Hello,
I have followed the instructions from Arch Linux - News: Git migration completed and am still getting this issue. Can someone please help me resolve this?
My garuda-inxi:
╰─λ garuda-inxi
Kernel: 6.3.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=c1ba9331-3cea-44cf-a194-04cb29defb6c rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 82L5 v: IdeaPad 5 Pro 16ACH6
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 Pro 16ACH6
Mobo: LENOVO model: LNVNB161216 v: WIN serial: <superuser required>
UEFI: LENOVO v: GSCN27WW date: 08/23/2021
ID-1: BAT0 charge: 66.3 Wh (97.6%) condition: 67.9/75.0 Wh (90.6%)
volts: 17.4 min: 15.4 model: Celxpert L20C4PE1 type: Li-ion serial: <filter>
status: charging cycles: 41
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2638 high: 4368 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3457 2: 1200
3: 3519 4: 4368 5: 3423 6: 1200 7: 3551 8: 3200 9: 3200 10: 1200 11: 3401
12: 1200 13: 3448 14: 1200 15: 3445 16: 1200 bogomips: 102204
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a2 class-ID: 0302
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 off: eDP-1
empty: DP-1 bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 48.0 C
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 13d3:56fb
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 676x380mm (26.61x14.96")
s-diag: 775mm (30.53")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary model: Samsung
serial: <filter> built: 2020 res: 2560x1440 hz: 60 dpi: 35 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 1630mm (64.2") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
Monitor-2: eDP-1 mapped: eDP note: disabled model-id: CSO 0x1601
built: 2020 res: 2560x1440 dpi: 188 gamma: 1.2 size: 345x215mm (13.58x8.46")
diag: 407mm (16") ratio: 16:10 modes: max: 2560x1600 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.6-zen1-1-zen) direct-render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.3.6-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3
chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 679.57 GiB (71.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TDE9X084N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41010C22 temp: 46.9 C
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 38.61 GiB (38.6%)
used: 876 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 38.61 GiB (38.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.5 GiB used: 497 MiB (3.6%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 48.0 C
Processes: 448 Uptime: 5m wakeups: 154 Memory: available: 13.5 GiB
used: 3.35 GiB (24.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1704 libs: 416 tools: octopi,pamac,paru,yay pm: flatpak pkgs: 0
inxi: 3.3.27
System install date: 2023-05-09
Last full system update: 2023-06-08 ↻
Thank you.
