Refresh Mirrorlist problem
Hi,
╰─λ inxi -Faz
Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=733a78e5-2a03-4d99-bd2e-33feedaa75a2 rw rootflags=subvol=@
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop Mobo: Gigabyte model: P55-US3L serial: <superuser required>
BIOS: Award v: FE date: 03/05/2010
Info: model: Intel Core i5 750 bits: 64 type: MCP arch: Nehalem family: 6
model-id: 0x1E (30) stepping: 5 microcode: 0xA
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1616 high: 1893 min/max: 1197/2661 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1766 2: 1279
3: 1527 4: 1893 bogomips: 21318
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
IBRS_FW, STIBP: disabled, RSB filling
Device-1: AMD Redwood XT [Radeon HD 5670/5690/5730] vendor: Gigabyte
driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:68d8 class-ID: 0300
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1.2:3 chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
s-diag: 582mm (22.9")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL:
renderer: AMD REDWOOD (DRM 2.50.0 / 5.16.9-zen1-1-zen LLVM 13.0.1)
v: 3.3 Mesa 21.3.6 compat-v: 3.1 direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
Device-2: AMD Redwood HDMI Audio [Radeon HD 5000 Series] vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 1002:aa60
Device-3: Creative Labs CA0106/CA0111 [SB Live!/Audigy/X-Fi Series]
driver: snd_ca0106 v: kernel bus-ID: 06:04.0 chip-ID: 1102:0007
class-ID: 0401
Device-4: Philips s SAA7131/SAA7133/SAA7135 Video Broadcast Decoder
vendor: Avermedia DVB-T Super 007 driver: saa7134 v: 0, 2, 17
bus-ID: 06:05.0 chip-ID: 1131:7133 class-ID: 0480
Device-5: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel port: ee00 bus-ID: 02:00.0 chip-ID: 10ec:818b class-ID: 0280
vendor: Gigabyte driver: r8169 v: kernel port: ce00 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 447.13 GiB used: 160.97 GiB (36.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: GOODRAM model: N/A size: 447.13 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD
serial: <filter> rev: 01.7 scheme: MBR
ID-1: / raw-size: 293.3 GiB size: 293.3 GiB (100.00%)
used: 51.38 GiB (17.5%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot raw-size: 520 MiB size: 519 MiB (99.80%)
used: 246.6 MiB (47.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 293.3 GiB size: 293.3 GiB (100.00%)
ID-4: /var/log raw-size: 293.3 GiB size: 293.3 GiB (100.00%)
ID-5: /var/tmp raw-size: 293.3 GiB size: 293.3 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.68 GiB used: 3.72 GiB (31.9%)
System Temperatures: cpu: 50.0 C mobo: N/A gpu: radeon temp: 59.5 C
Processes: 346 Uptime: 12h 55m wakeups: 0 Memory: 11.68 GiB
used: 7.47 GiB (63.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1758 lib: 385 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.12
So I just simply wanted to refresh my mirrorlist (Reflector simple). After ratings complete you should save it at /etc/pacman.d/mirrorlist. Doing so I get each time:
reflector-simple: info: reading file /etc/reflector-simple-tool.conf
reflector-simple: info: reading file /etc/reflector-simple.conf
pkexec must be setuid root
Press enter to exit
How to fix that? And what’s "pkexex’, while I can’t find it? I’d like to handle that also because during system update I receive warning (nothing a big deal but I just don’t like it and would love to get rid of):
Thank you in advance!
Try
garuda-update
Well, I don't have problem with system update (it's going fine even with warnings). But the problem is I'm not able to add a new mirrors. Each time it's the same. I'm not able to change it and keep permanent.
Can you try
garuda-update
or is that a old inxi
then provide
╰─λ garuda-inxi
desc: 1x8 MiB
Speed (MHz): avg: 3005 high: 3176 min/max: 1197/2661 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3176 2: 3074
3: 2868 4: 2903 bogomips: 21318
Type: l1tf
Type: mds
OpenGL:
class-ID: 0401
Local Storage: total: 447.13 GiB used: 160.99 GiB (36.0%)
used: 51.4 GiB (17.5%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-1: swap-1 type: zram size: 11.68 GiB used: 2.85 GiB (24.4%)
System Temperatures: cpu: 47.0 C mobo: N/A gpu: radeon temp: 58.0 C
Processes: 332 Uptime: 13h 48m wakeups: 0 Memory: 11.68 GiB
used: 7.33 GiB (62.7%) Init: systemd v: 250 tool: systemctl Compilers:
Garuda (2.5.4-2):
System install date:     2021-05-29
Last full system update: 2022-02-18
Snapshots:               Timeshift
Failed units:            bluetooth-autoconnect.service docker.service docker.socket
Can you provide the output of
sudo pacman -Syu
Seems like you removed the setuid bit from pkexec for some reason. You probably read one of those posts related to pkexec's security vulnerability and ran the "fix" command, which ruins pkexec.
