Hello.
inxi -Faz
System: Kernel: 5.14.3-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=a6eae74a-2326-42b3-af7d-a0ea0be07a31 rw
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF serial: <filter>
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <filter> UEFI: American Megatrends LLC. v: F33h
date: 04/23/2021
CPU: Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 family: 17 (23) model-id: 71 (113)
stepping: 0 microcode: 8701021 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 114989
Speed: 3593 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3593 2: 3591 3: 3598 4: 3569 5: 3595
6: 3587 7: 3575 8: 3593 9: 3597 10: 3604 11: 3592 12: 3592 13: 3594 14: 4130 15: 3840 16: 3592
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: Gigabyte driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 05:00.0 chip-ID: 10de:1b82 class-ID: 0300
Device-2: Chicony USB2.0 FHD UVC WebCam type: USB driver: uvcvideo bus-ID: 5-4.4:22 chip-ID: 04f2:b612
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 80 s-size: 1626x457mm (64.0x18.0") s-diag: 1689mm (66.5")
Monitor-1: DP-2 res: 5120x1440 dpi: 109 size: 1190x340mm (46.9x13.4") diag: 1238mm (48.7")
OpenGL: renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 05:00.1
Device-2: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series] driver: snd_hda_intel v: kernel
bus-ID: 07:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
Device-4: Oculus VR Rift S type: USB driver: cdc_acm,hid-generic,snd-usb-audio,usbhid bus-ID: 5-1.2:4
chip-ID: 2833:0051 class-ID: 0300 serial: <filter>
Device-5: Logitech PRO type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4.1.3:21 chip-ID: 046d:0aa7
Device-6: Realtek USB Audio type: USB driver: snd-usb-audio bus-ID: 5-4.3:19 chip-ID: 0bda:48a5 class-ID: 0102
Sound Server-1: ALSA v: k5.14.3-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Network: Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel port: e000 bus-ID: 06:00.0
Device-2: Microsoft Wireless XBox Controller Dongle type: USB driver: mt76x2u bus-ID: 1-3.4:4 chip-ID: 045e:02e6
IF: wlp8s0f1u3u4 state: down mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 6-4.1.2:13 chip-ID: 0bda:8153
IF: enp12s0f3u4u1u2 state: down mac: <filter>
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8 bus-ID: 3-6.2:4
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Drives: Local Storage: total: 5.25 TiB used: 1.26 TiB (23.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 1TB size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 34.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 33.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37240G size: 223.57 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 96R9 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD4002FYYZ-01B7CB1 size: 3.64 TiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: 1M03 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: TransMemory size: 28.85 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
Partition: ID-1: / raw-size: 923.58 GiB size: 923.58 GiB (100.00%) used: 120.98 GiB (13.1%) fs: btrfs dev: /dev/nvme0n1p3
maj-min: 259:4
ID-2: /boot/efi raw-size: 489 MiB size: 488 MiB (99.80%) used: 65.3 MiB (13.4%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:2
ID-3: /home raw-size: 923.58 GiB size: 923.58 GiB (100.00%) used: 120.98 GiB (13.1%) fs: btrfs dev: /dev/nvme0n1p3
maj-min: 259:4
ID-4: /var/log raw-size: 923.58 GiB size: 923.58 GiB (100.00%) used: 120.98 GiB (13.1%) fs: btrfs
dev: /dev/nvme0n1p3 maj-min: 259:4
ID-5: /var/tmp raw-size: 923.58 GiB size: 923.58 GiB (100.00%) used: 120.98 GiB (13.1%) fs: btrfs
ID-1: swap-1 type: partition size: 7.45 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:3
ID-2: swap-2 type: zram size: 31.29 GiB used: 84 MiB (0.3%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 44.4 C mobo: 32.0 C gpu: nvidia temp: 56 C
Info: Processes: 397 Uptime: 9h 10m wakeups: 0 Memory: 31.35 GiB used: 10.49 GiB (33.5%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1903 pacman: 1895 lib: 508 flatpak: 8 Shell: fish v: 3.3.1
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
I have tried rebalanceing the volume, but that's it. I am very new to btrfs, so I am trying to be careful.
This is my fstab:
╭─kekkon@tuxgamer in ~ took 1s
╰─λ cat /etc/fstab
File: /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=4BB6-B024 /boot/efi vfat umask=0077 0 2
UUID=a6eae74a-2326-42b3-af7d-a0ea0be07a31 / btrfs subvol=/@,noatime,space_cache,autodefrag,compress=zstd 0 0
UUID=a6eae74a-2326-42b3-af7d-a0ea0be07a31 /home btrfs subvol=/@home,noatime,space_cache,autodefrag,compress=zstd 0 0
UUID=a6eae74a-2326-42b3-af7d-a0ea0be07a31 /root btrfs subvol=/@root,noatime,space_cache,autodefrag,compress=zstd 0 0
UUID=a6eae74a-2326-42b3-af7d-a0ea0be07a31 /srv btrfs subvol=/@srv,noatime,space_cache,autodefrag,compress=zstd 0 0
UUID=a6eae74a-2326-42b3-af7d-a0ea0be07a31 /var/cache btrfs subvol=/@cache,noatime,space_cache,autodefrag,compress=zstd 0 0
UUID=a6eae74a-2326-42b3-af7d-a0ea0be07a31 /var/log btrfs subvol=/@log,noatime,space_cache,autodefrag,compress=zstd 0 0
UUID=a6eae74a-2326-42b3-af7d-a0ea0be07a31 /var/tmp btrfs subvol=/@tmp,noatime,space_cache,autodefrag,compress=zstd 0 0
/dev/sdb2 /mnt/data ntfs defaults 0 0
Since a day or two I get errors when updating packages or running sudo timeshift --check
about not being able to remove files because it is a read-only filesystem. I don't think I changed anything, but I do regularly install the available updates.
