Hello,
I Just install Garuda Linux and through out the installation and after install my WiFi adapter which is Tp-link TL-WN725N was working fine, however after few minutes it start loosing signal and every time after pc start it works fine and then signal goes to 0% for every nearby wifi. here is inxi -Faz
Kernel: 5.19.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8aa43813-96df-49df-a22f-0994b48419c0 rw rootflags=subvol=@
resume=UUID=083fba5b-8fba-4d3e-9858-3cda312585b3 loglevel=3
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Desktop Mobo: ASUSTeK model: A68HM-K v: Rev X.0x serial: <filter>
UEFI-[Legacy]: American Megatrends v: 1503 date: 03/10/2016
Info: model: AMD A4-6300 APU with Radeon HD Graphics socket: FM2 (FM2+)
note: check bits: 64 type: MT MCP arch: Piledriver level: v3 built: 2012-13
process: GF 32nm family: 0x15 (21) model-id: 0x13 (19) stepping: 1
microcode: 0x6001119
Topology: cpus: 1x cores: 2 smt: enabled cache: L1: 96 KiB desc: d-2x16
KiB; i-1x64 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 1800 min/max: 1800/3700 boost: enabled
base/boost: 3700/3700 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.3 V ext-clock: 100 MHz cores: 1: 1800 2: 1800 bogomips: 14763
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Richland [Radeon HD 8370D] vendor: ASUSTeK driver: radeon
v: kernel alternate: amdgpu arch: TeraScale-3 code: Northern Islands
process: TSMC 32nm built: 2010-13 ports: active: VGA-1 empty: DVI-D-1
bus-ID: 00:01.0 chip-ID: 1002:9998 class-ID: 0300
alternate: fbdev,vesa gpu: radeon display-ID: :0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: VGA-1 mapped: VGA-0 model: Acer P166HQL serial: <filter>
built: 2015 res: 1366x768 hz: 60 dpi: 101 gamma: 1.2
max: 1366x768 min: 640x480
OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.19.9-zen1-1-zen LLVM 14.0.6)
v: 4.3 Mesa 22.1.7 compat-v: 3.1 direct render: Yes
Device-1: AMD FCH Azalia vendor: ASUSTeK AM1I-A driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.19.9-zen1-1-zen running: yes
vendor: ASUSTeK AM1I-A driver: N/A modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 2-1:2 chip-ID: 0bda:8179 class-ID: 0000
IF: wlp0s19f2u1 state: down mac: <filter>
IF-ID-1: enp0s18f2u5 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: OPPO SDM712-MTP _SN:CBE5A43D type: USB driver: rndis_host
v: kernel bus-ID: 1-5:5 chip-ID: 22d9:2766 class-ID: 0a00 serial: <filter>
Report: bt-service: disabled note: tool can't run
Local Storage: total: 931.51 GiB used: 7.53 GiB (0.8%)
model: WD10EZEX-08WN4A0 family: Blue size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 1A02 temp: 38 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 4d 23h cycles: 103
ID-1: / raw-size: 457.4 GiB size: 457.4 GiB (100.00%) used: 7.29 GiB (1.6%)
fs: btrfs block-size: 4096 B dev: /dev/sda5 maj-min: 8:5
ID-2: /boot raw-size: 350 MiB size: 349.3 MiB (99.79%) used: 248.1 MiB
(71.0%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 457.4 GiB size: 457.4 GiB (100.00%) used: 7.29 GiB
(1.6%) fs: btrfs block-size: 4096 B dev: /dev/sda5 maj-min: 8:5
ID-4: /var/log raw-size: 457.4 GiB size: 457.4 GiB (100.00%) used: 7.29
GiB (1.6%) fs: btrfs block-size: 4096 B dev: /dev/sda5 maj-min: 8:5
ID-5: /var/tmp raw-size: 457.4 GiB size: 457.4 GiB (100.00%) used: 7.29
ID-1: swap-1 type: zram size: 3.04 GiB used: 258.8 MiB (8.3%)
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 24.0 C mobo: N/A gpu: radeon temp: 9.0 C
Processes: 177 Uptime: 24m wakeups: 0 Memory: 3.04 GiB used: 1.39 GiB
(45.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1148 libs: 302
tools: octopi,paru Shell: Bash (su) v: 5.1.16 running-in: konsole
inxi: 3.3.21
I am new to Arch linux so sorry in advanced if i messed something up and didnt know about it and thanks for helping and for your time.
