Hello,
I've just installing garuda linux,
the problem is my USB wifi status is enabled but wifi list not showing
please help
Hello,
please help
Again !
Hello.
inxi -Faz
How?
I move it from Issues & Assistance to Networking Support
And
hi,
sorry, here is inxi -Faz
╭─jagad@jagad in ~ took 11m53s
╰─λ inxi -Faz
System: Kernel: 5.15.3-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=981e39f7-5604-4e1e-9705-bc3768afe27a rw
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: ECS model: H61H2-MV v: 1.0 serial: <filter> BIOS: American Megatrends v: 4.6.5
date: 11/27/2013
CPU: Info: Quad Core model: Intel Core i7-2600 bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
stepping: 7 microcode: 2F cache: L2: 8 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 54273
Speed: 2284 MHz min/max: 1600/3800 MHz Core speeds (MHz): 1: 2284 2: 3672 3: 3300 4: 3645 5: 3685 6: 1729
7: 2491 8: 3653
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Elite Systems driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0300
Device-2: Microdia Integrated Camera type: USB driver: uvcvideo bus-ID: 2-1.6:3 chip-ID: 0c45:64ab
class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.6x8.0") s-diag: 338mm (13.3")
Monitor-1: VGA1 res: 1024x768 hz: 60
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1) v: 3.3 Mesa 21.2.5 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Elite Systems driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.3-zen1-1-zen running: yes
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Elite Systems driver: r8169 v: kernel port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB driver: r8188eu bus-ID: 1-1.4:4
chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
IF: wlp0s26u1u4 state: down mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 45.64 GiB (4.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EURX-73C57Y0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: MBR
Partition: ID-1: / raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 45.64 GiB (4.9%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 45.64 GiB (4.9%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 45.64 GiB (4.9%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-4: /var/tmp raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 45.64 GiB (4.9%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-1: swap-1 type: zram size: 6.72 GiB used: 2.8 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 54.0 C mobo: 27.8 C
Info: Processes: 280 Uptime: 18m wakeups: 0 Memory: 6.72 GiB used: 2.45 GiB (36.4%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1439 lib: 349 Shell: Bash v: 5.1.8
running-in: gnome-terminal inxi: 3.3.08
If you include terminal outputs in your post please use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
Please install the following driver from the AUR using an AUR helper:
8188fu-kelebek333-dkms-git
https://aur.archlinux.org/packages/8188fu-kelebek333-dkms-git/
Welcome to Garuda.
thank before...could you please post a step-by-step command ?
because i'm newbie..
Our forum tries to encourage our users to learn how to do things for themselves. I have provided you with the name pf the correct driver you need to install. You simply need to search for how to install a package from the AUR.
Search using your favorite search engines the terms:
"How to use an AUR helper Arch Linux"
"How to install a package from the Arch Linux AUR"
You will feel far more empowered learning how to do for yourself, rather than expecting to be spoon fed every answer,
Good luck on your Arch awareness journey.
Hello,
thanks for your advice.
Here is the error when makepkg -si
(1/1) checking keys in keyring [-------------------------------------------] 100%
(1/1) checking package integrity [-------------------------------------------] 100%
(1/1) loading package files [-------------------------------------------] 100%
(1/1) checking for file conflicts [-------------------------------------------] 100%
8188fu-kelebek333-dkms-git: /etc/modprobe.d/rtl8188fu.conf exists in filesystem
8188fu-kelebek333-dkms-git: /usr/lib/firmware/rtlwifi/rtl8188fufw.bin exists in filesystem
==> WARNING: Failed to install built package(s).
From those errors I assume you already installed one of the alternate realtek drivers for this adapter. You must uninstall the driver you installed before. How did you install the driver? Did you install it from source? Once the other driver is uninstalled the install of 8188fu-kelebek333-dkms-git
should be able to proceed.
I would use am AUR helper such as paru for installing packages from the AUR. Paru should be installed by default. You simply need to enable paru in the package manager Octopi. This can be enabled in Octopi's options, and then ypu can use the Octopi GUI package manager for installing and uninstalling packages from the AUR. I'm sure you will find the GUI method much easier if you are unfamiliar with the terminal.
Okay thank you.
