Hello,
I'm studying for the a networking certification and trying to access cisco routers & switches via serial to console with a usb to DB9 adapter. It works for about 30 seconds and then something I can only describe as junk data keeps showing up. I've tried using putty and minicom through terminal and find much more success with minicom. Searching on the web I've found indicators that it's a font problem so I uninstalled most of my fonts with no avail- may have been coincidental but it worked way worse -I reinstalled them since I'm a noob and don't know what else I may have inadvertently broken I am using the newest PL2303 usb to DB9 serial adapter and I tried with an older version too. I've also tried different USB ports and 4 different cisco devices with similar outcomes every time. The cable works with Win 11 and Win 10 (after installing necessary drivers). Also I didn't find anything have checked Octopi for anything pl2303 related. I'm newish to linux and very new to Arch based systems (about a month lol) so hopefully I'm overlooking something simple. Thanks for any support and much appreciation to the community as a whole!
An example of the feedback I get while I'm not even typing:
RTR-B>~@@@@
% Unknown command or computer name, or unable to find computer address
RTR-B>
RTR-B>MAW0C0B
Translating "MAW0C0B"...domain server (255.255.255.255)
Here's what I sometimes get while typing:
%Unwnomr omer ,r x����x�����x������������x���������
Eventually it just becomes non responsive. Sometimes it works for 30 seconds and sometimes not at all.
The minicom settings I use are as follows (I've tried all 3 available baud rates and playing with other settings with less success) I have also used the same settings in putty- The most confusing thing is that it kind of works but fails at seemingly random intervals.
A - Serial Device : /dev/ttyUSB0 |
| B - Lockfile Location : /var/run |
| C - Callin Program : |
| D - Callout Program : |
| E - Bps/Par/Bits : 9600 8N1 |
| F - Hardware Flow Control : Yes |
| G - Software Flow Control : No |
| H - RS485 Enable : No |
| I - RS485 Rts On Send : No |
| J - RS485 Rts After Send : No |
| K - RS485 Rx During Tx : No |
| L - RS485 Terminate Bus : No |
| M - RS485 Delay Rts Before: 0 |
| N - RS485 Delay Rts After : 0
dmesg grep tty gives me:
[ 6.919905] systemd[1]: Created slice Slice /system/getty.
[ 7.966303] usb 1-1.3: pl2303 converter now attached to ttyUSB0
[ 13.918236] audit: type=1006 audit(1646304592.097:87): pid=2847 uid=0 old-auid=429496
7295 auid=966 tty=(none) old-ses=4294967295 ses=1 res=1
[ 13.918242] audit: type=1300 audit(1646304592.097:87): arch=c000003e syscall=1 succes
s=yes exit=3 a0=9 a1=7ffd175207c0 a2=3 a3=0 items=0 ppid=1 pid=2847 auid=966 uid=0 gid=0
euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr
/lib/systemd/systemd" key=(null)
[ 26.276256] audit: type=1300 audit(1646304604.455:122): arch=c000003e syscall=321 suc
cess=yes exit=26 a0=5 a1=7ffd71711120 a2=80 a3=7ffd71711120 items=0 ppid=1 pid=690 auid=
4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=429496
7295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
[ 5139.565252] audit: type=1300 audit(1646309718.149:319): arch=c000003e syscall=321 suc
cess=yes exit=27 a0=5 a1=7ffd71711120 a2=80 a3=7ffd71711120 items=0 ppid=1 pid=690 auid=
[ 8739.673004] audit: type=1300 audit(1646313318.321:323): arch=c000003e syscall=321 suc
[10539.727315] audit: type=1300 audit(1646315118.405:325): arch=c000003e syscall=321 suc
[13284.457447] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[13284.457782] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[13284.567107] pl2303 ttyUSB0: pl2303_set_control_lines - failed: -19
[13284.567112] pl2303 ttyUSB0: error sending break = -19
[13284.567266] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0
[13284.588709] audit: type=1131 audit(1646317863.339:327): pid=1 uid=0 auid=4294967295 s
es=4294967295 msg='unit=gpsdctl@ttyUSB0 comm="systemd" exe="/usr/lib/systemd/systemd" ho
stname=? addr=? terminal=? res=success'
[13304.235233] usb 3-4: pl2303 converter now attached to ttyUSB0
[13304.330180] audit: type=1130 audit(1646317883.081:328): pid=1 uid=0 auid=4294967295 s
[14139.781956] audit: type=1300 audit(1646318718.569:380): arch=c000003e syscall=321 suc
[15334.771974] pl2303 ttyUSB0: pl2303_set_control_lines - failed: -19
[15334.771986] pl2303 ttyUSB0: error sending break = -19
[15334.772067] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0
[15334.811402] audit: type=1131 audit(1646319913.651:457): pid=1 uid=0 auid=4294967295 s
Finally, my system is as follows:
Kernel: 5.16.11-zen1-2-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=05585052-6be0-43ce-8d5b-1679bbda1d64 rw rootflags=subvol=@
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: B75M-D3H v: x.x serial: <superuser required>
UEFI: American Megatrends v: F15 date: 10/23/2013
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
status: Discharging
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3533 high: 3762 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3489 2: 3450 3: 3762
4: 3645 5: 3649 6: 3039 7: 3613 8: 3624 bogomips: 54277
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: AMD Bonaire XT [Radeon HD 7790/8770 / R7 360 R9 260/360 OEM]
vendor: ASUSTeK driver: radeon v: kernel alternate: amdgpu pcie: gen: 2
speed: 5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1,DVI-I-1 bus-ID: 01:00.0
chip-ID: 1002:665c class-ID: 0300
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa gpu: radeon
Screen-1: 0 s-res: 3640x1920 s-dpi: 120 s-size: 768x405mm (30.2x15.9")
s-diag: 868mm (34.2")
Monitor-1: DVI-0 mapped: DVI-D-1 pos: primary,top-left model: HP V27i
serial: <filter> built: 2021 res: 1080x1920 hz: 60 dpi: 82 gamma: 1.2
size: 336x598mm (13.2x23.5") diag: 686mm (27") ratio: 16:9 modes:
Monitor-2: HDMI-0 mapped: HDMI-A-1 pos: primary,bottom-r
model: LG (GoldStar) 32GK850G serial: <filter> built: 2014 res: 2560x1440
hz: 60 dpi: 109 gamma: 1.2 size: 598x336mm (23.5x13.2")
diag: 801mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
OpenGL: renderer: AMD BONAIRE (DRM 2.50.0 5.16.11-zen1-2-zen LLVM 13.0.1)
v: 4.5 Mesa 21.3.7 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
Device-2: AMD Tobago HDMI Audio [Radeon R7 360 / R9 OEM]
vendor: ASUSTeK R7260X-DC2OC-2GD5 driver: snd_hda_intel v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 1002:aac0 class-ID: 0403
Sound Server-1: ALSA v: k5.16.11-zen1-2-zen running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-2: TP-Link Archer T3U [Realtek RTL8812BU] type: USB
driver: rtl88x2bu bus-ID: 3-3.2:4 chip-ID: 2357:012d class-ID: 0000
IF: wlp0s20u3u2 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-3.1.3:5 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 931.51 GiB used: 48.71 GiB (5.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
used: 48.71 GiB (5.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.57 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 52.0 C
Processes: 301 Uptime: 3h 56m wakeups: 31 Memory: 15.57 GiB
used: 3.57 GiB (22.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1618 lib: 459 Shell: fish
v: 3.3.1 running-in: yakuake inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-02-14
Last full system update: 2022-03-03
Snapshots: Timeshift (maybe)
