Rani stuck on Initilizing at 20%
I have installed the OS and everything is working but Rani is stuck initializing at 20%. Based on what I have read this is related to the video driver. I am a new user and have done everything that I have seen as a possible solution. Any assistance is greatly appreciated.
sudo garuda-hardware-tool --nonfree
[sudo] password:
Detecting hardware...
Detected GPU: Product: NVIDIA Corporation GK104M GeForce GTX 670MX, PCI ID: 01:00.0, Vendor ID: 10de
All required packages are already installed: garuda-hardware-profile-standard-x11
lspci -nn -d '*:*:03xx'
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GK104M [GeForce GTX 670MX] [10de:11a1] (rev a1)
Kernel: 6.17.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=c3c19f56-bee3-4cc1-a467-a7d794149a48 rw rootflags=subvol=@
quiet resume=UUID=e52656f1-942e-496b-94f0-7a5d268e874b loglevel=3
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Laptop System: ASUSTeK product: G75VX v: 1.0
Mobo: ASUSTeK model: G75VX v: 1.0 serial: <superuser required>
part-nu: ASUS-NotebookSKU uuid: <superuser required>
UEFI: American Megatrends v: G75VX.204 date: 10/31/2012
ID-1: BAT0 charge: 66.2 Wh (100%) condition: 66.2/78 Wh (84.9%) volts: 16.72
min: 14.8 model: ASUSTek G75--52 type: Li-ion serial: N/A charging:
status: full cycles: N/A
Info: model: Intel Core i7-3610QM bits: 64 type: MT MCP arch: Ivy Bridge
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3300 min/max: 1200/3300 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3300 2: 3300 3: 3300 4: 3300 5: 3300 6: 3300
7: 3300 8: 3300 bogomips: 36713
Flags-basic: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GK104M [GeForce GTX 670MX] vendor: ASUSTeK driver: nouveau
v: kernel non-free: series: 470.xx+ status: legacy-active (EOL~2024-09-xx)
arch: Kepler-2 code: GKxxx process: TSMC 28nm built: 2012-2018 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 01:00.0
chip-ID: 10de:11a1 class-ID: 0300 temp: 43.0 C
Device-2: Sunplus Innovation ASUS Webcam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-1.3:4
chip-ID: 1bcf:2885 class-ID: 0e02
compositor: kwin_wayland driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: 0
Monitor-1: LVDS-1 model: Chi Mei Opto 0x1720 built: 2011 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 128 gamma: 1.2
size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9 modes:
max: 1920x1080 min: 640x350
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.2.6-arch1.1 glx-v: 1.4
direct-render: yes renderer: NVE4 device-ID: 10de:11a1 memory: 2.92 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 9 device: 0 type: cpu name: llvmpipe (LLVM
21.1.4 256 bits) driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM 21.1.4)
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
Device-2: NVIDIA GK104 HDMI Audio driver: snd_hda_intel v: kernel pcie:
bus-ID: 01:00.1 chip-ID: 10de:0e0a class-ID: 0403
API: ALSA v: k6.17.7-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 04:00.0 chip-ID: 1969:1083 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1.1:3 chip-ID: 8087:0032
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 931.51 GiB used: 18.49 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 914.1 GiB size: 914.1 GiB (100.00%) used: 18.49 GiB (2.0%)
used: 664 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 914.1 GiB size: 914.1 GiB (100.00%)
used: 18.49 GiB (2.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 914.1 GiB size: 914.1 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.1 GiB size: 914.1 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.12 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nouveau temp: 43.0 C
Fan Speeds (rpm): cpu: 2100
Memory: total: 16 GiB available: 15.56 GiB used: 2.14 GiB (13.7%)
Processes: 299 Power: uptime: 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2152 libs: 491 tools: octopi,paru Compilers:
clang: 21.1.4 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.1.2
Garuda (2.11.1-1):
System install date:     2025-11-04
Garuda release:          251002
Last full system update: 2025-11-04
24/25 checks run in 2.19 seconds ⌛
Powered by garuda-health 🦅
Can you run it via the console and add --enable-logging please?
garuda-rani --enable-logging
[8112:1104/124235.878230:WARNING:ui/ozone/platform/wayland/common/drm_render_node_path_finder.cc:111] Preferre
d drm_render_node not found, picking nouveau
[8112:1104/124236.809510:WARNING:ui/ozone/platform/wayland/common/wayland_object.cc:119] Binding to wl_shm ver
sion 1 but version 2 is available.
[8112:1104/124236.809543:WARNING:ui/ozone/platform/wayland/common/wayland_object.cc:119] Binding to wl_seat ve
rsion 8 but version 10 is available.
[8112:1104/124236.809554:WARNING:ui/ozone/platform/wayland/common/wayland_object.cc:119] Binding to zwp_pointe
r_gestures_v1 version 1 but version 3 is available.
[8112:1104/124236.809581:WARNING:ui/ozone/platform/wayland/common/wayland_object.cc:119] Binding to wp_cursor_
shape_manager_v1 version 1 but version 2 is available.
[8112:1104/124236.809605:WARNING:ui/ozone/platform/wayland/common/wayland_object.cc:119] Binding to org_kde_kw
in_appmenu_manager version 1 but version 2 is available.
[8112:1104/124236.809664:WARNING:ui/ozone/platform/wayland/common/wayland_object.cc:119] Binding to zwp_linux_
dmabuf_v1 version 4 but version 5 is available.
[8112:1104/124237.539985:WARNING:ui/ozone/platform/wayland/host/wayland_surface.cc:172] Server doesn't support
zcr_alpha_compositing_v1.
[8112:1104/124237.540003:WARNING:ui/ozone/platform/wayland/host/wayland_surface.cc:187] Server doesn't support
overlay_prioritizer.
[8112:1104/124237.540010:WARNING:ui/ozone/platform/wayland/host/wayland_surface.cc:221] Server doesn't support
zcr_color_management_surface.
[8154:1104/124237.676856:WARNING:sandbox/policy/linux/sandbox_linux.cc:414] InitializeSandbox() called with mu
ltiple threads in process gpu-process.
[8112:1104/124239.881693:INFO:CONSOLE:4451] "Initializing ConfigService", source: file:///usr/lib/garuda-rani/
app.asar/node_modules/@app/renderer/dist/client/index.js (4451)
[8112:1104/124239.881811:INFO:CONSOLE:4451] "Loading on", source: file:///usr/lib/garuda-rani/app.asar/node_mo
[8112:1104/124240.371891:INFO:CONSOLE:4451] "Checking if store has key: activeTheme", source: file:///usr/lib/
garuda-rani/app.asar/node_modules/@app/renderer/dist/client/index.js (4451)
[8112:1104/124240.380682:INFO:CONSOLE:4451] "Checking if store has key: autoRefresh", source: file:///usr/lib/
[8112:1104/124240.388875:INFO:CONSOLE:4451] "Checking if store has key: autoStart", source: file:///usr/lib/ga
[8112:1104/124240.396875:INFO:CONSOLE:4451] "Checking if store has key: background", source: file:///usr/lib/g
[8112:1104/124240.405182:INFO:CONSOLE:4451] "Checking if store has key: backgroundFit", source: file:///usr/li
b/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/index.js (4451)
[8112:1104/124240.413530:INFO:CONSOLE:4451] "Checking if store has key: blurBackground", source: file:///usr/l
ib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/index.js (4451)
[8112:1104/124240.421813:INFO:CONSOLE:4451] "Checking if store has key: blurStrength", source: file:///usr/lib
[8112:1104/124240.429821:INFO:CONSOLE:4451] "Checking if store has key: copyDiagnostics", source: file:///usr/
lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/index.js (4451)
[8112:1104/124240.440151:INFO:CONSOLE:4451] "Checking if store has key: customDesign", source: file:///usr/lib
[8112:1104/124240.449899:INFO:CONSOLE:4451] "Checking if store has key: darkMode", source: file:///usr/lib/gar
[8112:1104/124240.458685:INFO:CONSOLE:4451] "Checking if store has key: firstBoot", source: file:///usr/lib/ga
[8112:1104/124240.477121:INFO:CONSOLE:16] "Store get: firstBoot => false", source: file:///usr/lib/garuda-rani
/app.asar/node_modules/@app/preload/dist/exposed.mjs (16)
[8112:1104/124240.477210:INFO:CONSOLE:4451] "Setting firstBoot to false", source: file:///usr/lib/garuda-rani/
[8112:1104/124240.477286:INFO:CONSOLE:4451] "Checking if store has key: language", source: file:///usr/lib/gar
[8112:1104/124240.485489:INFO:CONSOLE:4451] "Checking if store has key: logLevel", source: file:///usr/lib/gar
[8112:1104/124240.495819:INFO:CONSOLE:4451] "Checking if store has key: showMainLinks", source: file:///usr/li
[8112:1104/124240.504012:INFO:CONSOLE:4451] "Checking if store has key: systemdUserContext", source: file:///u
sr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/index.js (4451)
[8112:1104/124240.513807:INFO:CONSOLE:4451] "Loaded 1 settings from store", source: file:///usr/lib/garuda-ran
[8112:1104/124240.603427:INFO:CONSOLE:4451] "Active language: en", source: file:///usr/lib/garuda-rani/app.asa
[8112:1104/124240.612211:INFO:CONSOLE:4451] "User barn, welcome!", source: file:///usr/lib/garuda-rani/app.asa
[8112:1104/124240.612347:INFO:CONSOLE:4451] "Running kernel: 6.17.7-zen1-1-zen", source: file:///usr/lib/garud
[8112:1104/124240.612470:INFO:CONSOLE:4451] "Filesystem type: btrfs, is installed", source: file:///usr/lib/ga
[8112:1104/124240.612584:INFO:CONSOLE:4451] "Current desktop environment: KDE", source: file:///usr/lib/garuda
[8112:1104/124240.612693:INFO:CONSOLE:4451] "Borderless maximized window setting: enabled", source: file:///us
[8112:1104/124240.612920:INFO:CONSOLE:4451] "Reboot pending status: false", source: file:///usr/lib/garuda-ran
[8112:1104/124240.613021:INFO:CONSOLE:4451] "Current locale: en_US.UTF-8", source: file:///usr/lib/garuda-rani
[8112:1104/124240.613791:INFO:CONSOLE:4451] "Syncing auto start setting with system: disable", source: file://
/usr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/index.js (4451)
[8112:1104/124240.613893:INFO:CONSOLE:4451] "Enabling auto start", source: file:///usr/lib/garuda-rani/app.asa
[8112:1104/124240.622365:INFO:CONSOLE:4451] "Initializing theme: Catppuccin Mocha/Latte Aura", source: file://
INFO [12:42:40.513]: Renderer - Loaded 1 settings from store
[8112:1104/124241.001941:INFO:CONSOLE:4451] "Available packages: 23712", source: file:///usr/lib/garuda-rani/a
[8112:1104/124241.002167:INFO:CONSOLE:4451] "ConfigService initialized successfully", source: file:///usr/lib/
[8112:1104/124241.002250:INFO:CONSOLE:4451] "Loading off", source: file:///usr/lib/garuda-rani/app.asar/node_m
[8112:1104/124241.010592:INFO:CONSOLE:16] "Store get: firstBoot => false", source: file:///usr/lib/garuda-rani
[8112:1104/124241.022259:INFO:CONSOLE:4451] "Active language: en", source: file:///usr/lib/garuda-rani/app.asa
[8112:1104/124241.025163:INFO:CONSOLE:4451] "Syncing auto start setting with system: enable", source: file:///
[8112:1104/124241.025233:INFO:CONSOLE:4451] "Disabling auto start", source: file:///usr/lib/garuda-rani/app.as
[8112:1104/124241.031751:INFO:CONSOLE:4451] "Loaded translation for en, 24 keys", source: file:///usr/lib/garu
[8112:1104/124241.051677:INFO:CONSOLE:4451] "Setting up app menu event listeners", source: file:///usr/lib/gar
[8112:1104/124241.052587:INFO:CONSOLE:16] "Event listener added for channel: appMenu:itemClicked", source: fil
e:///usr/lib/garuda-rani/app.asar/node_modules/@app/preload/dist/exposed.mjs (16)
[8112:1104/124241.052782:INFO:CONSOLE:4451] "App menu event listeners setup complete", source: file:///usr/lib
[8112:1104/124241.058153:INFO:CONSOLE:4451] "TaskManagerService constructor initialized", source: file:///usr/
[8112:1104/124241.064782:INFO:CONSOLE:4451] "Enabled dark mode via effect", source: file:///usr/lib/garuda-ran
[8112:1104/124241.064877:INFO:CONSOLE:4451] "Dark mode enabled", source: file:///usr/lib/garuda-rani/app.asar/
[8112:1104/124241.065721:INFO:CONSOLE:4451] "Electron window listeners initialized", source: file:///usr/lib/g
[8112:1104/124241.065863:INFO:CONSOLE:16] "Event listener added for channel: appMenu:itemClicked", source: fil
[8112:1104/124241.145975:INFO:CONSOLE:4451] "Terminal theme switched via effect", source: file:///usr/lib/garu
[8112:1104/124241.312534:INFO:CONSOLE:4451] "Terminal component initialized", source: file:///usr/lib/garuda-r
[8112:1104/124241.314154:INFO:CONSOLE:4451] "WallpaperService effect triggered and renderer and elementRef are
set", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/index.js (4451)
[8112:1104/124241.314234:INFO:CONSOLE:4451] "Removing background image from body", source: file:///usr/lib/gar
[8112:1104/124241.314310:INFO:CONSOLE:4451] "Applying background contain style to body", source: file:///usr/l
[8112:1104/124241.314458:INFO:CONSOLE:4451] "Removing background blur style from body with strength: 4", sourc
[8112:1104/124241.318064:INFO:CONSOLE:4451] "Notification permission already granted", source: file:///usr/lib
[8112:1104/124241.322208:INFO:CONSOLE:4451] "Subscribing to terminal output/clear emitter", source: file:///us
[8112:1104/124241.331283:INFO:CONSOLE:4451] "App menu update result from main process: true", source: file:///
[8112:1104/124241.332400:INFO:CONSOLE:4451] "Initializing theme: Catppuccin Mocha/Latte Aura", source: file://
[8112:1104/124241.425709:INFO:CONSOLE:4451] "Executing bash code: systemctl list-units --type service,socket -
-full --output json --no-pager", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/
[8112:1104/124241.425786:INFO:CONSOLE:4451] "Executing one-off command: bash ["--norc","--noprofile","-c","sys
temctl list-units --type service,socket --full --output json --no-pager"]", source: file:///usr/lib/garuda-ran
[8112:1104/124241.425857:INFO:CONSOLE:4451] "Executing bash code: systemctl --user list-units --type service,s
ocket --full --output json --no-pager", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/rendere
[8112:1104/124241.425924:INFO:CONSOLE:4451] "Executing one-off command: bash ["--norc","--noprofile","-c","sys
temctl --user list-units --type service,socket --full --output json --no-pager"]", source: file:///usr/lib/gar
[8112:1104/124241.425995:INFO:CONSOLE:4451] "Executing bash code: pacman -Qq", source: file:///usr/lib/garuda-
[8112:1104/124241.426054:INFO:CONSOLE:4451] "Executing one-off command: bash ["--norc","--noprofile","-c","pac
man -Qq"]", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/index.js (4451
[8112:1104/124241.426119:INFO:CONSOLE:4451] "Executing bash code: groups barn | cut -d ' ' -f 3-", source: fil
[8112:1104/124241.426185:INFO:CONSOLE:4451] "Executing one-off command: bash ["--norc","--noprofile","-c","gro
ups barn | cut -d ' ' -f 3-"]", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/c
[8112:1104/124241.426260:INFO:CONSOLE:4451] "Executing bash code: cat /etc/resolv.conf | grep nameserver | hea
d -n 1 | cut -d " " -f 2", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client
/index.js (4451)
[8112:1104/124241.426341:INFO:CONSOLE:4451] "Executing one-off command: bash ["--norc","--noprofile","-c","cat
/etc/resolv.conf | grep nameserver | head -n 1 | cut -d \" \" -f 2"]", source: file:///usr/lib/garuda-rani/ap
[8112:1104/124241.426411:INFO:CONSOLE:4451] "Executing bash code: basename $(/usr/bin/getent passwd $USER | aw
k -F':' '{print $7}')", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/in
dex.js (4451)
[8112:1104/124241.426471:INFO:CONSOLE:4451] "Executing one-off command: bash ["--norc","--noprofile","-c","bas
ename $(/usr/bin/getent passwd $USER | awk -F':' '{print $7}')"]", source: file:///usr/lib/garuda-rani/app.asa
[8112:1104/124241.426547:INFO:CONSOLE:4451] "Executing bash code: cat /etc/hosts | grep -A1 "Blocked domains"
| awk '/Blocked domains/ { print $NF }'", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/rende
[8112:1104/124241.426606:INFO:CONSOLE:4451] "Executing one-off command: bash ["--norc","--noprofile","-c","cat
/etc/hosts | grep -A1 \"Blocked domains\" | awk '/Blocked domains/ { print $NF }'"]", source: file:///usr/lib
[8112:1104/124241.426671:INFO:CONSOLE:4451] "Executing bash code: localectl list-locales", source: file:///usr
[8112:1104/124241.426730:INFO:CONSOLE:4451] "Executing one-off command: bash ["--norc","--noprofile","-c","loc
alectl list-locales"]", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/in
dex.js (4451)
[8112:1104/124241.426794:INFO:CONSOLE:4451] "Executing bash code: grep -q wifi.backend=iwd /etc/NetworkManager
/conf.d/*.conf", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/index.js
(4451)
[8112:1104/124241.426853:INFO:CONSOLE:4451] "Executing one-off command: bash ["--norc","--noprofile","-c","gre
p -q wifi.backend=iwd /etc/NetworkManager/conf.d/*.conf"]", source: file:///usr/lib/garuda-rani/app.asar/node_
[8112:1104/124241.429862:INFO:CONSOLE:4451] "Loading on", source: file:///usr/lib/garuda-rani/app.asar/node_mo
[8112:1104/124241.539936:INFO:CONSOLE:4451] "One-off command bash finished with code: 2", source: file:///usr/
[8112:1104/124241.540048:INFO:CONSOLE:4451] "One-off command bash finished with code: 0", source: file:///usr/
[8112:1104/124241.540152:INFO:CONSOLE:4451] "One-off command bash finished with code: 0", source: file:///usr/
[8112:1104/124241.540245:INFO:CONSOLE:4451] "One-off command bash finished with code: 0", source: file:///usr/
[8112:1104/124241.540375:INFO:CONSOLE:4451] "One-off command bash finished with code: 0", source: file:///usr/
[8112:1104/124241.540452:INFO:CONSOLE:4451] "One-off command bash finished with code: 0", source: file:///usr/
[8112:1104/124241.547926:INFO:CONSOLE:4451] "One-off command bash finished with code: 0", source: file:///usr/
[8112:1104/124241.606192:INFO:CONSOLE:4451] "One-off command bash finished with code: 0", source: file:///usr/
[8112:1104/124242.867722:INFO:CONSOLE:4451] "Last update: 2025-11-04T16:29:12.000Z", source: file:///usr/lib/g
INFO [12:42:42.867]: Renderer - Last update: 2025-11-04T16:29:12.000Z
[8112:1104/124246.499548:INFO:CONSOLE:4451] "One-off command bash finished with code: 0", source: file:///usr/
[8112:1104/124246.946436:INFO:CONSOLE:4451] "Updates: falcosecurity-libs 0.20.0-6 -> 0.20.0-7", source: file:/
[8112:1104/124246.946527:INFO:CONSOLE:4451] "Updates: grpc 1.75.1-2 -> 1.76.0-1", source: file:///usr/lib/garu
[8112:1104/124246.946605:INFO:CONSOLE:4451] "Updates: kismet 2023_07_R2-7 -> 2023_07_R2-8", source: file:///us
[8112:1104/124246.946671:INFO:CONSOLE:4451] "Updates: libvlc 3.0.21-30 -> 3.0.21-31", source: file:///usr/lib/
[8112:1104/124246.946741:INFO:CONSOLE:4451] "Updates: mumble 1.5.857-1 -> 1.5.857-2", source: file:///usr/lib/
[8112:1104/124246.946803:INFO:CONSOLE:4451] "Updates: opencv 4.12.0-11 -> 4.12.0-12", source: file:///usr/lib/
[8112:1104/124246.946871:INFO:CONSOLE:4451] "Updates: protobuf 32.1-1 -> 33.0-2", source: file:///usr/lib/garu
[8112:1104/124246.946933:INFO:CONSOLE:4451] "Updates: protobuf-c 1.5.2-6 -> 1.5.2-7", source: file:///usr/lib/
[8112:1104/124246.947016:INFO:CONSOLE:4451] "Updates: python-protobuf 32.1-1 -> 33.0-2", source: file:///usr/l
[8112:1104/124246.947114:INFO:CONSOLE:4451] "Updates: scap-dkms 0.20.0-6 -> 0.20.0-7", source: file:///usr/lib
[8112:1104/124246.947211:INFO:CONSOLE:4451] "Updates: telegram-desktop 6.2.5-1 -> 6.2.5-2", source: file:///us
[8112:1104/124246.947271:INFO:CONSOLE:4451] "Updates: vlc 3.0.21-30 -> 3.0.21-31", source: file:///usr/lib/gar
[8112:1104/124246.947345:INFO:CONSOLE:4451] "Updates: vlc-cli 3.0.21-30 -> 3.0.21-31", source: file:///usr/lib
[8112:1104/124246.947404:INFO:CONSOLE:4451] "Updates: vlc-gui-qt 3.0.21-30 -> 3.0.21-31", source: file:///usr/
[8112:1104/124246.947467:INFO:CONSOLE:4451] "Updates: vlc-plugin-a52dec 3.0.21-30 -> 3.0.21-31", source: file:
[8112:1104/124246.947525:INFO:CONSOLE:4451] "Updates: vlc-plugin-alsa 3.0.21-30 -> 3.0.21-31", source: file://
[8112:1104/124246.947587:INFO:CONSOLE:4451] "Updates: vlc-plugin-archive 3.0.21-30 -> 3.0.21-31", source: file
[8112:1104/124246.947644:INFO:CONSOLE:4451] "Updates: vlc-plugin-dav1d 3.0.21-30 -> 3.0.21-31", source: file:/
[8112:1104/124246.947730:INFO:CONSOLE:4451] "Updates: vlc-plugin-dbus 3.0.21-30 -> 3.0.21-31", source: file://
[8112:1104/124246.947788:INFO:CONSOLE:4451] "Updates: vlc-plugin-dbus-screensaver 3.0.21-30 -> 3.0.21-31", sou
[8112:1104/124246.947852:INFO:CONSOLE:4451] "Updates: vlc-plugin-faad2 3.0.21-30 -> 3.0.21-31", source: file:/
[8112:1104/124246.947910:INFO:CONSOLE:4451] "Updates: vlc-plugin-ffmpeg 3.0.21-30 -> 3.0.21-31", source: file:
[8112:1104/124246.947972:INFO:CONSOLE:4451] "Updates: vlc-plugin-flac 3.0.21-30 -> 3.0.21-31", source: file://
[8112:1104/124246.948029:INFO:CONSOLE:4451] "Updates: vlc-plugin-gnutls 3.0.21-30 -> 3.0.21-31", source: file:
[8112:1104/124246.948097:INFO:CONSOLE:4451] "Updates: vlc-plugin-inflate 3.0.21-30 -> 3.0.21-31", source: file
[8112:1104/124246.948159:INFO:CONSOLE:4451] "Updates: vlc-plugin-journal 3.0.21-30 -> 3.0.21-31", source: file
[8112:1104/124246.948221:INFO:CONSOLE:4451] "Updates: vlc-plugin-jpeg 3.0.21-30 -> 3.0.21-31", source: file://
