anyone know whats wrong with this refind boot stanza?
been looking here rEFInd - ArchWiki and here The rEFInd Boot Manager: Configuring the Boot Manager
and can’t find what I am doing wrong
for some reason it fails to boot with an
Invalid loader file not found while loading vmlinuz-linux-cachyos error
here is what I have defined at the end of my /boot/efi/EFI/refind/refind.conf
menuentry "Garuda Linux" {
icon /EFI/refind/icons/os_arch.png
volume 8a69f047-feee-46cf-81a1-d299eb173883
loader /@/boot/vmlinuz-linux-cachyos
initrd /@/boot/initramfs-linux-cachyos.img
options "root=PARTUUID=b9c12dad-59b7-437a-9b44-334b217f8dab rw rootflags=subvol=@ loglevel=3 sysrq_always_enabled=1 amd_pstate=active amdgpu.ppfeaturemask=0xffffffff tsc=reliable clocksource=tsc nowatchdog nmi_watchdog=0"
submenuentry "Boot using fallback initramfs" {
initrd /@/boot/initramfs-linux-cachyos-fallback.img
submenuentry "Boot to terminal" {
add_options "systemd.unit=multi-user.target"
which seems correct …
UUID matches as well
lsblk -o NAME,PARTUUID,UUID
NAME PARTUUID UUID
sda
└─sda2 20b07f95-f912-7f4a-a1dc-0bda6b23f987 d6a92575-7181-4506-80d1-84a9594f90e8
zram0
nvme0n1
├─nvme0n1p1 23ba08e3-a716-4615-8712-6b4a29ecbfc8 79CD-8D09
└─nvme0n1p2 b9c12dad-59b7-437a-9b44-334b217f8dab 8a69f047-feee-46cf-81a1-d299eb173883
the arch wiki gives this as an example config
menuentry "Arch Linux" {
volume "[bootdevice]"
loader /ROOT/boot/vmlinuz-linux
initrd /ROOT/boot/initramfs-linux.img
options "root=PARTUUID=XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX rw rootflags=subvol=ROOT"
which is pretty much word for word what I have (except the extra options and the sub menu entry I did try removing those)
Kernel: 6.9.3-2-cachyos arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-linux
root=UUID=8a69f047-feee-46cf-81a1-d299eb173883 rw rootflags=subvol=@
nmi_watchdog=0 initrd=@\boot\initramfs-linux-cachyos.img
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: P5.10
date: 10/20/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4132 high: 4551 min/max: 550/4651 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3640 2: 4548 3: 3654
4: 4461 5: 4544 6: 4415 7: 3640 8: 4551 9: 3639 10: 3647 11: 4551
12: 4296 bogomips: 88816
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-2,HDMI-A-2 empty: HDMI-A-1,Writeback-1
bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
compositors: 1: Gamescope 2: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 4980x2513 display-ID: 0
Monitor-1: DP-1 pos: bottom-r res: 2048x864 size: N/A modes: N/A
Monitor-2: DP-2 pos: primary,top-left res: 1396x785 size: N/A modes: N/A
Monitor-3: HDMI-A-2 pos: middle-c res: 1536x864 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
navi22 LLVM 17.0.6 DRM 3.57 6.9.3-2-cachyos) device-ID: 1002:73df
memory: 11.72 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.279 layers: 23 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28
Device-2: Sony INZONE H9 / H7
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 054c:0e53
class-ID: 0a00
API: ALSA v: k6.9.3-2-cachyos status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Edimax Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: 7392:c611
lmp-v: 10 status: discoverable: yes pairing: yes class-ID: 6c0104
Local Storage: total: 5.46 TiB used: 5.4 TiB (98.9%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731120WD temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN006-3CW104
tech: HDD rpm: 5400 serial: <filter> fw-rev: SC60 scheme: GPT
used: 834 GiB (89.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 43.9 MiB (14.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
zswap: no
ID-1: swap-1 type: zram size: 31.26 GiB used: 4.29 GiB (13.7%)
System Temperatures: cpu: 58.4 C mobo: 34.0 C gpu: amdgpu temp: 57.0 C
mem: 58.0 C
Fan Speeds (rpm): cpu: 2191 fan-1: 0 fan-3: 1315 fan-4: 1413 fan-5: 1254
gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.28 vbat: 3.28 gpu: amdgpu watts: 32.00
Memory: total: 32 GiB available: 31.26 GiB used: 15.33 GiB (49.0%)
Processes: 568 Power: uptime: 1h 12m states: freeze,mem,disk
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: 2904 pm: pacman pkgs: 2851 libs: 642 tools: octopi,paru,yay
pm: appimage pkgs: 0 pm: flatpak pkgs: 53 Compilers: clang: 17.0.6
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: alacritty inxi: 3.3.34
System install date: 2024-01-11
Last full system update: 2024-06-08
