Realtek 8852BE not working properly
I just got a new laptop with a RTK8852BE wifi card, and after installing Garuda on it (what else would you use amirite?), I noticed that my wifi is behaving very strangely. I can connect to networks just fine, but after connecting the internet is basically unusable, any page will take 30+ seconds to open, and it often won't get rendered properly, I tested this 3 ways, at work with a 5GHz connection, at home with a 2.4GHz connection, and I tried it with USB tethering from my phone, and I had the same result each time, so I'm assuming the Realtek card might not be the only issue. I tried installing both variants of rtk89 from AUR, as well as directly from GH, and it changed nothing, additionally, Garuda Network Assistant doesn't detect any drivers for the card (tho I'm assuming this is normal as the same thing happens on my PC where everything works normally).
First time posting here, so I'm sorry if I missed something, but I tried looking through both linux-related forums and arch-related, and I found nothing that solves my issue, so this was my last resort. Let me know if you need any additional info, and thank you in advance
  Kernel: 6.3.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=11382682-9837-4fd1-a2da-59190556b19e rw [email protected]
    loglevel=3 ibt=off
  Type: Laptop System: LENOVO product: 82SN v: IdeaPad 5 Pro 16ARH7
    serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 Pro 16ARH7
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    UEFI: LENOVO v: J4CN33WW date: 08/29/2022
  ID-1: BAT0 charge: 71.2 Wh (91.3%) condition: 78.0/75.0 Wh (103.9%)
    volts: 16.8 min: 15.4 model: LENOVO AP16L5J type: Li-ion serial: <filter>
    status: discharging cycles: 4
  Info: model: AMD Ryzen 7 6800HS Creator Edition bits: 64 type: MT MCP
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1748 high: 3200 min/max: 1600/4784 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1386 2: 1600
    3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 3200 9: 1600 10: 1600 11: 1395
    12: 3200 13: 1393 14: 1600 15: 1397 16: 1600 bogomips: 102206
  Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, HDMI-A-1 bus-ID: 04:00.0
    chip-ID: 1002:1681 class-ID: 0300 temp: 33.0 C
  Device-2: Luxvisions Innotech Integrated RGB Camera type: USB
    driver: uvcvideo bus-ID: 5-1:2 chip-ID: 30c9:0057 class-ID: fe01
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x09b6 built: 2021
    res: 2560x1600 hz: 60 dpi: 188 gamma: 1.2 size: 345x215mm (13.58x8.46")
    diag: 407mm (16") ratio: 16:10 modes: max: 2560x1600 min: 640x480
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (rembrandt
    LLVM 15.0.7 DRM 3.52 6.3.1-zen1-1-zen) direct-render: Yes
  Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
    bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
  API: ALSA v: k6.3.1-zen1-1-zen status: kernel-api with: aoss
  Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: N/A
    modules: rtw_8852be pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
    bus-ID: 01:00.0 chip-ID: 10ec:b852 class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.81
    bus-ID: 3-3:3 chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
  Report: bt-adapter ID: hci0 rfk-id: 1 state: down
    address: <filter>
  Local Storage: total: 476.94 GiB used: 84.89 GiB (17.8%)
    model: MZAL4512HBLU-00BL2 size: 476.94 GiB block-size: physical: 512 B
    rev: 7L1QHXC7 temp: 21.9 C scheme: GPT
  ID-1: / raw-size: 376.94 GiB size: 376.94 GiB (100.00%)
    used: 84.83 GiB (22.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 61.3 MiB (63.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 376.94 GiB size: 376.94 GiB (100.00%)
  ID-4: /var/log raw-size: 376.94 GiB size: 376.94 GiB (100.00%)
  ID-5: /var/tmp raw-size: 376.94 GiB size: 376.94 GiB (100.00%)
  ID-1: swap-1 type: zram size: 13.34 GiB used: 1.2 MiB (0.0%) priority: 100
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 33.0 C
  Processes: 328 Uptime: 1h 5m wakeups: 1196 Memory: 13.34 GiB
  used: 2.39 GiB (17.9%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1724
  libs: 516 tools: octopi,paru Shell: fish v: 3.6.1 running-in: konsole
  inxi: 3.3.26
  System install date:     2023-05-04
  Last full system update: 2023-05-07
  Failed units:            systemd-vconsole-setup.service
Try other kernel
https://bbs.archlinux.org/viewtopic.php?id=281763
rtw89_8852be
That didn't seem to do much, tho one interesting thing did happen.