I try removing the conflicted files and run makepkg -si again
╭─jagad@jagad in repo: rtl8821ce-dkms-git on master [!?] took 4ms
╰─λ makepkg -si
==> Making package: rtl8821ce-dkms-git 1.0.5.r130.gca204c6-1 (Sel 23 Nov 2021 10:43:46 )
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
-> Updating rtl8821ce git repo...
Fetching origin
==> Validating source files with sha256sums...
rtl8821ce ... Skipped
==> Extracting sources...
-> Creating working copy of rtl8821ce git repo...
Switched to a new branch 'makepkg'
==> Starting pkgver()...
==> WARNING: A package has already been built, installing existing package...
==> Installing package rtl8821ce-dkms-git with pacman -U...
loading packages...
warning: rtl8821ce-dkms-git-1.0.5.r130.gca204c6-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) rtl8821ce-dkms-git-1.0.5.r130.gca204c6-1
Total Installed Size: 30,17 MiB
Net Upgrade Size: 0,00 MiB
(1/1) checking keys in keyring [-----------------------------------] 100%
(1/1) checking package integrity [-----------------------------------] 100%
(1/1) loading package files [-----------------------------------] 100%
(1/1) checking for file conflicts [-----------------------------------] 100%
(1/1) checking available disk space [-----------------------------------] 100%
(1/2) Performing snapper pre snapshots for the following configurations...
==> root: 33
(2/2) Remove upgraded DKMS modules
==> dkms remove --no-depmod rtl8821ce/1.0.5.r130.gca204c6 -k 5.15.4-zen1-1-zen
(1/1) reinstalling rtl8821ce-dkms-git [-----------------------------------] 100%
( 1/10) Arming ConditionNeedsUpdate...
( 2/10) Install DKMS modules
==> dkms install --no-depmod rtl8821ce/1.0.5.r130.gca204c6 -k 5.15.4-zen1-1-zen
==> depmod 5.15.4-zen1-1-zen
==> ERROR: Missing 5.15.4-arch1-1 kernel modules tree for module rtl8821ce/1.0.5.r130.gca204c6.
( 3/10) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 5.15.4-zen1-1-zen
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [filesystems]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: wd719x
==> WARNING: Possibly missing firmware for module: xhci_pci
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
( 4/10) Foreign/AUR package notification
( 5/10) Orphaned package notification...
rebuild-detector 4.1.6-2
( 6/10) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/paru.conf.pacnew
Please check and merge
( 7/10) Updating pkgfile database...
( 8/10) Checking which packages need to be rebuilt
( 9/10) Performing snapper post snapshots for the following configurations...
==> root: 34
(10/10) Syncing all file systems...
Now reboot, and check functionality.
Run:
(ping -c5 google.com 2>&1 >/dev/null) && echo "*** Google IPv4 Connection established via Domain Name Address ***" || echo "*** Google IPv4 Connection unreachable via Domain Name Address***" ; (ping -c5 google.com 2>&1 >/dev/null) && echo "*** Google IPv4 Connection established via IP Address" || echo "*** Google IPv4 Connection unreachable via IP Address ***"; (ping -c5 2607:f8b0:4009:800::200e 2>&1 >/dev/null) && echo "*** Google IPv6 Connection established via IP Address ***" || echo "*** Google IPv6 network connection unreachable via IP Address ***"
Post results please.
Dude, you installed a completely different driver than I requested you to install.
Please simplify things for yourself and follow my instructions to use the GUI installation method I already posted.
Enable paru
as your default AUR helper in Octopi. Then search in Octopi for 8188fu-kelebek333-dkms-git
and install it through octopi.
N.B I’m not the OP btw, just (hopefully) helpful bystander
Did you mean (without the ( & ) as term doesn’t like that & I added 3 missing *s) :
ping -c5 google.com 2>&1 >/dev/null && echo "*** Google IPv4 Connection established via Domain Name Address ***" || echo "*** Google IPv4 Connection unreachable via Domain Name Address***" ; ping -c5 google.com 2>&1 >/dev/null && echo "*** Google IPv4 Connection established via IP Address ***" || echo "*** Google IPv4 Connection unreachable via IP Address ***"; ping -c5 2607:f8b0:4009:800::200e 2>&1 >/dev/null && echo "*** Google IPv6 Connection established via IP Address ***" || echo "*** Google IPv6 network connection unreachable via IP Address ***"
FWIW (seems it’s still flawed):
ping: connect: Network is unreachable
