Allo. I feel like I’ve been all over with this issue, and I’m not getting anywhere. I’ve got a Logitech g600 that will not fully work. The mouse moves, but no buttons work. Other “standard” USB mouse works without issue.
Garuda-inxi
Kernel: 6.7.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=fea6666d-069c-4b7a-978e-f9efeffa807f rw rootflags=subvol=@
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B650 GAMING X AX v: x.x
Megatrends LLC. v: F22b date: 02/06/2024
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 999 high: 3683 min/max: 400/5050 scaling:
4: 400 5: 400 6: 3683 7: 400 8: 400 9: 400 10: 3587 11: 400 12: 400
13: 3523 14: 400 15: 400 16: 400 bogomips: 134144
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
DP-6, HDMI-A-2 bus-ID: 11:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 34.0 C
gpu: amdgpu,amdgpu display-ID: 0
Monitor-1: DP-2 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (radeonsi
navi22 LLVM 16.0.6 DRM 3.57 6.7.8-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.276 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6750 XT (RADV NAVI22) driver: mesa radv v: 24.0.2-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 24.0.2-arch1.1 device-ID: 1002:164e
16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.1 (LLVM 16.0.6)
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 11:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0c76:161f class-ID: 0300
API: ALSA v: k6.7.8-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
port: d000 bus-ID: 08:00.0 chip-ID: 10ec:c852 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 0bda:0852
Report: btmgmt ID: hci0 rfk-id: 16 state: up address: <filter> bt-v: 5.3
Local Storage: total: 1.82 TiB used: 127.94 GiB (6.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 1.82 TiB
tech: SSD serial: <filter> fw-rev: EDFMF0.0 temp: 27.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 127.94 GiB (6.9%)
used: 127.94 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.5 GiB used: 516 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.1 C mobo: 26.0 C
GPU: device: amdgpu temp: 34.0 C device: amdgpu temp: 41.0 C mem: 48.0 C
fan: 0 watts: 16.00
Memory: total: 32 GiB note: est. available: 30.5 GiB used: 6.11 GiB (20.0%)
Processes: 388 Power: uptime: 12h 39m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 15 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.19 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 tools: apt,apt-get pm: pacman pkgs: 1830
libs: 546 tools: octopi,paru Compilers: gcc: 13.2.1 Shell: garuda-inxi
default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-29
Last full system update: 2024-03-04
ratbagd --verbose=raw
Initializing libratbag
ratbag debug: New device: USB PnP Audio Device
ratbag debug: Using data directory '/usr/share/libratbag'
ratbag debug: No data file found for 0c76:161f
ratbag debug: New device: Logitech USB Receiver
ratbag debug: 046d:c534 is a Logitech receiver, not a device. Ignoring...
ratbag debug: New device: Logitech Wireless Mouse
ratbag debug: No data file found for 046d:4054
ratbag debug: New device: ITE Tech. Inc. ITE Device
ratbag debug: No data file found for 048d:5702
ratbag debug: New device: SONiX USB Keyboard
ratbag debug: No data file found for 0c45:7605
ratbag debug: New device: Logitech Gaming Mouse G600
ratbag debug: device assigned driver logitech_g600
ratbag debug: hidraw info: bus 0x03 vendor 0x46d product 0xffffc24a
ratbag debug: Logitech Gaming Mouse G600 is device '/dev/hidraw4'.
ratbag debug: Parsing HID report descriptor
ratbag debug: Logitech Gaming Mouse G600 is device '/dev/hidraw6'.
ratbag debug: - HID report ID 01
ratbag debug: - HID report ID 80
ratbag debug: - HID report ID f6
ratbag debug: - HID report ID f0
ratbag debug: - HID report ID f1
ratbag debug: - HID report ID f2
ratbag debug: - HID report ID f3
ratbag debug: - HID report ID f4
ratbag debug: - HID report ID f5
ratbag debug: - HID report ID f7
ratbag raw: feature get: f3 00 00 00 02 04 00 00 00 00 00 07 00 00 0e 14 2c 00 00 00 00 00 00 00 02 00 00 00 00 00 00 01 00 00 02 00 00 03 00 00 04 00 00 05 00 00 17 00 00 00 02 05 14 00 00 00 00 1e 00 00 1f 00 00 20 00 00 21 00 00 22 00 00 23 00 00 24 00 00 25 00 00 26 00 00 27 00 00 2d 00 00 2e 00 00 00 01 00 00 02 00 00 03 00 00 04 00 00 05 00 00 17 00 00 00 02 05 14 00 00 00 01 1e 00 01 1f 00 01 20 00 01 21 00 01 22 00 01 23 00 01 24 00 01 25 00 01 26 00 01 27 00 01 2d 00 01 2e
ratbag debug: Unknown data in profile 0
ratbag debug: profile->unknown1: 00 00 00 00 00
ratbag debug: profile->unknown2: 00 00 00 00 00 00 02 00 00 00 00 00 00
ratbag raw: feature get: f4 3f bf 5a 01 08 00 00 00 00 00 07 00 00 08 10 1e 3c 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 02 00 00 03 00 00 04 00 00 05 00 00 00 00 00 12 00 00 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3f bf 5a 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ratbag debug: Unknown data in profile 1
ratbag debug: profile->unknown2: 00 00 00 00 00 00 00 00 00 00 00 00 00
ratbag raw: feature get: f5 00 27 ff 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 27 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ratbag debug: Unknown data in profile 2
ratbag raw: feature get: f0 38 00 00
ratbag error: libratbag bug: Logitech Gaming Mouse G600: no profile set as active profile
DBus server ready
All of that leads to Piper claiming it can’t find a device, which ratbagdctl confirms:
>ratbagctl list
No devices available.
Not sure where to go next. I think this has to do with an inablity to load profiles, but I’m not sure?
Any hints you can give would be greatly appreciated.
