Hi,
I’m having trouble with my USB Bluetooth adapter on Garuda Linux. My adapter is Realtek RTL8761B/BU (USB ID 0bda:8771) and my headphones are Sony WH-CH520. The headphones are detected in bluetoothctl scan on, but pairing and connecting always fail. They work fine with my phone, so the problem seems specific to this setup.
What happens:
bluetoothctl pair <MAC>fails withorg.bluez.Error.AuthenticationCanceledbluetoothctl connect <MAC>fails withorg.bluez.Error.Failed br-connection-canceled- Logs show
[SIGNAL] BREDR.Disconnected - org.bluez.Reason.Local, Connection terminated by local host
Steps I’ve tried:
sudo systemctl restart bluetooth
systemctl --user restart pipewire pipewire-pulse wireplumber
bluetoothctl remove
sudo modprobe -r btusb && sudo modprobe btusb
rfkill list bluetooth
- Verified headphones work with other devices
- Checked that adapter is detected by
lsusbandbluetoothctl list - Confirmed kernel modules loaded:
btusb,btrtl,btintel,btbcm,btmtk,bluetooth
Additional details:
- PipeWire 1.4.8 with
pipewire-pulserunning - BlueZ 5.84
- Kernel: latest Garuda kernel
- Headphones: WH-CH520
Questions:
- How can I troubleshoot why the adapter sees the headphones but cannot pair/connect?
- What additional logs or commands should I provide to help diagnose this?
- Any tips from users who have successfully paired WH-CH520 with RTL8761B/BU on Garuda?
Output of garuda-inxi:
Kernel: 6.17.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=3b2c00da-0d18-42e0-b656-b4389d7ada49 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A info: frameworks v: 6.19.0
Mobo: ASUSTeK model: PRIME B550M-A v: Rev X.0x
UEFI: American Megatrends v: 3607 date: 03/22/2024
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA500012
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2991 min/max: 404/4466 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2991 2: 2991 3: 2991
4: 2991 5: 2991 6: 2991 7: 2991 8: 2991 9: 2991 10: 2991 11: 2991 12: 2991
bogomips: 93597
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 0b:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 41.0 C
compositor: kwin_wayland driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Dell E2723HN serial: <filter> built: 2021 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.4-arch1.2
renoir ACO DRM 3.64 6.17.1-zen1-1-zen) device-ID: 1002:1638
memory: 3.91 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.328 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.4-arch1.2
device-ID: 1002:1638 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.4-arch1.2 (LLVM
Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:1637 class-ID: 0403
lanes: 16 bus-ID: 0b:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.17.1-zen1-1-zen status: kernel-api tools: N/A
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:5 chip-ID: 0bda:8771
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
Local Storage: total: 465.76 GiB used: 106.13 GiB (22.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: EXCERIA SSD
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFA12.b temp: 40.9 C
ID-1: / raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
used: 106.13 GiB (22.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
ID-4: /var/log raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
ID-5: /var/tmp raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.47 GiB used: 12 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.5 C mobo: N/A gpu: amdgpu temp: 42.0 C
Memory: total: 12 GiB note: est. available: 11.47 GiB used: 5.92 GiB (51.6%)
Processes: 380 Power: uptime: 44m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 4.56 GiB services: org_kde_powerdevil,
Packages: 1345 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr
pkgs: 0 pm: pacman pkgs: 1335 libs: 336 tools: octopi,paru pm: flatpak
pkgs: 10 Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish
v: 4.1.2 running-in: konsole inxi: 3.3.39
Garuda (2.11.1-1):
System install date: 2025-09-30
Garuda release: 250916
Last full system update: 2025-10-14
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard
23/24 checks run in 1.02 seconds ⌛
Powered by garuda-health 🦅
