garuda inxi:
Kernel: 6.9.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=37143950-d1f3-4a2a-8cb8-05120360fc01 rw rootflags=subvol=@
rd.luks.uuid=9c588456-2255-4964-b21f-0d2a956fab7a loglevel=3yz
plymouth.enable=0 disablehooks=plymouth ibt=off
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: HUAWEI product: KLVL-WXX9 v: M1560
Mobo: HUAWEI model: KLVL-WXX9-PCB v: M1560 serial: <superuser required>
part-nu: C100 uuid: <superuser required> UEFI: HUAWEI v: 1.06
date: 09/14/2020
ID-1: BAT0 charge: 5.8 Wh (12.5%) condition: 46.5/54.9 Wh (84.5%) volts: 7.2
min: 7.6 model: DYNAPACK HB4593R1ECW-22T0 type: Li-ion serial: <filter>
status: discharging cycles: 410
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600104
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2320 high: 2900 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2900 2: 1522
3: 2544 4: 2545 5: 2900 6: 2900 7: 2900 8: 2900 9: 1282 10: 2900 11: 1397
12: 2900 13: 1318 14: 1272 15: 2047 16: 2900 bogomips: 92621
Device-1: AMD Renoir [Radeon Vega Series / Radeon Mobile Series]
vendor: Huaqin driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 41.0 C
Device-2: IMC Networks HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:5451
Monitor-1: eDP-1 res: 1800x1200 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.2-arch1.1
renoir LLVM 17.0.6 DRM 3.57 6.9.6-zen1-1-zen) device-ID: 1002:1636
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.2-arch1.1
device-ID: 1002:1636 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.2-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio vendor: Huaqin
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Huaqin driver: N/A
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Huaqin driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
API: ALSA v: k6.9.6-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0
IF-ID-1: br-362fc8bf733b state: down mac: <filter>
IF-ID-2: br-71f4b1a5cea3 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-dc056ff6fa0d state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
IF-ID-5: vethbcea2ee state: up speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 8087:0032
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 931.51 GiB used: 227.16 GiB (24.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 40.9 C
ID-1: / raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
used: 227.07 GiB (24.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-9c588456-2255-4964-b21f-0d2a956fab7a
used: 90.4 MiB (17.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
ID-4: /var/log raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.01 GiB size: 931.01 GiB (100.00%)
ID-1: swap-1 type: zram size: 15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.8 C mobo: N/A gpu: amdgpu temp: 42.0 C
Memory: total: 16 GiB note: est. available: 15 GiB used: 7.62 GiB (50.8%)
Processes: 415 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.97 GiB services: org_kde_powerdevil,
Packages: 2228 pm: pacman pkgs: 2220 libs: 597
tools: gnome-software,octopi,paru pm: flatpak pkgs: 8 Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-04-07
Last full system update: 2024-06-27
Always when I switch to another desktop with three finger swiping on the mousepad, I get the following dialog:
When I accept it, it comes again later. Sometimes keyboard inputs are broken after it. Sometimes it freezes the OS. But mostly it’s just annoying. So is there a way to disable this dialog?
I mean - I can just not click it. Also: using keyboard or mouse to switch desktop works fine without this message.
