I have an Edimax USB 3.0 AC1200 WiFi dongle, model EW-7822UTC, which is a small (but not micro) dongle device. Previously I had almost the same model in the USB 2.0 micro version, same chipset.
Anyway, it’s connecting to the PC at USB 2.0 speeds, whilst it and the port are both USB 3.0. The blue ones, so yeah, I’m sure it’s not the “wrong” ports. I’ve tried a USB 3.0 hard drive in them and have confirmed that device is coming up as 5GBps. Here’s what happens when I type:
lsusb -t
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=ehci-pci/3p, 480M
|__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/6p, 480M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=ehci-pci/3p, 480M
|__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/8p, 480M
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/15p, 480M
**|__ Port 007: Dev 011, If 0, Class=Vendor Specific Class, Driver=rtw_8822bu, 480M**
|__ Port 009: Dev 006, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 009: Dev 006, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 010: Dev 005, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 010: Dev 005, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 010: Dev 005, If 2, Class=Human Interface Device, Driver=[none], 12M
/: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/6p, 5000M
|__ Port 002: Dev 006, If 0, Class=Mass Storage, Driver=uas, 5000M
See, the hard drive connects at 5GBit. And this is a Lenovo M93p, which has 6 USB 3.0 and 2 USB 2.0 ports (and I know the difference between them; the blue ones are 3.0) so there’s no lack of USB 3.0 connectivity. It’s just odd that so many show up as slow speed ports when I have 6 3.0 ports! It also looks like we have too many ports in total. What’s up with that? Do I need to redetect my USB ports or something?
I must confess, I have an idea what it might be. I did move my install from a Dell Optiplex 3020 that didn’t have as many USB 3.0 ports; is that where the confusion lies? I simply put the SSDs in the new system and it just worked… except maybe it sort of didn’t? It’s also a different chipset (Q87 vs H81) so maybe that could be a problem. Same model processor, though. I guess I just expected it to scan hardware like Windows would and “fix itself.” Is that not how things work? Do I need to initiate something manually?
Kernel: 6.9.9-x64v-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=b1270554-eee9-4e1e-86df-0fc6d4334e01 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop System: LENOVO product: 10A90045US v: ThinkCentre M93p
Mobo: LENOVO model: SHARKBAY v: SDK0E50510 WIN
serial: <superuser required> part-nu: LENOVO_MT_10A9
uuid: <superuser required> BIOS: LENOVO v: FBKTE0AUS date: 12/23/2021
Info: model: Intel Core i5-4590 bits: 64 type: MCP arch: Haswell gen: core 4
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3700 min/max: 800/3700 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3700 2: 3700 3: 3700 4: 3700 bogomips: 26340
Device-1: NVIDIA GP107 [GeForce GTX 1050] driver: nvidia v: 560.35.03
alternate: nvidiafb,nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:1c81 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
Screen-1: 0 s-res: 1920x1080 s-dpi: 90 s-size: 542x301mm (21.34x11.85")
s-diag: 620mm (24.41")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Acer XF251Q
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 90 gamma: 1.2
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.295 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1050 driver: nvidia v: 560.35.03
device-ID: 10de:1c81 surfaces: xcb,xlib
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.9.9-x64v-xanmod1-1 status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I217-LM vendor: Lenovo driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Edimax AC1200 MU-MIMO USB3.0 Adapter driver: rtw_8822bu
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:11
chip-ID: 7392:c822 class-ID: 0000 serial: <filter>
IF: wlp0s20u7 state: up mac: <filter>
Local Storage: total: 1.38 TiB used: 1022.41 GiB (72.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T-FORCE 240GB
tech: SSD serial: <filter> fw-rev: 4A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: KLEVV model: NEO N610 SSD 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 7D scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HTS545025B9SA00
size: 232.89 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> scheme: MBR
ID-1: / raw-size: 40 GiB size: 40 GiB (100.00%) used: 29.29 GiB (73.2%)
fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 183.07 GiB size: 180.01 GiB (98.33%)
used: 142.03 GiB (78.9%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-3: /var/log raw-size: 40 GiB size: 40 GiB (100.00%)
used: 29.29 GiB (73.2%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/tmp raw-size: 40 GiB size: 40 GiB (100.00%)
zswap: no
ID-1: swap-1 type: zram size: 7.69 GiB used: 3.17 GiB (41.2%)
System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 20%
Memory: total: 8 GiB available: 7.69 GiB used: 5.1 GiB (66.3%)
Processes: 374 Power: uptime: 1d 16h 3m states: freeze,mem,disk
reboot, suspend, test_resume image: 3.02 GiB services: org_kde_powerdevil,
Packages: 2191 pm: pacman pkgs: 2145 libs: 600 tools: octopi,paru,yay
pm: flatpak pkgs: 46 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date: 2024-06-09
Last full system update: 2024-10-17 ↻
Failed units: upgrade.service
I have an Edimax USB 3.0 AC1200 WiFi dongle, model EW-7822UTC, which is a small (but not micro) dongle device. Previously I had almost the same model in the USB 2.0 micro version, same chipset. Same thing happened.
The issue is that it seems to drop randomly. It’ll work for hours on end, and stay connected most of the day, then sometimes, without warning or much logic, it will drop the connection. Unplugging and replugging usually fixes it, but every once in a great while I might have to restart. It seems to have the proper driver support, rtw_8822bu; and it generally works, just drops randomly, and not really that super-often, but at least a few times a day, and it’s mildly annoying.
