Hello.
I'm trying to figure out why everytime I restart my computer the redshift-wayland-git errors out and I have to relaunch it.
During the launch of the sway session I get a pop up from redshift and the last line is os_create_anonymous_file: Invalid argument
Kernel: 5.16.3-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5ea32362-776b-4a64-a2e7-1e1492b1137b rw rootflags=subvol=@
resume=UUID=99213909-149f-4663-8cb0-b7431f100328 loglevel=3
Desktop: sway 1.7 vt: 1 dm: N/A Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 13 9350 v: N/A
serial: <superuser required> Chassis: type: 9
Mobo: Dell model: 0PWNCR v: A01 serial: <superuser required> UEFI: Dell
v: 1.11.1 date: 08/01/2019
ID-1: BAT0 charge: 32.3 Wh (100.0%) condition: 32.3/56.0 Wh (57.7%)
volts: 8.6 min: 7.6 model: LGC-LGC7.3 DELL 5K9CP5A type: Li-ion
serial: <filter> status: Full
Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 640 high: 1115 min/max: 400/3100 scaling:
driver: intel_pstate governor: powersave cores: 1: 463 2: 483 3: 500
4: 1115 bogomips: 20799
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0c45:670c class-ID: 0e02
Display: wayland server: N/A compositor: sway v: 1.7 driver:
loaded: i915 note: n/a (using device driver) display-ID: 1
resolution: <missing: xdpyinfo>
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
Sound Server-1: ALSA v: k5.16.3-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.44 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 3a:00.0
chip-ID: 8086:095a class-ID: 0280
IF: wlp58s0 state: up mac: <filter>
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus-ID: 1-3:3 chip-ID: 8087:0a2a class-ID: e001
address: <filter>
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 465.76 GiB used: 19.17 GiB (4.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung
model: SSD 860 EVO M.2 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q
ID-1: / raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
used: 19.17 GiB (4.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-4: /var/log raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C pch: 37.5 C mobo: 35.0 C
sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 211 Uptime: 1h 49m wakeups: 3 Memory: 7.63 GiB
used: 2.37 GiB (31.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1282 lib: 318 Shell: Zsh
v: 5.8 running-in: alacritty inxi: 3.3.12
Garuda:
System install date: 2021-12-08
Last full system update: 2022-01-29
Using TLP: No
I have searched across the different redshift-wayland-git tickets but I haven't seen anything that matches this.
I did find this discussion about Sway 1.5 and redshift but supposedly this ticket was fixed and closed. Broken Under Sway 1.5
Anyone have suggestions that I should try?
Should I switch to gammastep? I see there is a wlsunset script in ~/.config/sway/scripts called light.sh. Is that something that is production ready?