A simple reinstall should fix this: sudo pacman -S polkit
Reinstalling polkit fixed problem with setuid bit. Thank you for that!
I have checked history and I wasn't able to find any command which consisted polkit or pkexec words. So not able to explain why it happened to me.
Ok so that part partially is done. How about mirror list. After choosing and saving a few countries shouldn't them be again checked in next approach of modification? By that I mean that after opening a list I see:
and it's always the same. Why I don't see Germany, Latvia, Austria, Switzerland etc marked down as well, while those countries was previously assigned? Or my understanding is wrong and that's correct behavior?
Sure. Previously was ok. After reinstalling polkit and reassigning mirrorlist I get:
Please no pictures from terminal, post as text.
The answer is in your picture.
Try
Sorry, I've thought that picture terminal inxi output are only not allowed.
So bellow is whole log from garuda-update:
╰─λ garuda-update
[sudo] password for zawier:
--> Refreshing mirrorlists using reflector, please be patient..
[2022-02-19 12:39:03] WARNING: failed to rate http(s) download (https://archmirror.it/repos/community/os/x86_64/community.db): HTTP Error 403: Forbidden
################# Arch Linux mirrorlist generated by Reflector #################
# With:       reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When:       2022-02-19 11:39:03 UTC
# From:       https://archlinux.org/mirrors/status/json/
# Retrieved:  2022-02-19 11:38:55 UTC
# Last Check: 2022-02-19 11:29:39 UTC
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://phinau.de/arch/$repo/os/$arch
Server = https://mirror.cyberbits.eu/archlinux/$repo/os/$arch
Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
Server = https://archmirror.it/repos/$repo/os/$arch
:: Synchronising package databases...
core                                  133,4 KiB   295 KiB/s 00:00 [------------------------------------] 100%
extra                                1542,3 KiB  1753 KiB/s 00:01 [------------------------------------] 100%
community                               6,1 MiB  2,38 MiB/s 00:03 [------------------------------------] 100%
multilib                              149,6 KiB   343 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur                           167,0 KiB   193 KiB/s 00:01 [------------------------------------] 100%
spawn pacman -Su
resolving dependencies...
Packages (5) alsa-card-profiles-1:0.3.47-2  bind-9.18.0-1  jemalloc-1:5.2.1-6  pipewire-1:0.3.47-2
whoogle-git-0.7.1_r528.g9984158-1
Total Download Size:   14,65 MiB
Total Installed Size:  56,30 MiB
Net Upgrade Size:       6,08 MiB
:: Retrieving packages...
alsa-card-profiles-1:0.3.47-2-x86_64   27,0 KiB  83,3 KiB/s 00:00 [------------------------------------] 100%
jemalloc-1:5.2.1-6-x86_64             302,1 KiB   188 KiB/s 00:02 [------------------------------------] 100%
whoogle-git-0.7.1_r528.g9984158-...    10,9 MiB  6,62 MiB/s 00:02 [------------------------------------] 100%
pipewire-1:0.3.47-2-x86_64           1616,6 KiB   730 KiB/s 00:02 [------------------------------------] 100%
bind-9.18.0-1-x86_64                 1914,6 KiB   551 KiB/s 00:03 [------------------------------------] 100%
Total (5/5)                            14,6 MiB  4,14 MiB/s 00:04 [------------------------------------] 100%
(5/5) checking keys in keyring                                     [------------------------------------] 100%
(5/5) checking package integrity                                   [------------------------------------] 100%
(5/5) loading package files                                        [------------------------------------] 100%
(5/5) checking for file conflicts                                  [------------------------------------] 100%
(5/5) checking available disk space                                [------------------------------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
/dev/sda2 is mounted at: /run/timeshift/backup, options: rw,relatime
Creating new snapshot...(RSYNC)
Saving to device: /dev/sda2, mounted at path: /run/timeshift/backup
Linking from snapshot: 2022-02-19_12-27-27
Synching files with rsync...
34.19% complete (00:01:42 remaining)
Created control file: /run/timeshift/backup/timeshift/snaps
hots/2022-02-19_12-40-17/info.json
RSYNC Snapshot saved successfully (104s)
Tagged snapshot '2022-02-19_12-40-17': ondemand
Removing '2022-02-16_01-33-29'...
Removed '2022-02-16_01-33-29'
(1/5) upgrading alsa-card-profiles                                 [------------------------------------] 100%
(2/5) installing jemalloc                                          [------------------------------------] 100%
warning: directory permissions differ on /usr/bin/
filesystem: 4755  package: 755
Optional dependencies for jemalloc
perl: for jeprof [installed]
(3/5) upgrading bind                                               [------------------------------------] 100%
(4/5) upgrading pipewire                                           [------------------------------------] 100%
(5/5) upgrading whoogle-git                                        [------------------------------------] 100%
( 1/11) Creating system user accounts...
