Can I somehow change my login screen from sddm to something else?
You can get the current default configs with cp -rf /etc/skel/* ~
To clarify, did you try to downgrade SDDM? (sudo downgrade sddm
You could as well just disable sddm (sudo systemctl disable --now sddm
) and login to tty, then type startx
to start the session manually
No, I will try downgrading
Well I downgraded to 19.0.03 and the same issue arises. I can't even get to a tty
Trying to disable sddm gives an error saying that System has not been booted with systemd as init system and writing cp -rf /etc/skel/* ~ gives error saying no such file or directory
We have to do something about SDDM, try putting a warning up that tells people not to upgrade. Or something like that.
Can't I switch from SDDM to lighdm or gdm3?
Are you able to get to a tty?
Nope but I have chrooted from a live usb
Try
sudo pacman -S lightdm
sudo systemctl enable lightdm.service
I just updated KDE and restarted it. Couldn't find any irregularities.
Getting an error saying failed to enable unit, file /etc/systemd/system/display-manager.service already exists and is a symlink to /usr/lib/systemd/system/sddm-plymouth.service
Oh I forgot type
sudo systemctl disable sddm-plymouth.service
Done. I will try to reboot!
As soon as SDDM works again (Probobly a few days from now) try to swich back, running KDE with LightDM is not reccomended. But it will have to do.
Alright! My PC is getting rebooted right now. Its stuck on a black screen but hopefully it will move past it and not be stuck like with sddm.
Lets hope sddm did not break anything else.
Hopefully. All the breakage seems to be confined within the home directory as I reinstalled garuda (without formatting home ofcourse) and the same problem occured
I will have to wait before relesing a beta build of kde-multimedia
Lightdm is also not launching
