After much tom-foolery with Optimus and prime this and gdm-prime that and garuda-manager, and all that, I realized that setting my BIOS "Chipset menu (only has 2 options, Optimus and:) GPU to “discrete GPU only” would completely disable the integrated intel GPU inside.
All I’ve ever seen is guides on getting prime-manager to work, but I had no care that my intel gpu ever even turned on. This laptop, only just the 3070, still goes for hours playing a game on battery power.
Quick guide
First. my system is a 2021 Razer R15 Advanced RTX 3070 Max-Q, with the 166hz screen (I’ve since put 32GB 3200hz RAM in, this laptop also has the only double-stack NvME M.2 SSD input on the motherboard that I’ve ever seen (you can literally fit 2x8TB NvMEs if you were dumb and rich enough, the sit on top the other, with a small heatsink in between):
$ sudo garuda-inxi
#we sudo so that os-prober detects that you aren’t dual booting like you shouldn’t be
Kernel: 5.15.71-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=#s&letters rw rootflags=subvol=@
splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
sysrq_always_enabled=1
Type: Laptop System: Razer product: Blade 15 Advanced Model (Mid 2021) -
RZ09-0409 v: 7.04 serial: <filter> Chassis: type: 10 serial: N/A
Mobo: Razer model: CH570 v: 4 serial: N/A UEFI: Razer v: 2.01
date: 09/24/2021
ID-1: BAT0 charge: 63.6 Wh (100.0%) condition: 63.6/80.2 Wh (79.2%)
volts: 16.7 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
Info: model: 11th Gen Intel Core i7-11800H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 built: 2020
microcode: 0x40
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2599 high: 2661 min/max: 800/4600 base/boost: 4158/5000
scaling: driver: intel_pstate governor: performance volts: 1.0 V
ext-clock: 100 MHz cores: 1: 2600 2: 2639 3: 2600 4: 2600 5: 2600 6: 2600
7: 2600 8: 2600 9: 2571 10: 2528 11: 2661 12: 2600 13: 2600 14: 2600
15: 2600 16: 2600 bogomips: 73728
prctl and seccomp
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Razer USA
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max:
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
Device-2: IMC Networks Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 3-8:9 chip-ID: 13d3:5279 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-4 size-res: N/A modes: N/A
Monitor-2: HDMI-0 pos: primary res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3070 Laptop GPU/PCIe/SSE2 v: 4.6.0
NVIDIA 515.76 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Razer USA
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA GA104 High Definition Audio vendor: Razer USA
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Sound Server-1: ALSA v: k5.15.71-1-lts running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 5b:00.0 chip-ID: 8086:2725
IF: wlp91s0 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-3.1:7 chip-ID: 0bda:8153 class-ID: 0000
IF: enp0s13f0u3u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wgivpn state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-5:6 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 1.82 TiB used: 1.02 TiB (56.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS2130 2TB SSD
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: CS213531 temp: 47.9 C
SMART: yes health: PASSED on: 153d 8h cycles: 910 read-units: 70,973,262
[36.3 TB] written-units: 44,949,722 [23.0 TB]
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1019.35 GiB
(54.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
(0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1019.35 GiB
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1019.35
GiB (54.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1019.35
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.16 GiB used: 4.13 GiB (13.3%)
System Temperatures: cpu: 87.0 C mobo: N/A gpu: nvidia temp: 75 C
Processes: 444 Uptime: 4h 4m wakeups: 19 Memory: 31.16 GiB used: 10.84 GiB
(34.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 alt: 11 Packages: pm: pacman pkgs: 1981 libs: 544
tools: octopi,paru,yay Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-09-23
Last full system update: 2022-09-29 ↻
Note that I have a 144hz monitor plugged in through HDMI.
The guide is very simple, and I have tried this with both the normal and gaming Dragonized edition KDE Garuda.
Boot using open source drivers, you will end up installing the nvidia-dkms drivers, but for some reason you will run into kernel panics if you launch the install Live USB selecting the NVIDIA driver option.
Run through the installation guide, the laptop should not even detect that you have Optimus, and as such, when it offers to install the non-free NVIDIA drivers, select yes, and then double-check that prime-manager was not installed, in fact make sure the word optimus is not in your image at all
You should end up with the nvidia-dkms drivers, I also install the cuda SDK as I use hashcat and the like…
Now my question is… Everything works 100% (as in, I have not run into any Proton/Lutris/Heroic/etc. issues at all! HOWEVER
For some reason, my laptop will only boot successfully (im using strictly btrfs btw) using the Linux - LTS Kernel Linux (headless or not), -zen, and -hardened result in about 20 lines of boot code before a hard freeze, it appears to be right as the NVIDIA-dkms drivers are initialized.
Does anyone know why this might be? As a cyber and information security professional, I know of some flaws with certain ways LTS, especially this kernel of aarch64 LTS do things, and I’d prefer to use the hardened version.
If anyone has questions about the build, or would like any additional information, please let me know. Thanks!