( 2/11) Reloading system manager configuration...
( 3/11) Creating temporary files...
Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
( 4/11) Reloading device manager configuration...
( 5/11) Arming ConditionNeedsUpdate...
( 6/11) Foreign/AUR package notification
ananicy-cpp 1.0.0.rc6-1
appimagelauncher 2.2.0-5
archlinux-appstream-data-pamac 1:20220107-1
backintime-cli-git 1.3.1.r1.ge1ae23dd-2
backintime-git 1.3.1.r1.ge1ae23dd-2
beautyline 20220212-2
bluetooth-autoconnect 1.3-1
bluetooth-support 1-5
btrfs-assistant 0.8-2
btrfsmaintenance 0.5-2
chaotic-keyring 20220130-1
chaotic-mirrorlist 20211231-1
ckbcomp 1.207-1
conky-lua-nv 1.12.2-1
downgrade 11.0.0-1
firedragon 97.0-2
fish-autopair 1.0.3-2
fish-systemd-git r10.4e922a2-2
freedownloadmanager 6.15.3.4236-1
game-devices-udev 0.16-2
garuda-assistant 2.6.0-1
garuda-bash-config 1.0.1-1
garuda-common-settings 2.5.4-2
garuda-dr460nized 1.5.17-1
garuda-fish-config 1.4.4-1
garuda-hooks 2.5.4-1
garuda-network-assistant 1.1.1-1
garuda-starship-prompt 1.0.3-1
google-chrome 98.0.4758.102-1
grub-garuda 2.06-1
hblock 3.3.1-1
hypnotix 2.6-1
input-devices-support 1.0.1-1
inxi 3.3.12.1-1
iscan 2.30.3.1-2
kde-servicemenus-rootactions 2.9.1-1
kfiredragonhelper 5.0.6-1
kmozillahelper 1:5.0.6-1
kwin-effects-sliding-notifications 1.2.0-1
kwin-scripts-forceblur 0.6.1-1
libinput-gestures 2.72-1
libinput_gestures_qt 0.3.2+7+g0868859-1
libopenaptx 0.2.0-1
libpamac-aur 11.2.0-5
librewolf 97.0-1
librewolf-extension-bitwarden 1.55.0-1
librewolf-extension-xdm-browser-monitor 2.2-1
libstdc++5 3.3.6-7
linux-wifi-hotspot 4.4.0-1
linuxtv-dvb-apps 1505-2
memavaild 0.6-1
mhwd-amdgpu 19.1.0-1
mhwd-ati 19.1.0-1
mhwd-nvidia 495.46-1
mhwd-nvidia-390xx 390.143-1
mhwd-nvidia-470xx 470.94-1
mkinitcpio-openswap 0.1.0-3
mystiq 20.03.23-1
neard 0.18-1
nerd-fonts-fantasque-sans-mono 2.1.0-3
networkmanager-support 1-2
nohang 0.2.0-1
noto-color-emoji-fontconfig 1.0.0-1
onlyoffice-bin 7.0.0-1
os-prober-btrfs 1.79-3
pace 1.4.1.1-2
paleofetch-garuda r3.6471340-1
pamac-aur 10.3.0-4
paru 1.9.3-1
performance-tweaks 2.1.1-3
plasma5-applets-eventcalendar 75-1
plasma5-applets-netspeed 1.9-1
plasma5-applets-window-appmenu 0.7.1-2
plasma5-applets-window-title 0.7.0-2
plasma5-theme-sweet-git r20.f7f760a-1
plymouth-git 0.9.5.r110.g5b91b9e-1
plymouth-theme-garuda-purple r5.16806d2-1
preload 0.6.4-7
prelockd 0.9-1
printer-support 1-5
python2-gobject2 2.28.7-7
quake3 1.32c-2
quake3-cpma 1.52-1
rdpsign r7.g89cd086-1
resvg 0.21.0-1
rocket-depot-git r318.849654d-1
shortwave 1:2.0.1-1
sweet-gtk-theme-dark 3.0-1
systemd-guest-user 33.2-1
systemd-oomd-defaults 249.7-1
teams 1.4.00.26453-1
timeshift 21.09.1-3
timeshift-autosnap 0.9-1
update-grub 0.0.1-7
uresourced 0.4.1-1
virtualbox-ext-oracle 6.1.32-1
virtualbox-meta 2-2
visual-studio-code-bin 1.64.2-1
xcursor-sweet 20200612-1
xdman 2020.7.2.11-2
xrdp 0.9.17-1
( 7/11) Orphaned package notification...
