I have no idea what's going on but for some reason my computer keeps going into read-only a few minutes after I booed up my computer it'll work fine for a moment and then it'll just start screaming at me that it's read only and I can't do stuff I'm using Garuda dragonized gaming edition
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=3c7e83b5-453b-495a-ae9f-4259e2aaf568 rw rootflags=subvol=@
Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P4.30 date: 07/14/2020
Info: model: AMD Ryzen 5 2400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2967 high: 3600 min/max: 1600/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3144 2: 2555
3: 2553 4: 2769 5: 3192 6: 3600 7: 2954 8: 2970 bogomips: 57498
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ASUSTeK
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f08 class-ID: 0300
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
s-diag: 1252mm (49.29")
Monitor-1: HDMI-0 pos: primary,left res: 1920x1080 dpi: 81
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-2: HDMI-1 pos: right res: 1920x1080 dpi: 82
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.6
Device-3: Corsair VOID ELITE Wireless Gaming Dongle
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 1b1c:0a75 class-ID: 0300
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-8:3 chip-ID: 8087:0a2a
Local Storage: total: 1.24 TiB used: 93.95 GiB (7.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Netac model: SSD 360GB
size: 335.35 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: PNY model: CS900 1TB SSD
tech: SSD serial: <filter> fw-rev: 06B5 scheme: MBR
used: 93.95 GiB (10.1%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 53 C
Processes: 301 Uptime: 1m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 3.36 GiB (21.6%) Init: systemd v: 254
Packages: 1649 pm: pacman pkgs: 1639 libs: 482 tools: octopi,paru,yay
pm: flatpak pkgs: 10 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.29
System install date: 2023-08-27
Last full system update: 2023-09-04
