Example Post for Garuda Forum
Title: Boot menu delay and screen wake issue on dual boot (Garuda Linux 6.1.6-zen2-1-zen)
Body:
Hi, I’m facing two issues with my Garuda Linux setup:
Boot menu delay: When I power on my laptop, the boot menu takes a long time to appear.
Screen sleep issue: If my screen goes to sleep, it often doesn’t wake up properly. Sometimes I even have to reboot the system to get the display working again.
System setup:
OS: Garuda Linux x86_64
Kernel: Linux 6.1.6-zen2-1-zen
Dual boot with Windows
Troubleshooting tried:
Tried adjusting display settings, but the wake-up problem persists.
Request:
Could you please suggest how to fix the boot menu delay and the screen wake issue? Is this a kernel/driver problem or something related to dual boot configuration?
Kernel: 6.16.0-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=0d0ec8f2-0342-4024-8d58-4471b1701234 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
wm: kwin_wayland tools: avail: hypridle,hyprlock vt: 1 dm: SDDM
Type: Laptop System: HP product: Victus by HP Gaming Laptop 15-fa0xxx v: N/A
Mobo: HP model: 8A4F v: 37.56 serial: <superuser required>
part-nu: 805X2PA#ACJ uuid: <superuser required> UEFI: AMI v: F.29
date: 09/23/2024
ID-1: BAT0 charge: 18.5 Wh (29.2%) condition: 63.3/70.1 Wh (90.3%)
volts: 14.4 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
status: discharging cycles: 64
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
microcode: 0x437
Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 threads: 12 mt: 4 tpc: 2
st: 4 smt: enabled cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32
KiB, 4x64 KiB L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 526 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 526 2: 526 3: 526 4: 526 5: 526 6: 526 7: 526
8: 526 9: 526 10: 526 11: 526 12: 526 bogomips: 59904
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Hewlett-Packard
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:46a3 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 580.76.05 alternate: nouveau,nvidia_drm
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:25a2
display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x2992 built: 2020 res:
mode: 1920x1080 hz: 144 scale: 95% (0.95) to: 2021x1137 dpi: 142 gamma: 1.2
modes: 1920x1080
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a3 memory: 14.92 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 15 device: 0 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: mesa intel v: 25.1.7-arch1.1
device-ID: 8086:46a3 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 Laptop GPU driver: nvidia v: 580.76.05
device-ID: 10de:25a2 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA GA107 High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.16.0-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 13d3:3567
Local Storage: total: 931.51 GiB used: 155.77 GiB (16.7%)
model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 43.9 C scheme: GPT
ID-1: / raw-size: 204.1 GiB size: 204.1 GiB (100.00%)
used: 155.71 GiB (76.3%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 59.6 MiB (19.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 204.1 GiB size: 204.1 GiB (100.00%)
ID-4: /var/log raw-size: 204.1 GiB size: 204.1 GiB (100.00%)
ID-5: /var/tmp raw-size: 204.1 GiB size: 204.1 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2732 fan-2: 2401
Memory: total: 16 GiB note: est. available: 15.28 GiB used: 7.66 GiB (50.1%)
Processes: 366 Power: uptime: 32m states: freeze,mem,disk suspend: s2idle
image: 6.02 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: 2531 pm: dpkg pkgs: 0 pm: pacman pkgs: 2511 libs: 587
tools: octopi,pacseek,paru pm: rpm pkgs: 0 pm: flatpak pkgs: 20 Compilers:
clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.0.2
Garuda (2.7.5-1):
System install date: 2025-03-19
Last full system update: 2025-08-17
20/21 checks run in 0.56 seconds ⌛
Powered by garuda-health 🦅
