Installed remmina, which I always use for RDP, but RDP is missing. I don't see it as an add-on in the repositories. Is there somehow to add rdp?
Thanks!
Kernel: 6.2.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=43f18a73-c753-4e08-9fba-b8afedfcb3ac rw [email protected]
resume=UUID=9431c5cc-6a40-4ec6-91b8-d397f24a4c4e loglevel=3 ibt=off
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Sony product: VPCZ21TGX v: J004MUHH
serial: Chassis: type: 10 serial:
Mobo: Sony model: VAIO serial: BIOS: INSYDE
v: R0170H5 date: 06/16/2011
ID-1: BAT1 charge: 0 Wh condition: N/A volts: N/A model: Sony Corporation
type: Li-ion serial: N/A status: not charging
Info: model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 809 high: 843 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 843 2: 798 3: 798 4: 798
bogomips: 21550
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
vendor: Sony driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: eDP-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0126
Device-2: Cheng Uei Precision Industry (Foxlink) Webcam type: USB
driver: uvcvideo bus-ID: 2-1.3:5 chip-ID: 05c8:0318 class-ID: 0e02
serial:
compositor: gnome-shell driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: :1
Monitor-1: eDP-1 model: Sony LCD serial: built: 2011
res: 1920x1080 hz: 60 dpi: 168 gamma: 1.2 size: 291x164mm (11.46x6.46")
diag: 334mm (13.2") ratio: 16:9 modes: 1920x1080
missing.
vendor: Sony driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound API: ALSA v: k6.2.1-zen1-1-zen running: yes
Device-1: Intel Centrino Advanced-N 6230 [Rainbow Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:0091 class-ID: 0280
IF: wlp2s0 state: up mac:
vendor: Sony driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 6000 bus-ID: 05:00.0 chip-ID: 10ec:8168
IF: enp5s0 state: down mac:
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Device-1: Intel Centrino Advanced-N 6230 Bluetooth adapter type: USB
driver: btusb v: 0.8 bus-ID: 2-1.2:4 chip-ID: 8086:0189 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address:
v: 3.0 port: a060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 238.49 GiB used: 66.93 GiB (28.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZRPC256HADR-000SO
type: SSD serial: rev: 3S1Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZRPC256HADR-000SO
ID-1: / raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
used: 66.93 GiB (60.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
ID-3: /var/log raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
ID-4: /var/tmp raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.71 GiB used: 919.2 MiB (15.7%)
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 264 Uptime: 19m wakeups: 1 Memory: 5.71 GiB used: 4.5 GiB (78.9%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 1568 libs: 493
tools: gnome-software,pamac,paru pm: flatpak pkgs: 0 Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-05-03
Last full system update: 2023-03-02
Relevant software: snapper(custom) NetworkManager mkinitcpio
Windows dual boot:
