Hello, I experience dizzyingly rapid flickering randomly during games or productivity apps.
It seems monitor and app dependent, one app can be flickering, alt tabbing to another one (for example from game to ff on the same monitor) stops the flickering but shift alt tabbing back the app is still flickering. When I drag app to different monitor it stops or sometimes starts again.
this has been happening for months now. I think I’ve had this issue since moving to wayland on kde plasma 6. I have an AMD GPU (5700XT) with both AMD-PRO and regular ones, so I can’t imagine it’s gpu drivers. I read somewhere that it might be VRR, but I’m not sure how to test that, turning off v-sync in games doesn’t help.
I think it also might be happening more likely when I stress my GPU (Coding in konsole/nvim is usually fine, but games start this issue, FF and discord sometimes). Pressing meta key to bring up menu bar sometimes stops the game from flickering but clicking back breaks it again, sometimes makes it worse.
Here are some example videos I recorded in slowmo:
https://workdrive.zohopublic.eu/folder/ewjjo23c9364e1ea6414ba7581e153dd609ac
- There’s a slowmo without flicker (I can’t see it)
- Slowmo with very bad flicker,
- Slowmo where I see flicker, press meta and open menu, where I stop perceiving flicker(tho there seems to still be some)
On the very bad one, I see that it introduces ghosting, as if it’s switching between one random frame in the past and next one, as if video buffers get corrupted during switching.
On apps like firefox and discord it’s hard to tell if it’s ghosting, but it’s definitely flickering. Sometimes flickers like 3 times and stops, sometimes periodic, very random.
What could I do to fix this?
Kernel: 6.9.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=b8196f39-e08b-4bce-b75d-343098561547 rw rootflags=subvol=@
resume=UUID=9bac1011-b1fa-4c26-85c0-a8dacd8e1df1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.0 tk: Qt v: N/A info: frameworks v: 6.3.0
Mobo: ASUSTeK model: PRIME B650-PLUS v: Rev 1.xx
UEFI: American Megatrends v: 1636 date: 07/28/2023
Device-1: hid-0003:256F:C652.0004-battery model: 3Dconnexion Universal
Receiver serial: N/A charge: N/A status: N/A
Device-2: hid-98:b6:ea:16:d7:89-battery model: GuliKit Controller XW
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4999 high: 5254 min/max: 400/5573 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4673 2: 5216 3: 4985
4: 4887 5: 4974 6: 5253 7: 5125 8: 4767 9: 5153 10: 5210 11: 5241 12: 3986
13: 5196 14: 5254 15: 4923 16: 5154 bogomips: 144004
driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm)
built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:731f
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4,HDMI-A-2,Writeback-1 bus-ID: 0e:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 59.0 C
gpu: amdgpu,amdgpu d-rect: 5632x3168 display-ID: 0
Monitor-1: DP-1 pos: primary,top-left res: 3072x1728 size: N/A modes: N/A
Monitor-2: DP-3 pos: bottom-r res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
navi10 LLVM 17.0.6 DRM 3.57 6.9.6-zen1-1-zen) device-ID: 1002:731f
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 5700 XT (RADV NAVI10) driver: mesa radv v: 24.1.2-arch1.1
device-ID: 1002:731f surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: AMD Radeon RX 5700 XT driver: amd v: (AMD
proprietary shader compiler) device-ID: 1002:731f
surfaces: xcb,xlib,wayland device: 2 type: integrated-gpu name: AMD
v: 24.1.2-arch1.1 device-ID: 1002:164e surfaces: xcb,xlib,wayland
device: 3 type: integrated-gpu name: AMD Radeon Graphics driver: amd
v: (AMD proprietary shader compiler) device-ID: 1002:164e
surfaces: xcb,xlib,wayland device: 4 type: cpu name: llvmpipe (LLVM
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.2-arch1.1 (LLVM 17.0.6)
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0e:00.1 chip-ID: 1002:1640 class-ID: 0403
bus-ID: 0e:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: USB MIDI Interface driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: fc02:0101
class-ID: 0103
Device-5: Native Instruments Komplete Audio 2 driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:3
chip-ID: 17cc:1840 class-ID: fe01 serial: <filter>
API: ALSA v: k6.9.6-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0a:00.0
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
Local Storage: total: 1.82 TiB used: 1.2 TiB (66.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 59.9 C
ID-1: / raw-size: 1.3 TiB size: 1.3 TiB (100.00%) used: 1.2 TiB (92.3%)
used: 520 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.3 TiB size: 1.3 TiB (100.00%)
used: 1.2 TiB (92.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.3 TiB size: 1.3 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.3 TiB size: 1.3 TiB (100.00%)
ID-1: swap-1 type: zram size: 30.5 GiB used: 643.2 MiB (2.1%)
ID-2: swap-2 type: partition size: 33.55 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 74.6 C mobo: N/A
GPU: device: amdgpu temp: 101.0 C mem: 92.0 C fan: 1901 watts: 175.00
device: amdgpu temp: 60.0 C
Memory: total: 32 GiB note: est. available: 30.5 GiB used: 12.43 GiB (40.7%)
Processes: 416 Power: uptime: 5h 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
Packages: 2140 pm: dpkg pkgs: 0 pm: pacman pkgs: 2128 libs: 526
tools: octopi,paru,yay pm: pkg pkgs: 0 pm: flatpak pkgs: 12 Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26
System install date: 2023-08-17
Last full system update: 2024-06-28 ↻
Failed units: sesinetd.service
