My problem is that I cannot permanently change the refresh rate of my monitor. I'm able to change it via the Monitor Settings but on the next reboot it will default to 60hz!
The save button in the below screenshot doesn't seem to have any effect:
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=ce118470-4f53-49b9-b500-9ddd71f75162 rw rootflags=subvol=@
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.30.0
Type: Desktop Mobo: Micro-Star model: B450-A PRO (MS-7B86) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.21
date: 09/20/2018
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3540 high: 3873 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3567 2: 3258
3: 3405 4: 3358 5: 3330 6: 2614 7: 3755 8: 3838 9: 3873 10: 3841 11: 3856
12: 3791 bogomips: 81590
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nvidia v: 515.43.04 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Pascal pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 1c:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 dpi: 93 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") modes: N/A
Device-1: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
bus-ID: 1c:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 1e:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
lanes: 1 port: f000 bus-ID: 18:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp24s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-c38dd7569bf8 state: down mac: <filter>
IF-ID-2: br-c473b5e2278b state: down mac: <filter>
IF-ID-3: br-c573e5d4dcb3 state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
Local Storage: total: 1.59 TiB used: 237.35 GiB (14.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z42105
temp: 37.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A02 scheme: GPT
ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 51.53 GiB (26.4%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
used: 604 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 254.16 GiB size: 254.16 GiB (100.00%)
used: 43.07 GiB (16.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.36 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 42.0 C mobo: 34.0 C gpu: nvidia temp: 38 C
Fan Speeds (RPM): fan-1: 1437 fan-2: 1549 fan-3: 0 fan-4: 926 fan-5: 1002
fan-6: 0 gpu: nvidia fan: 35%
Processes: 432 Uptime: 10h 57m wakeups: 0 Memory: 31.36 GiB
used: 18.71 GiB (59.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 Packages: 1608 pacman: 1599 lib: 344 flatpak: 9 Shell: Zsh
v: 5.9 running-in: alacritty inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2021-10-07
Last full system update: 2022-05-22
