: <filter>
Device-4: Realtek RTL8152 Fast Ethernet Adapter driver: r8152 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-4.1:4
chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: enp11s0f3u4u1 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Edimax Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-3:2 chip-ID: 7392:c611
Local Storage: total: 2.73 TiB used: 1.14 TiB (41.9%)
fw-rev: 1B2QEXM7 temp: 49.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
ID-1: / raw-size: 862.15 GiB size: 862.15 GiB (100.00%)
used: 640.7 GiB (74.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 5.7 MiB (1.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 862.15 GiB size: 862.15 GiB (100.00%)
ID-4: /var/log raw-size: 862.15 GiB size: 862.15 GiB (100.00%)
ID-5: /var/tmp raw-size: 862.15 GiB size: 862.15 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.7 GiB used: 604 MiB (0.9%) priority: 100
ID-2: swap-2 type: partition size: 69.07 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 57.4 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 33%
Memory: total: 64 GiB note: est. available: 62.7 GiB used: 35.48 GiB (56.6%)
Processes: 747 Power: uptime: 2h 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.04 GiB services: org_kde_powerdevil,
Packages: 2397 pm: dpkg pkgs: 1 pm: pacman pkgs: 2341 libs: 611
tools: gnome-software, octopi, pamac, paru pm: flatpak pkgs: 55 Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0
Garuda (2.6.23-1):
System install date: 2023-11-27
Last full system update: 2024-03-24 ↻
