1. Pre-Check Actions
- Searched:
- Arch Wiki
- Garuda Forum
- Kernel.org firmware Git
- Read:
2. Issue Description
After fresh Garuda Linux install, Bluetooth fails to initialize due to missing firmware for Realtek RTL8761BU. Manual firmware installation didn’t resolve the issue.
3. Technical Details
System Info (Full garuda-inxi):
root=UUID=48d3a397-c95a-42ab-a873-b9314bb62bcb rw rootflags=subvol=@
quiet rd.luks.uuid=48242417-f0b5-4d0a-8212-ba04cd2c83d9
rd.luks.uuid=3145a088-153a-4219-b51e-9e9c837f1c13
resume=/dev/mapper/luks-3145a088-153a-4219-b51e-9e9c837f1c13 loglevel=3
Desktop: KDE Plasma v: 6.4.0 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Desktop Mobo: ASRock model: B550M Pro4 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: P3.20
date: 09/27/2023
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 3
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1750 min/max: 566/4471 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1750 2: 1750 3: 1750
4: 1750 5: 1750 6: 1750 7: 1750 8: 1750 9: 1750 10: 1750 11: 1750 12: 1750
bogomips: 83839
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 575.64 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2
bus-ID: 06:00.0 chip-ID: 10de:2504 class-ID: 0300
d-rect: 3840x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: ViewSonic VA2261 Series
serial: <filter> built: 2019 res: mode: 1920x1080 hz: 60 scale: 105% (1.05)
to: 1829x1029 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55")
diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-2 pos: right model: MSI MAG 275F serial: <filter>
built: 2024 res: mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 81 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 685mm (27") ratio: 16:9 modes:
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64
API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 575.64 device-ID: 10de:2504
surfaces: N/A
Device-1: NVIDIA GA106 High Definition Audio vendor: Gigabyte
bus-ID: 06:00.1 chip-ID: 10de:228e class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: FIFINE Microphones Microphone
lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 3142:0688 class-ID: 0300
API: ALSA v: k6.15.3-zen1-1-zen status: kernel-api with: aoss
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: ROBOT_UXERROR state: unknown speed: N/A duplex: N/A mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7.1:6 chip-ID: 0bda:8771
Local Storage: total: 2.11 TiB used: 14.73 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: A-Data model: LEGEND 710
lanes: 4 tech: SSD serial: <filter> fw-rev: VC2SAD01 temp: 31.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-08Z10
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A05 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 3.0
size: 57.75 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
used: 14.73 GiB (1.6%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-48242417-f0b5-4d0a-8212-ba04cd2c83d9
used: 776 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
ID-4: /var/log raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 253:1
mapped: luks-3145a088-153a-4219-b51e-9e9c837f1c13
ID-2: swap-2 type: zram size: 31.26 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.8 C mobo: N/A
Memory: total: 32 GiB available: 31.26 GiB used: 4.77 GiB (15.3%)
Processes: 378 Power: uptime: 1h 0m states: freeze,mem,disk suspend: deep
Packages: pm: pacman pkgs: 1754 libs: 524 tools: octopi,paru Compilers:
clang: 20.1.6 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date: 2025-06-23
Last full system update: 2025-06-23
Error from dmesg:
[ 5.746286] bluetooth hci0: Direct firmware load for rtl_bt/rtl8761bu_fw.bin failed with error -2 [ 5.746289] Bluetooth: hci0: RTL: firmware file rtl_bt/rtl8761bu_fw not found
4. Steps Taken
| Attempt | Command/Result |
| Installed firmware | sudo wget -O /lib/firmware/rtl_bt/rtl8761bu_fw.bin <URL> → File saved |
| Verified permissions | -rw-r--r-- 1 root root 44484 Jun 23 20:57 /lib/firmware/rtl_bt/rtl8761bu_fw.bin |
| Reset modules | sudo rmmod btusb && sudo modprobe btusb → No change |
Checked rfkill |
Bluetooth: Soft blocked: no |
| Updated initramfs | sudo update-initramfs -u → Still fails |
