Recent libvpx update breaks wallpaper-engine-kde and syncthing tray
  Kernel: 6.7.0-3-cachyos arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-linux
    root=UUID=8a69f047-feee-46cf-81a1-d299eb173883 rw rootflags=subvol=@
    sysrq_always_enabled=1 mitigations=off amd_pstate=active
    amdgpu.ppfeaturemask=0xffffffff tsc=reliable clocksource=tsc nowatchdog
    nmi_watchdog=0 initrd=@\boot\initramfs-linux-cachyos.img
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
  Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
    UEFI: American Megatrends v: P5.10 date: 10/20/2022
    serial: <filter> charge: 50% (should be ignored) rechargeable: yes
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3341 high: 3600 min/max: 550/4687 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3595 2: 3599 3: 3600
    4: 3597 5: 550 6: 3595 7: 3597 8: 3595 9: 3599 10: 3593 11: 3593 12: 3590
    bogomips: 88807
    vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: DP-1,DP-2,HDMI-A-2 empty: HDMI-A-1
    bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
    gpu: amdgpu d-rect: 4980x2513 display-ID: 0
  Monitor-1: DP-1 pos: bottom-r res: 2048x864 size: N/A modes: N/A
  Monitor-2: DP-2 pos: primary,top-left res: 1396x785 size: N/A modes: N/A
  Monitor-3: HDMI-A-2 pos: middle-c res: 1536x864 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
    navi22 LLVM 16.0.6 DRM 3.56 6.7.0-3-cachyos) device-ID: 1002:73df
    memory: 11.72 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.3.274 layers: 21 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.3.3-arch1.1
    device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 23.3.3-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28
  Device-2: Sony INZONE H9 / H7
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:3 chip-ID: 054c:0e53
    class-ID: 0a00
  API: ALSA v: k6.7.0-3-cachyos status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
  Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
  IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Edimax Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 7392:c611
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: yes pairing: yes class-ID: 6c0104
  Local Storage: total: 3.64 TiB used: 3.7 TiB (101.8%)
    model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 731120WD temp: 40.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 38.9 C
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
    used: 540.02 GiB (58.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 37.4 MiB (12.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: zram size: 31.26 GiB used: 4.29 GiB (13.7%)
  System Temperatures: cpu: 55.5 C mobo: 36.0 C gpu: amdgpu temp: 55.0 C
    mem: 58.0 C
  Fan Speeds (rpm): cpu: 0 fan-2: 2030 fan-3: 0 fan-4: 0 fan-5: 0
    gpu: amdgpu fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.18 vbat: 3.28 gpu: amdgpu watts: 29.00
  Processes: 667 Uptime: 1h 9m wakeups: 0 Memory: total: 32 GiB
  available: 31.26 GiB used: 16.59 GiB (53.1%) Init: systemd v: 255
  Packages: 2725 pm: pacman pkgs: 2682 libs: 614 tools: octopi,paru,yay
  pm: appimage pkgs: 0 pm: flatpak pkgs: 43 Shell: fish v: 3.7.0
  running-in: alacritty inxi: 3.3.31
Garuda (2.6.22-1):
  System install date:     2024-01-11
  Last full system update: 2024-01-26 ↻
After a recent update, both wallpaper-engine-kde and synching tray from the chaotic aur seem to break.
I was able to track the breakage of these six packages from my update.
ffmpeg4.4 lib32-libvpx libavif libvpx qt5-webengine rav1e
I noticed both wallpaper engine and syncing were complaining about not being able to find older versions of libvpx, so I tried downgrading it (which led me to downgrade the other five packages)
syncthingtray: error while loading shared libraries: libvpx.so.8: cannot open shared object file: No such file or directory
 pacman -Qi libvpx
Version         : 1.14.0-1
Description     : VP8 and VP9 codec
Architecture    : x86_64
URL             : https://www.webmproject.org/
Licenses        : custom:BSD
Groups          : None
Provides        : libvpx.so=9-64
I reported this both on the wallpaper-engine-kde and sything-tray issue trackers, but
I was told I was better off reporting this to Garuda devs as it is a Garuda/arch issue.
Try other kernel. Reboot.
no luck still same error
EDIT: very strange I restored a snapshot to before the update.
I then tried to update again, this time I got the extra.db mirror errors everyone been getting so I did a update remote fix which fxed the issue and updated the system… and now its working
I guess something got screwy with the mirrors and it didn’t apply the update correctly? (if that can even happen) both wallpaper-engine and synchingtray work now
I’ve pushed the rebuilds for the kde wallpaper plugin and syncthingtray. In general, you can of course rebuild these packages yourself, they are just AUR packages after all.
Yeah i tried rebuilding the aur packages to and it didn’t help. I think something went screwy with the update (could even be all the downgrading, package skipping tomfolory I did I know I know not a good idea, but when have my ideas ever been a good idea lol) and re doing the update helped. Or I could of gotten lucky with the timing and got the rebuilds lol
