Realtek RTL8852CU - 802.11ax USB wifi driver
Are there any drivers support for Realtek Semiconductor Corp. 802.11ax WLAN?
If yes, how do I install it? I’m new to Arch.
How well the driver is supported in Linux is entirely dependent upon the WiFi chip in use in the network adapter. We can’t know which chip is in use, unless you provide us with more information.
Please post the output of the garuda-inxi command, so that we may be able to assist you with your inquiry.
Welcome to the Garuda forum @Lavanhill. :wave: :smiley:
It will be device 3 under network
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: down mac:
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp4s0 state: up mac:
Device-3: Realtek 802.11ax WLAN Adapter driver: N/A type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:21 chip-ID: 0bda:c832
class-ID: 0000 serial:
The only driver that I’m aware of for your adapter is:
Thank you for your help.