0ad-data a25.b-1
celt 0.11.3-4
cht.sh-git r892.46d1a5f-1
ddcutil 1.2.2-1
electron 16.0.8-2
elfutils 0.186-5
enet 1.3.17-1
extra-cmake-modules 5.91.0-1
gloox 1.0.24-1
gtkspell3 3.0.10-2
irrlicht 1.8.5-1
kinit 5.91.0-1
libcmis 0.5.2-9
libmms 0.6.4-3
libofa 0.9.3-9
libopenaptx 0.2.0-1
memavaild 0.6-1
miniupnpc 2.2.2-2
nasm 2.15.05-1
nohang 0.2.0-1
prelockd 0.9-1
python-cached-property 1.5.2-5
python-docopt 0.6.2-11
python-systemd 234-11
python-sysv_ipc 1.1.0-2
python-texttable 1.6.4-3
qconf 2.5-1
rebuild-detector 4.4.1-1
schedtool 1.3.0-7
uresourced 0.4.1-1
xinetd 2.3.15.4-1
zita-alsa-pcmi 0.4.0-1
zita-resampler 1.8.0-1
( 8/11) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/nsswitch.conf.pacnew
/etc/locale.gen.pacnew
/etc/default/grub-btrfs/config.pacnew
/etc/services.pacnew
/etc/pamac.conf.pacnew
/usr/lib/librewolf/librewolf.cfg.pacnew
/usr/lib/librewolf/distribution/policies.json.pacnew
/etc/nanorc.pacnew
/etc/Nextcloud/sync-exclude.lst.pacnew
/etc/pacman.conf.pacnew
/etc/plymouth/plymouthd.conf.pacnew
/etc/sudoers.pacnew
/etc/systemd/system.conf.pacnew
/etc/systemd/user.conf.pacnew
Please check and merge
( 9/11) Updating pkgfile database...
(10/11) Checking which packages need to be rebuilt
foreign firedragon
foreign libinput_gestures_qt
(11/11) Syncing all file systems...
Parsing man pages and writing completions to /home/zawier/.local/share/fish/generated_completions/
4659 / 4659 : zramctl.8.gz
Checking for plugin updates
Nothing to install / update
System updated! 🐧
As you see there are some errors and warnings. In the end it said that system is updated, but why during updating those warnings are presented?
Here my permissions :
╭─zawier@zawier in ~ as 🧙 took 4m11s
╰─λ ls -ld /usr/bin
drwsr-xr-x - root 19 lut 12:42  /usr/bin
╭─zawier@zawier in ~ took 3ms
╰─λ ls /usr/bin/sudo -all
.rwsr-xr-x 211k root  2 lut 09:02  /usr/bin/sudo
Warning = ignore :slight_smile:
Error = Only if you have this hardware, investigate more.
Ah, ok I see. Thank you for explaining.
BTW. Should I use from now on garuda-update or pacman -Syu command? Are they matter which one is picked up? From the beginning I was always using upgrading from pacman.
Please also lets go back to mirrors with reflector-simple.
https://forum.garudalinux.org/t/refresh-mirrorlist-problem/17547/8?u=zawier
First
Second
If first failed :slight_smile:
Roger that! :wink: Thank you!
And what about mirrorlist?
Check
cat /etc/xdg/reflector/reflector.conf
File: /etc/xdg/reflector/reflector.conf
# Reflector configuration file for the systemd service.
# Empty lines and lines beginning with "#" are ignored.  All other lines should
# contain valid reflector command-line arguments. The lines are parsed with
# Python's shlex modules so standard shell syntax should work. All arguments are
# collected into a single argument list.
# See "reflector --help" for details.
# Recommended Options
# Set the output path where the mirrorlist will be saved (--save).
# Select the transfer protocol (--protocol).
--protocol https
# Select the country (--country).
# Consult the list of available countries with "reflector --list-countries" and
# select the countries nearest to you or the ones that you trust. For example:
# --country France,Germany
# Use only the  most recently synchronized mirrors (--latest).
--latest 5
# Sort the mirrors by synchronization time (--sort).
--sort age
Everything exactly the same.
Edit to
 --country France,Germany,Poland,Brazil # and what you like.
Or
sudo reflector --country Germany --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist && cat /etc/pacman.d/mirrorlist && sudo pacman -Syu
File: /etc/pacman.d/mirrorlist
# With:       reflector --country Germany --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When:       2022-02-19 14:52:44 UTC
# Retrieved:  2022-02-19 14:52:30 UTC
# Last Check: 2022-02-19 14:39:07 UTC
Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
Server = https://mirror.luzea.de/archlinux/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
Server = https://mirror.pseudoform.org/$repo/os/$arch
SGS thank you ! :partying_face:
