when booting into a snapshot I get some kde errors complaining that it cant write to its config files and the desktop never loads. It seems this user had the same issue How to solve this error in Garuda kde plasma ( attempt to write a readonlydatabase
but didn’t provide any specifics
so basically what happens is after booting the snapshot I am presented with a bunch of kde error messages that say attempt-to-write-a-readonlydatabase and the rest of the desktop never loads
eventually the restore snapshot prompt does appear and once I restore the snapshot and reboot everything is fine.
Kernel: 6.8.1-3-cachyos arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-linux
root=UUID=8a69f047-feee-46cf-81a1-d299eb173883 rw rootflags=subvol=@
sysrq_always_enabled=1 mitigations=off amd_pstate=active
amdgpu.ppfeaturemask=0xffffffff tsc=reliable clocksource=tsc nowatchdog
nmi_watchdog=0 initrd=@\boot\initramfs-linux-cachyos.img
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: P5.10
date: 10/20/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3868 high: 4576 min/max: 550/4687 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3658 2: 3656 3: 4573
4: 3653 5: 3657 6: 3661 7: 3658 8: 3695 9: 4576 10: 3657 11: 4316 12: 3667
bogomips: 88815
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,HDMI-A-2 empty: DP-2,HDMI-A-1,Writeback-1
bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu d-rect: 3584x1728 display-ID: 0
Monitor-1: DP-1 pos: bottom-r res: 2048x864 size: N/A modes: N/A
Monitor-2: HDMI-A-2 pos: primary,top-left res: 1536x864 size: N/A
modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.1
navi22 LLVM 17.0.6 DRM 3.57 6.8.1-3-cachyos) device-ID: 1002:73df
memory: 11.72 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.279 layers: 23 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.3-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28
Device-2: Sony INZONE H9 / H7
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 054c:0e53
class-ID: 0a00
API: ALSA v: k6.8.1-3-cachyos status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Edimax Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4.2:8 chip-ID: 7392:c611
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: yes pairing: yes class-ID: 6c0104
Local Storage: total: 3.64 TiB used: 3.98 TiB (109.3%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731120WD temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 35.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
used: 796.51 GiB (85.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 44.3 MiB (14.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.26 GiB used: 1.62 GiB (5.2%)
System Temperatures: cpu: 63.5 C mobo: 34.0 C gpu: amdgpu temp: 40.0 C
mem: 38.0 C
Fan Speeds (rpm): cpu: 2356 fan-1: 0 fan-3: 1306 fan-4: 1311 fan-5: 1509
gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.23 vbat: 3.28 gpu: amdgpu watts: 9.00
Memory: total: 32 GiB available: 31.26 GiB used: 12.84 GiB (41.1%)
Processes: 541 Power: uptime: 21m states: freeze,mem,disk suspend: s2idle
image: 12.49 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: 2819 pm: pacman pkgs: 2774 libs: 632 tools: octopi,paru,yay
pm: appimage pkgs: 0 pm: flatpak pkgs: 45 Compilers: clang: 17.0.6
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0
running-in: alacritty inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-01-11
Last full system update: 2024-03-20
