Hello.
I notice that my battery laptop is decreasing a lot. Is there a way how to recalibrating the laptop battery or increasing the battery health?
I steadly deacreasing and now it on alarming 30%. I don't know how I do it before, because my battery health increasing again to normal but now it's on 30%.
inxi -Fxxxza
System: Kernel: 5.12.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=8c19f2fb-ef8b-4358-af82-e00062ba02b4 rw
systemd.unified_cgroup_hierarchy=1 resume=UUID=213f8c6e-971b-4a37-8a60-e6051978ab6a loglevel=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: ASUSTeK product: X550IU v: 1.0 serial:
Mobo: ASUSTeK model: X550IU v: 1.0 serial: UEFI: American Megatrends v: X550IU.308 date: 04/19/2019
Battery: ID-1: BAT0 charge: 11.4 Wh (98.3%) condition: 11.6/38.5 Wh (30.0%) volts: 14.8 min: 14.8 model: ASUSTeK X550A30
type: Li-ion serial: N/A status: Charging cycles: 20
CPU: Info: Quad Core model: AMD FX-9830P RADEON R7 12 COMPUTE CORES 4C+8G bits: 64 type: MCP arch: Excavator
family: 15 (21) model-id: 65 (101) stepping: 1 microcode: 600611A cache: L2: 1024 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 23953
Speed: 3479 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 3479 2: 3472 3: 3440 4: 3402
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Wani [Radeon R5/R6/R7 Graphics] vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 00:01.0 chip-ID: 1002:9874 class-ID: 0300
Device-2: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: ASUSTeK driver: amdgpu
v: kernel bus-ID: 03:00.0 chip-ID: 1002:67ef class-ID: 0380
Device-3: Realtek USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus-ID: 1-1.3:4 chip-ID: 0bda:57de
class-ID: 0e02 serial:
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD CARRIZO (DRM 3.40.0 5.12.5-zen1-1-zen LLVM 11.1.0) v: 4.6 Mesa 21.1.0 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 15h Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.12.5-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Network: Device-1: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave driver: rtl8821ae v: kernel
port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8821 class-ID: 0280
IF: wlp1s0 state: up mac:
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI
modules: r8169 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: down mac:
Bluetooth: Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-1.2:3 chip-ID: 13d3:3414
class-ID: e001 serial:
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no software: no
address:
Drives: Local Storage: total: 476.94 GiB used: 198.99 GiB (41.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power model: SPCC Solid State Disk size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: rev: 61.3 scheme: GPT
Partition: ID-1: / raw-size: 460.56 GiB size: 460.56 GiB (100.00%) used: 198.99 GiB (43.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 460.56 GiB size: 460.56 GiB (100.00%) used: 198.99 GiB (43.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 460.56 GiB size: 460.56 GiB (100.00%) used: 198.99 GiB (43.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw-size: 460.56 GiB size: 460.56 GiB (100.00%) used: 198.99 GiB (43.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: partition size: 16.13 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
ID-2: swap-2 type: zram size: 3.66 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 3.66 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 3.66 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 3.66 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 81.8 C mobo: N/A
Fan Speeds (RPM): cpu: 4000
GPU: device: amdgpu temp: 57.0 C watts: 6.14 device: amdgpu temp: 81.0 C
Info: Processes: 267 Uptime: 37m wakeups: 2 Memory: 14.66 GiB used: 2.75 GiB (18.7%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 11.1.0 Packages: pacman: 1785 lib: 506 Shell: Zsh v: 5.8 running-in: yakuake
inxi: 3.3.04
