Refresh Rate problems
I'm trying to set my refresh rate to 144hz I already set it in the Nvidia settings and display settings and also in kwin.rc compositing putting refresh rate 144 and max 144 it use to work but not anymore ive been looking around but can't find another solution does someone know of another solution I'm using Garuda dragonized with plasma 5.27 and also there the garuda-inxi Thank you
Kernel: 6.2.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=58693025-6c1b-4b02-91db-e0c3dd8c9b75 rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG STRIX B660-A GAMING WIFI D4 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2212
date: 12/13/2022
Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
microcode: 0x2C
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 2999 high: 4719 min/max: 800/4900:5000:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1882 2: 1153 3: 3587
4: 3710 5: 2141 6: 1500 7: 4091 8: 3362 9: 4700 10: 4719 11: 4340 12: 4711
13: 1991 14: 1115 15: 3251 16: 2571 17: 3601 18: 2450 19: 2990 20: 2122
bogomips: 144383
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate]
vendor: Hewlett-Packard driver: nvidia v: 525.89.02
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2216 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX
3080/PCIe/SSE2 direct-render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 1-8:3 chip-ID: 0b05:1a16 alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: Hewlett-Packard
Device-3: ASUSTek USB Audio type: USB
Sound API: ALSA v: k6.2.2-zen1-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 4.55 TiB used: 750.1 GiB (16.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: 980 PRO with
Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7
temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung
rev: 2B2QEXM7 temp: 35.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Western Digital
model: WDBA3V0010BNC-WRSN size: 931.51 GiB block-size: physical: 512 B
rev: 211070WD temp: 32.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS200T2B0A
type: SSD serial: <filter> rev: 90WD scheme: GPT
used: 17.83 GiB (1.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.09 GiB used: 171.5 MiB (0.5%)
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 57%
Processes: 455 Uptime: 1h 54m wakeups: 0 Memory: 31.09 GiB
used: 7.16 GiB (23.0%) Init: systemd v: 253 default: graphical
pkgs: 1612 libs: 473 tools: octopi,pamac,paru Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date:     2023-03-06
Last full system update: 2023-03-06 ↻
Please elaborate.
Its just that under settings in the display section putting it to 144hz never sticks upon reboot, so I found on the internet that if you go in kwin.rc and add to the compositing section your desired refresh rate, mine is MaxFPS=144 Refresh Rate=144 it use to work when i would reboot my system the setting would stay but in plasma 5.27 in Garuda doesn't seem to work every time i reboot it reverts back to 60hz.
