Hello.
I've got usb wifi adapter Mercusys MU6H (on Realtek 8811CU) and can get it working on Garuda.
lsusb shows:
Bus 003 Device 005: ID 0bda:c811 Realtek Semiconductor Corp. 802.11ac NIC
and no specific driver
I found this driver AUR (en) - rtl8821cu-git
but don't know how to install it (complete newbie).
Thanx in advance for any assistance.
Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a4a07008-262c-4d06-a52e-7e21df95a3fc rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: Z87X-UD3H v: N/A
Mobo: Gigabyte model: Z87X-UD3H-CF v: x.x serial: <superuser required>
BIOS: American Megatrends v: F9 date: 03/18/2014
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Device-2: hidpp_battery_0 model: Logitech Wireless Keyboard K360
status: Discharging
Info: model: Intel Core i5-4670K bits: 64 type: MCP arch: Haswell family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
desc: 1x6 MiB
Speed (MHz): avg: 2516 high: 3294 min/max: 800/3800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2399 2: 2622 3: 3294
4: 1750 bogomips: 27136
Type: l1tf
IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
Device-2: NVIDIA GK104 [GeForce GTX 770] vendor: Gigabyte driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:1184 class-ID: 0300
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-10.4:8 chip-ID: 046d:082d
loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
Screen-1: 0 s-res: 2560x1080 s-dpi: 96 s-size: 677x285mm (26.7x11.2")
s-diag: 735mm (28.9")
Monitor-1: HDMI-4 res: 2560x1080 hz: 60 dpi: 81
size: 798x334mm (31.4x13.1") diag: 865mm (34.1")
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GK104 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0a class-ID: 0403
Device-4: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-1: Intel Ethernet I217-V vendor: Gigabyte driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
Device-2: Realtek 802.11ac NIC type: USB driver: N/A bus-ID: 3-9.2:5
chip-ID: 0bda:c811 class-ID: 0000 serial: <filter>
IF-ID-1: enp0s20u9u1c4i2 state: up speed: N/A duplex: N/A mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 3-4:2 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Local Storage: total: 2.95 TiB used: 7.12 GiB (0.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDX120GG25
type: SSD serial: <filter> rev: R201 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Plextor model: PX-128M5S
type: SSD serial: <filter> rev: 1.05 scheme: MBR
model: WD10EZRZ-00HTKB0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
ID-1: / raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
used: 7.12 GiB (6.0%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
ID-3: /var/log raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
ID-4: /var/tmp raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 43.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1020
Processes: 217 Uptime: 33m wakeups: 58 Memory: 15.52 GiB
used: 2.32 GiB (14.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1144 lib: 294 Shell: fish
Garuda (2.5.3-1):
System install date: 2022-02-23
Last full system update: 2022-02-23
Is partially upgraded: Yes
