Hi, I am a very new user to both arch linux as well as Garuda KDE I have switched from windows to here hence have zero knowledge about how things work around here. As the title suggest i have been trying to make my Wi-Fi adapter (Archer T2U Nano) getting run on the system but have been unable to do so after trying most of the top solutions over the web such as installing Realtek wifi adapters and downgrading my kernel but i run into some problem no matter what i try. Without this driver i wont be able to update the system through the assistant so if you can please help me out ASAP , really grateful to you for having read this and please forgive any of my mistake done unintentionally.
Thank you.
root=UUID=3b68888c-6e15-481b-8cb8-2ea96d278e2e rw rootflags=subvol=@
Type: Desktop Mobo: Intel model: H61S serial: <superuser required>
BIOS: American Megatrends v: 4.6.5 date: 11/01/2022
Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
desc: 1x6 MiB
Speed (MHz): avg: 3416 high: 3600 min/max: 1600/3600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2866 2: 3600 3: 3600
4: 3600 bogomips: 25544
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics driver: i915
active: VGA-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0152
s-diag: 414mm (16.31")
Monitor-1: VGA-1 model: Acer V193HQV serial: <filter> built: 2010
res: 1366x768 hz: 60 dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06")
diag: 470mm (18.5") ratio: 16:9 modes: max: 1366x768 min: 720x400
device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
inactive: gbm,wayland
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 2500 (IVB
GT1) device-ID: 8086:0152 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: integrated-gpu name: Intel
HD Graphics 2500 (IVB GT1) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:0152 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
Device-2: TP-Link AC600 wireless Realtek RTL8811AU [Archer T2U Nano]
driver: N/A type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-1.1:3 chip-ID: 2357:011e class-ID: 0000 serial: <filter>
IF-ID-1: enp0s29u1u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: OPPO [] driver: rndis_host v: kernel type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.1:30 chip-ID: 22d9:276a
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 2-1.2:4 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0 lmp-v: 6
status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.03 TiB used: 7.97 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 model: SSD 128GB size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD serial: <filter>
fw-rev: XKR scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: Expansion HDD
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 1901 scheme: MBR
ID-1: / raw-size: 115.24 GiB size: 115.24 GiB (100.00%)
used: 7.97 GiB (6.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 115.24 GiB size: 115.24 GiB (100.00%)
ID-3: /var/log raw-size: 115.24 GiB size: 115.24 GiB (100.00%)
ID-4: /var/tmp raw-size: 115.24 GiB size: 115.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 213 Uptime: 41m wakeups: 0 Memory: total: 8 GiB
available: 7.65 GiB used: 4.32 GiB (56.5%) Init: systemd v: 254
pm: pacman pkgs: 1772 libs: 522 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2024-01-08
Last full system update: 2024-01-08