I tried 3 other kernel versions:
6.3.1-AMD
6.3.1-arch
6.1.27.1-lts
On 6.3.1-arch and 6.1.27.1-lts the result was identical, it connects very easily but it's effectively unusable, on 6.3.1-AMD however, it wouldn't even detect my WiFi card at all. I tried using USB Tethering just to run garuda-update, maybe it'd help, but it couldn't hold a stable connection for long enough, which again leads me to believe that the issue isn't the wifi card itself, otherwise USB Tethering would run just fine right?
They wrote about black listing some driver in the link, but IDK nothing about this part.
So wait for other or try by yourself, please.
Create a file /etc/modprobe.d/rtw8852be.conf with the following contents:
blacklist rtw_8852be
and reboot.
I'm not a blacklist karate-kid :slight_smile:
Give also a look at:
https://wiki.archlinux.org/title/Kernel_module#Blacklisting
If still not working, this could be the culprit (I expected this to be fixed in kernel 6.3), but there seem to be a workaround (see comment #2, but again, read entirely):
https://bugzilla.kernel.org/show_bug.cgi?id=217207
Edit:
Sorry, I really think you can disregard this post...
Rereading the bug description I see that the problem was different (WiFi was not working at all due to firmware not found).
I hope the other solution/driver, with blacklisting, has better luck.
Thank you for the suggestion, but I just tried something completely different, and it turns out that it's not the wifi card at all.
In my previous laptop, I also used Garuda, and it had a 8821CE or something like that, and it worked perfectly fine, so I took it out, replaced it with the 8852BE in the current one, and the issue persisted, I tried installing the driver for 8821CE and rebooting, nothing. I do have windows in dual boot, and I have secure boot disabled as well as fast startup in windows, but again, the issue definitely doesn't seem related as wifi does actually still work, it's just completely unusable. I would often get DNS related errors when doing things like paru -S *package name* or garuda-update, but it'd eventually start working, same for the browser, it might take a while, but it does connect eventually (most of the time).
If anyone has any other troubleshooting steps I'm open to anything at this point. It's starting to look like it's not a Linux/Arch/Garuda issue at this point and Lenovo did some BS to it, but I'm all out of ideas.
Are you dual-booting with Windows? If so, you will need to change the default shutdown method Windows uses. The "fast startup" feature that is enabled by default is known to interfere with the network card and other resources when booted to another OS.
If you are not dual-booting with Windows, run a basic ping to test for dropped packets. First point the ping at your gateway.
ping 192.168.0.1
Obviously change that IP address to whatever your gateway's IP is.
Test an external IP address:
ping 9.9.9.9
Test a ping that uses DNS.
ping archlinux.org
If some tests have dropped packets but not others, that will be informative.
Hi, thanks for replying.
As I already mentioned in my comments, fast startup is disabled. I have already tried pinging my router, but not the rest.
Router: 10 received, 0% packet loss, time 9016ms
External IP: 10 received, 0% packet loss, time 9013ms
archlinux.org: 10 received, 0% packet loss, time 67883ms
Another thing I find fairly interesting is that if I run garuda-update, during the Synchronizing package databases step, core, extra, community, and multilib repos get retrieved very quickly, but garuda, chaotic-aur, and blackarch always fail to download.
Please show what you have in /etc/resolv.conf.
cat /etc/resolv.conf
# Generated by NetworkManager
nameserver 84.200.69.80
Nothing else
Edit:
I checked the same thing on my desktop PC (connected by LAN but still) and the contents are
nameserver 192.168.100.1
nameserver fe80::1%eno1
It looks like your desktop machine is using the gateway as a nameserver (that's pretty common). If you have not set it yourself, the gateway probably has a nameserver assigned by your ISP.
You can try changing the DNS server on the laptop to OpenDNS or something else, to see if the issue is related to the DNS server, but my hunch is the network card is to blame after all.
As I mentioned earlier, it can't be the network card, as the issue persists when using USB tethering, and also with a different network card that has worked perfectly fine in a different device.
Also, setting the DNS to 8.8.8.8 did nothing (assuming I was expected to change it in connection settings)
Hey guys, issue solved!
Turns out that I (probably?) missclicked during the first time setup and DNS was set to DNS.Watch by the Setup Assistant, which seems to be either broken or misconfigured. Anyway, after resetting it everything seems to be working perfectly smoothly. Sorry for wasting everyone's time!