[8112:1104/124246.948278:INFO:CONSOLE:4451] "Updates: vlc-plugin-lua 3.0.21-30 -> 3.0.21-31", source: file:///
[8112:1104/124246.948356:INFO:CONSOLE:4451] "Updates: vlc-plugin-mpg123 3.0.21-30 -> 3.0.21-31", source: file:
[8112:1104/124246.948414:INFO:CONSOLE:4451] "Updates: vlc-plugin-ogg 3.0.21-30 -> 3.0.21-31", source: file:///
[8112:1104/124246.948476:INFO:CONSOLE:4451] "Updates: vlc-plugin-opus 3.0.21-30 -> 3.0.21-31", source: file://
[8112:1104/124246.948533:INFO:CONSOLE:4451] "Updates: vlc-plugin-png 3.0.21-30 -> 3.0.21-31", source: file:///
[8112:1104/124246.948596:INFO:CONSOLE:4451] "Updates: vlc-plugin-pulse 3.0.21-30 -> 3.0.21-31", source: file:/
[8112:1104/124246.948653:INFO:CONSOLE:4451] "Updates: vlc-plugin-shout 3.0.21-30 -> 3.0.21-31", source: file:/
[8112:1104/124246.948715:INFO:CONSOLE:4451] "Updates: vlc-plugin-speex 3.0.21-30 -> 3.0.21-31", source: file:/
[8112:1104/124246.948771:INFO:CONSOLE:4451] "Updates: vlc-plugin-tag 3.0.21-30 -> 3.0.21-31", source: file:///
[8112:1104/124246.948833:INFO:CONSOLE:4451] "Updates: vlc-plugin-theora 3.0.21-30 -> 3.0.21-31", source: file:
[8112:1104/124246.948889:INFO:CONSOLE:4451] "Updates: vlc-plugin-twolame 3.0.21-30 -> 3.0.21-31", source: file
[8112:1104/124246.948951:INFO:CONSOLE:4451] "Updates: vlc-plugin-vorbis 3.0.21-30 -> 3.0.21-31", source: file:
[8112:1104/124246.949007:INFO:CONSOLE:4451] "Updates: vlc-plugin-vpx 3.0.21-30 -> 3.0.21-31", source: file:///
[8112:1104/124246.949075:INFO:CONSOLE:4451] "Updates: vlc-plugin-xml 3.0.21-30 -> 3.0.21-31", source: file:///
[8112:1104/124246.949132:INFO:CONSOLE:4451] "Updates: vlc-plugins-base 3.0.21-30 -> 3.0.21-31", source: file:/
[8112:1104/124246.949215:INFO:CONSOLE:4451] "Updates: vlc-plugins-video-output 3.0.21-30 -> 3.0.21-31", source
[8112:1104/124246.962227:INFO:CONSOLE:4451] "No aur updates available", source: file:///usr/lib/garuda-rani/ap
INFO [12:42:46.962]: Renderer - No aur updates available
[8112:1104/124255.090886:INFO:CONSOLE:4451] "Pacfiles: /etc/default/grub-btrfs/config.pacnew, /etc/pacman.d/mi
rrorlist.pacnew", source: file:///usr/lib/garuda-rani/app.asar/node_modules/@app/renderer/dist/client/index.js
(4451)
[8112:1104/124255.091013:INFO:CONSOLE:4451] "Loading off", source: file:///usr/lib/garuda-rani/app.asar/node_m
odules/@app/renderer/dist/client/index.js (4451)`Preformatted text`
Heya!
It’s very possible the issue with Rani here is related to your NVIDIA graphics card.
Unfortunately, your graphics card is over a decade old, released in 2012. The latest Nvidia drivers have no support for a graphics card this old.
Garuda Linux will not automatically install legacy drivers like this for you, but you are free to do so on your own. Just be aware that these older drivers are more likely to break on new kernel releases, so keep linux-lts close.
sudo pacman -S linux-lts linux-lts-headers nvidia-470xx-dkms nvidia-470xx-utils lib32-nvidia-470xx-utils
After a reboot, the graphics driver should be loaded.
Can you test if Rani works as intended afterwards?
Yes, this is an old laptop that I am using to become more familiar with Linux and the command line. I am already learning a lot. The new/old driver did the trick. I really appreciate all of the help. Thanks!
